Consejo:
Visita la página de asistencia de la Fuse Recorrido interactivo de la Sift para ver en 3D muchos de los componentes que detallamos a continuación.
Consejo:
Espacio de trabajo y componentes externos
| Item | Description | Image |
| Hood | Prevents powder and debris from leaving the Fuse Sift’s workspace. | |
| Control panel | A touchscreen and physical control panel for interfacing with the Fuse Sift. | |
| Vacuum | The vacuum hose and power cord plug into ports on the side of the Fuse Sift, allowing the vacuum to be controlled via the Fuse Sift's touchscreen or control panel. | |
| Vacuum hose | Connected to the external vacuum for cleaning the Fuse 1 and Fuse Sift after use. | |
| Tool shelf | Storage for break-out tools and brushes. | |
| Parts basket | Storage container for extracted parts while processing a cake. | |
| Vent | A fan pulls dispersed powder into a filter, preventing plumes from leaving the workspace. | |
| Light | The light illuminates the workspace while extracting and cleaning printed parts. | |
| Sifter | The sifter agitates and breaks up clumps of unsintered powder from previous prints before it is recaptured for reuse. | |
| Surface grate | Protective grate covering the sifter. |
| Powder catch | Removable tray for catching loose powder. |
| Mixer | The mixer spins a filled powder cartridge to ensure a homogeneous distribution of fresh and used powder. |
Cámara de impresión
| Build chamber | An interchangeable component of the Fuse 1 that contains the print bed, heaters and temperature sensors, and encapsulates the sintered parts and loose powder from a print. The accompanying plug allows the Fuse 1 and Fuse Sift to monitor the build chamber, and differentiate one build chamber from another. | |
| Build chamber enclosure | Area for housing the build chamber with prints ready to be ejected. |
| Build chamber port | Access port for the cooled powder cake to enter the workspace. |
| Build chamber latch | Secures the build chamber. |
| Build chamber socket | Connects the build chamber’s plug. |
Manipulación del polvo
| Sifter mesh | The sifter mesh filters reusable powder from unusable powder. |
| Fresh powder hopper | The fresh powder hopper holds unused powder for dispensing into a powder cartridge. | |
| Used powder hopper | The used powder hopper holds recaptured powder for dispensing into a powder cartridge. | |
| Fresh powder hopper lid | Access point for filling the fresh powder hopper. |
| Doser assembly | The doser assembly dispenses fresh and used powder into a powder cartridge in a ratio matching the selected refresh rate. |
| Cartridge drawer | Holds the powder cartridge while it is being filled with powder. Weight sensors in the cartridge drawer ensure that the cartridge is filled properly. |
Placa base y sistemas electrónicos
| Motherboard | The main circuitry through which all systems in the machine communicate. | |
| Power supply | The Fuse Sift requires a 230 VAC (50 Hz), 7.5 A power supply (EU) or 120 VAC (60 Hz), 15 A power supply (US) for nominal operation. |
| Wi-Fi antenna | The Wi-Fi antenna enables the Fuse Sift's wireless connectivity. The antenna is connected to the machine's motherboard. |
| Ethernet and USB ports | The Fuse Sift can connect to a network via Ethernet or to a computer via USB. These ports are connected to the motherboard and can be accessed from the back of the machine. |
Panel de control
| Touchscreen | Interactive touchscreen for controlling subsystems and settings of the Fuse Sift. | |
| Physical controls |
Cartucho de polvo
| Elemento | Descripción | Imagen |
| Cartucho de polvo | El recipiente en el que se mezcla el polvo de SLS y se transporta desde la Fuse Sift hasta la tolva de la impresora. |
| Alas del cartucho | Dos brackets para bloquear el cartucho en el mezclador. |
| Válvula del cartucho | La abertura principal para llenar y depositar el polvo. |
| Cuchilla de la válvula | Se utiliza para cerrar y abrir la válvula del cartucho. |
| Asas | Para sujetar y levantar el cartucho. |
Mezclador
| Plataforma giratoria del mezclador | La cara exterior del mezclador que gira con el cartucho. |
| Pestañas de bloqueo | Dos pestañas con muelle para fijar el cartucho en el mezclador. |
| Acopladores de las aletas del cartucho | Dos soportes que guían las aletas del cartucho hasta su posición. |
