Filling the Resin Tank
The resin tank is designed to hold up to 200 mL of resin. Add resin to the tank before starting the print.
1. Shake the resin bottle
Tip
Over time, pigment in the colored resins (such as black or grey) may settle to the bottom of the container. Shaking the bottle before use ensures even color.
2. Pour into resin tank
3. Fill to maximum line slowly
Warning
Filling the resin tank above the maximum fill line will damage the printer and void your warranty if resin overflows the tank during printing.
Larger prints may require that the resin tank is refilled during the print. With the printer paused, open the cover, and slowly add more resin to reach the maximum fill line.
Once the resin tank has been filled, you are ready to start your print.
Contact Support
Questions? Get in touch.
