Formlabs Application Guide
3D Printing Splints with the Form 2
Dental LT Clear Resin is a long term biocompatible material formulated for manufacturing dental splints and retainers. As a rigid material, Dental LT Clear is most appropriate for printing hard splints. If soft or hard-soft splints are desired, the best method is to print the model and thermoform.
This application guide demonstrates each step for making 3D printed splints on Formlabs’ Form 2 3D printer. Use the following workflow to ensure precise results.
Table of Contents
Save, print, or share with colleagues?
Download a PDF of the article below!
Essentials
Made by Third Parties:
  • Dental Design Software (CAD)
  • Intraoral or Desktop Optical Scanner
  • Alternative Post-Cure Chamber
1. Scan
In order to print a model, anatomical data of the patient’s dentition must be collected with a scanner. Either scan with an intraoral scanner directly with a patient, or use a desktop optical scanner to on a polyvinyl siloxane (PVS) impression.
2. Design
In order to print this scan data as a model, the data needs to be processed in dental CAD software. Make sure to pick software with a model builder module that offers open .STL export.
For exact design steps, contact the manufacturer or reseller of the software for details. A few major steps that are important to take into consideration for 3D printing are:
ParameterRecommended values
Minimum side wall thickness1.0 mm
Minimum bottom/occlusal surface thickness1.5 mm
Offset (aka. “Block Out Undercuts Offset”)>= 0.1 mm
2.1 Import & trim scans—both preparation and antagonist
First, import the intraoral or desktop optical scans of the patient dentition into your preferreddental CAD software. Use line marking or area selection tools to remove erroneous scan data, and select only the portion of the dentition that will be printed.
2.2 Define insertion direction and block out undercuts
Ensure that the model is blocked out adequately where needed, depending on the specifics of the case. Block out undercuts directly to impact the retention of the splint.
Left: Splint boundaries defined using spline tools.
Right: Automatically generated initial splint mesh.
2.3 Generate initial splint shell and apply
To design the splint, use spline tools to mark the margin of the splint along the perimeter of the arch. Generate an initial splint design, using a minimum thickness of 1.0 mm and an offset of 0.1 mm. Adjust the design manually using standard sculpting tools if necessary.
Left: Splint bar path defined using spline tools.
Right: Automatically generated bar mesh applied to the splint mesh.
2.4 Generate splint bar
In splint design software that offers the option, use the spline tools to generate a bar and combine it with the splint design. Ensure that the total initial thickness of the bar and shell are at an initial minimum of 3.0 mm, to allow space for antagonist adaptation.
When using splint design software that does not allow for the generation of a bar, ensure that the bottom surfaces of the splint are at least 1.5 mm thick.
Splint with areas highlighted for adaptation due to dynamic occlusion with the antagonist
2.5 Adapt splint design to antagonist
Remove material on the underside of the splint to adapt the design to the antagonist. Use static occlusion or dynamic occlusion via a virtual articulator, depending on the CAD software.
Using inspection tools to ensure that side wall thicknesses are greater than 1.0 mm and bottom surfaces are thicker than 1.5 mm.
2.6 Check design and make final adjustments
Inspect the model to ensure that the part is not thinner than 1.5 mm at any point in the occlusion or 1.0 mm in the side wall. Adjust the design manually using standard sculpting tools if necessary. Finalize the design by double checking the occlusion and articulation of the model and splint.
2.7 Export
Once the design is created, export a digital model of the part in STL or OBJ file format.
3. Print
3.1 Select material
Open PreForm. Select “LT Clear” from the Material menu.
3.2 Import model files into PreForm
Import the .STL or .OBJ file into PreForm.
3.3 Orient models
Orient parts with the intaglio surfaces facing away from the build platform, to ensure that supports will not be generated on these surfaces.
Ensure that parts are oriented at an angle of 30° or less. Orienting parts upright or at angles more than 30° will compromise precision and lead to poorly fitting parts.
When angling the model in PreForm rotate the anterior portion upward and away from the build platform so that the posterior ends remain closer to the build platform.
WARNING!
Printing at greater than 30° angles will result in poorly fitting splints. As the angle of inclination of the part increases above 30 degrees, interproximal surfaces will print less accurately, which may result in a poor fit.
3.4 Generate Supports
Generate supports using PreForm’s auto-generation feature. Inspect the part to ensure there are no support touchpoints on intaglio surfaces. Use the manual support editing feature to add or remove supports, if needed.
3.5 Upload the print
3.6 Prepare the printer and resin
Insert a resin tank, resin cartridge, and build platform into the printer. Thoroughly
agitate the resin cartridge before inserting, by shaking and rotating it several times.
3.7 Print
WARNING!
For full compliance and biocompatibility, Dental LT Clear requires a dedicated resin tank, build platform, and finishing kit, which should only be used with other Formlabs biocompatible resins, such as Dental SG.
Using Standard Resin Tanks vs. Resin Tank LT
For the highest accuracy and precision, Resin Tank LT is recommended for printing with Dental LT Clear. Testing of Dental LT Clear on Resin Tank LT revealed no degradation of accuracy or precision over the lifetime of the tank. If using the standard resin tanks, laser exposure forms white, clouded marks on the surface of the resin tank’s silicone layer. This clouding eventually becomes extreme enough to affect accuracy. Testing revealed that splint accuracy began decreasing after 2,000 layers were printed i
4. Post-processing printed splints
Post-processing 3D printed splints primarily involves five steps: rinsing, drying, post-curing, removing supports, and polishing
4.1a Wash parts with Form Wash
Place the build platform, with surgical guides still attached, into a Form Wash filled with isopropyl alcohol (IPA, 96% or higher). Set Form Wash for 5 minutes, which will clean the parts and remove liquid resin before post-curing.
Leave parts to air dry completely, or use a compressed air hose to blow IPA away from parts’ surfaces. Inspect parts closely to ensure all uncured resin has been removed. Repeat wash if necessary, but do not leave parts in IPA for more than 10 minutes, as this may reduce mechanical performance and cause defects in the printed parts. Remove parts from the build platform with the part removal tool.
4.2a Post-cure parts with Form Cure
Printed splints must be exposed to light and heat to achieve biocompatibility and optimal mechanical properties. Place the printed parts into a Form Cure. Post-cure for 20 minutes at 80 °C.
WARNING!
Post-curing outside of the recommended settings can lead to extreme discoloration of the parts. Post-curing at too high a temperature, for too long a duration, or with too high intensity of light can cause yellowing. In addition, improper post-curing steps can also lead to sub-optimal mechanical and biocompatibility properties. Post-cure only in accordance with official recommendations from Formlabs for the clearest and best possible results.
4.2b Post-cure parts with an alternative post-cure chamber
Printed splints must be exposed to light and heat to achieve biocompatibility and optimal mechanical properties. Post-cure time depends on the light intensity and the internal temperature of the post-curing device. One acceptable method for post-curing is exposure for 10 minutes to 72 watts of Blue UV-A (315–400 nm) in a heated environment at 60 °C (140 °F). One acceptable lighting setup is four 18W/78 lamps (Dulux blue UV-A).
4.3 Remove supports
Use the flush cutters included in the Formlabs Standard Finish Kit to carefully cut the supports at the points where they attach to the part. Use caution when cutting the supports, as the post-cured material may be brittle. Supports can also be removed using other specialized appliances, such as cutting disks or round cutting instruments like carbide burs.
4.4 Polish parts
For a glossy surface finish, polish parts using a rag wheel and pumice at low speeds. After initial rough polishing, switch to a dry cloth polish. Finish with a high-grit acrylic buffing paste, such as Hi-Shine, at high speeds.
4.5 Check fit
To check fit, print a solid model of the patient’s dentition, and place the splint on the model. Make adjustments to the 3D model or the post-processed parts if necessary. For printing orthodontic models we recommend Standard White or Grey Resin. For higher accuracy, use Dental Model Resin.
5. Cleaning and Disinfecting
Use an ethanol solution to disinfect parts before use.
Accuracy Study
An in-depth accuracy study of 80 Dental LT Clear printed splints showed that intaglio surfaces of Form 2 printed splints were dimensionally accurate within ± 100 microns over 80 percent of the intaglio surfaces, and within ± 125 microns over 90 percent of the surfaces. This was found to provide a precise fit on both models and patients.
Biocompatibility
Dental LT Clear is a Class IIa biocompatible resin that is in conformity with the essential requirements and provisions of the Council Directive 93/42/EEC concerning medical devices as amended by Directive 2007/47/EC, and is in conformity with the following standards:
EN ISO 1641:2009
EN-ISO 10993-1:2009/AC:2010
EN-ISO 10993-3:2009
EN-ISO 10993-5:2009
EN 908:2008
EC Declaration of Conformity
Additional Resources
Explore Formlabs dental resources for in-depth guides. step-by-step tutorials, white papers, webinars, and more.
See all Dental Resources
Powerful, Affordable 3D Printers for Dental Professionals
Bring high precision 3D printing into your dental lab or dental office with the Form 2.
See the Form 2   Request a Sample Part
