Tackle any problem with our industry-leading materials, including biocompatible options, or Open Material Mode.
Form4BL
Innovate at scale without limitations
Same-day turnaround for large or high-volume parts
Parts that always fit
High-performance biocompatible materials and Open Material Mode
Dependable production with stunningly accurate results
Anyone can learn in 15 minutes
Form4BL
Solve big problems with large-scale medical parts
or produce many parts in one print job, so you can accelerate product development or keep production running.Speed that scales. Same-day turnaround for large prints.
- 9h56mForm 4BL27h6mLeading FDM16h4mBenchmark SLA50h18mForm 3BL
Arbutus Medical QuikBow Arms
- 7h46mForm 4BL43h20mLeading FDM10h35mBenchmark SLA68h15mForm 3BL
restor3d Spinal Sizing Trials
- 11h57mForm 4BL27h25mLeading FDM*13h5mBenchmark SLA*92h17mForm 3BL
Axial3D Scoliotic Thorax
- 8h18mForm 4BL17h28mLeading FDM**11h8mBenchmark SLA**47h16mForm 3BL
Skull
- 2h39mForm 4BL13h10mLeading FDM18h6mBenchmark SLA21h36mForm 3BL
Ventilator
* Scaled to 80% to fit
** Reduced number of parts per build
Produce stunning parts that always fit, rivaling injection molding.
Smoothest Surfaces
Lower peel forces, Light Touch Supports, and 46 µm pixel size with pre-tuned anti-aliasing.
Sharpest Details
Highly collimated light and 46 µm pixel size with pre-tuned anti-aliasing for subpixel resolution.
Most Accurate Assemblies
±0.15% XY dimensional tolerances so assemblies always fit.
- QUIKBOW® IS A STERILE-READY, SINGLE-USE TENSION BOW FOR SKELETAL TRACTION IN THE OPERATING ROOM. IT ALLOWS TRAUMA CENTERS TO USE A SMALLER WIRE WITHOUT A KIRSCHNER BOW (K-BOW).
Smoothest Surfaces
Sharpest Details
QuikBow®Arbutus Medical
Reliability at scale. Large format 3D printing you can depend on.
Formlabs optimization engineers put hundreds of printed parts to the test to ensure each material performs to the most reliable standards, right out of the box.
Learn to print in four simple steps:
So intuitive that anyone can learn to print in 15 minutes.
- 1
Import your model and prepare your print.
- Smart auto-orientation
- Advanced support generation
- Live printability checks
- 2
Load a material and click print.
- Validated print settings
- No-hassle cartridge and tanks
- Automatic resin dispensing
- 3
Remove, wash, cure.
- Quick release part removal*
- Automatic part cleaning
- Precision post-curing for peak material properties
- *Build Platform Flex L is not yet available. Coming soon.
- 4
Finish your part.
- Light touch supports for quick, clean support removal
- Optional sanding, coating, or painting
Low Force Display™ (LFD)
The Power Behind Form 4BLLow Force Display™ (LFD)
The Power Behind Form 4BLSolutions for every stage of the process, from prototyping to commercial product.
Formlabs 3D printers helped PSYONIC create the Ability Hand, an FDA-registered, Medicare-covered, industry-defining upper-limb prosthesis from scratch. In-house printing enables rapid iteration and versatile testing with specialized resins, eliminating the need for costly outsourcing. This accelerates medical device development, saving time and resources while bringing products to market faster and at lower costs.
The Form 4BL Ecosystem
Complete Your 3D Printing Experience
Form 4BL
