Form 3BL
Large Medical Devices and Anatomical Replicas at Full Scale
3D print adult patient-specific anatomy at 1:1 scale or large medical devices in one build with the Form 3BL, a large-format 3D printer developed for medical professionals. This 3D printer is compatible with the majority of our SLA materials library, including biocompatible, sterilizable materials.
Form 3BL is now succeeded by Form 4BL, our next-generation medical 3D printer, which improves upon its foundation in every possible way.
Speed That Scales
Form 4BL is powered by our Low Force Display™ (LFD) Print Engine, setting the new industry standard for blazing-fast speed, unmatched reliability and accuracy, and the widest range of performance 3D printing materials. Complete large prints the size of the entire build volume in under 6 hours and solve big problems with big parts.
Big Parts, Big Ideas
With a large build volume of 33.5 × 20 × 30 cm (13.2 × 7.9 × 11.8 in),
you can print full-scale bulky prototypes or detailed models.
Life-Sized 3D Prints
On-Demand Printing
Validated Workflows
Form 3BL Is Ideal For:
What Could You Print?
Grey Resin
65 hours
$86
Minnetronix
Note: print time and cost will vary based on part geometry, material, layout, and orientation.
Intuitive and efficient
Seamlessly integrate the Form 3BL into your existing clinical workflows - no specialized technicians required. With automatic resin dispensing, simple print preparation software, and a thoughtfully designed interface, the Form 3BL is designed for efficiency.
Always on call
Always on call
The Form 3BL works around the clock with minimal supervision required. With compatability with our entire SLA materials library, sensors that maintain ideal print conditions, and remote printing, the Form 3BL helps you meet critical deadlines, even for trauma surgery. Achieve multicolor parts using various techniques.
Incredible part quality
The Form 3BL resolves fine details down to the micron level, critical when using surgical planning models for diagnostic use, while the smooth surface finish and high accuracy of the Form 3BL ensures medical devices meet production standards.
XY Resolution
Laser Power
Open System to Unlock Innovation in Healthcare
Formlabs Open Platform empowers healthcare professionals to drive groundbreaking advancements. Customizable print settings and the ability to print with any 405nm photopolymer resin on Form 3BL allow you to unleash unlimited possibilities for medical R&D.
Materials for a Wide Array of Applications
Access a library of 40+ materials compatible with the Form 3BL. Our technology has been validated in multiple FDA-cleared workflows and we develop and manufacture our own biocompatible materials in an ISO 13485 certified, FDA-registered facility. Parts can be sterilized using steam, e-beam, gamma, or EtO.
Compare Formlabs SLA 3D Printers
Form 3BL
7.9 × 4.9 × 8.3 in
5.25 liters
13.9 x 7.7 x 14.0 in
24.2 liters
21.4 liters
40.4 lb
129 lb
120 lb
15.7 × 14.5 × 21.9 in
26.1 x 20.8 x 31.3 in
30.3 × 20.5 × 29.1 in
Part of the Formlabs Ecosystem
Formlabs is known for designing end-to-end additive workflows you’ll be excited to use. The Form 3BL brings the Formlabs experience to large format 3D printing.
Post-Processing, Simplified
Streamline your workflow and consistently produce high-quality biocompatible parts with our automated large-format post-processing solution.
Form Wash L and Form Cure L have been validated and are compatible with our ISO 13485 compliant materials for biocompatible use.
Quick Release Technology
Build Platform 2L with patented Quick Release Technology easily releases parts from the build platform in seconds - no tools required.
Support When You Need It
Behind our Medical Service Plan is a dedicated team of certified medical 3D printing specialists who know exactly how to support you from prototype to the operating room.
Industry-Leading Software
Tested over millions of prints, PreForm automatically suggests optimal orientation, supports, and layout to save time during print setup.
Explore the Form 3BL
Maximize Your 3D Printer Fleet’s Throughput With 24/7 Production
Reach new levels of productivity with a fully automated fleet of Form 3B+ 3D printers that you can operate from anywhere. Skyrocket your ability to produce high-quality, affordable parts with 24/7 back-to-back production with the Formlabs Automation Ecosystem: Form Auto, Fleet Control, and Resin Pumping System.
The Next Generation of Industrial 3D Printing
Form 4B is powered by our Low Force Display™ Print Engine, setting the new industry standard for blazing-fast speed, leading reliability and accuracy, and the widest range of performance 3D printing materials.
Large Format 3D Printing You Can Rely On
Meet critical deadlines in-house without prohibitive costs. Formlabs brings unprecedented reliability, quality, and ease of use, with validated workflows tested by a team of medical experts.
