Get more done with most prints in under 2 hours.
  • 1h38min
    Form 4
    game controller
    3h37min
    Benchmark FDM
    4h11min
    Benchmark SLA
    10h47min
    Form 3+
    Battle Beaver Customs, Game Controller
    game controller
  • 2h49min
    Form 4
    LED Light Bar and Mount
    4h28min
    Benchmark FDM
    6h52min
    Benchmark SLA
    10h35min
    Form 3+
    Holley, LED Light Bar and Mount
  • 2h1min
    Form 4
    robotic Finger
    3h54min
    Benchmark FDM
    3h37min
    Benchmark SLA
    8h31min
    Form 3+
    RightHand Robotics, Robotic Finger Overmolds
    robotic Finger
  • 1h37min
    Form 4
    Tower Cap
    5h32min
    Benchmark FDM
    4h38min
    Benchmark SLA
    4h29min
    Form 3+
    Formlabs Form 4, Tower Cap
    Tower Cap
  • 1h28min
    Form 4
    Connector
    9h12min
    Benchmark FDM
    2h16min
    Benchmark SLA
    9h43min
    Form 3+
    Electrical Connector
    Connector
(1) Typical print time using 80th percentile print height (53 mm), 100 µm layer height, and most materials.
Print time is similar whether you’re printing one part or a full build of many parts.
1hr19min
1hr13min
Parts being 3D Printed
Prototyping
Increase your productivity by 3x. Say goodbye to iterating after hours.
Prototyping - 3D printed parts
Production
1 Minute per Part. Reach peak production efficiency.
3D printing production - several parts
Produce stunning parts that always fit, rivaling injection molded parts.
Sharpest Details
Highly collimated light and 50 µm pixel size with pre-tuned anti-aliasing for subpixel resolution
Smoothest Surfaces
Lower peel forces, light touch supports, and 50 µm pixel size with pre-tuned anti-aliasing
Most Accurate Assemblies
±0.15% XY dimensional tolerances so assemblies always fit.
  • Injection Mold
    INJECTION MOLD
    Sharpest Details
    Smoothest Surfaces
    Injection Mold
    Manufacturing
  • Jig
    JIG
    Sharpest Details
    Smoothest Surfaces
    Jig
    Automotive
  • Heat Sink and Shield
    HEAT SINK AND SHIELD
    Sharpest Details
    Smoothest Surfaces
    Consumer Products
  • Fluidic Device
    FLUIDIC DEVICE
    Sharpest Details
    Smoothest Surfaces
    Fluidic Device
    Fluidics
  • Gamer Controller
    GAMER CONTROLLER
    Sharpest Details
    Smoothest Surfaces
    Gamer Controller
    Consumer Products
  • Surgical Ratchet
    SURGICAL RATCHET
    Sharpest Details
    Smoothest Surfaces
    Surgical Ratchet
    Medical
Tackle any problem with our industry-leading materials, or use Open Material Mode.
Rigid Ultra stiff, high strength, glass-filled
Learn More
Unmatched reliability. Stop coming back to failed prints.
Form 4 was measured to have a 98.7% print success rate by an independent global leader in product testing. Read a complete description of the test methodology and see the results in our white paper.
  • So intuitive that anyone can learn to print in 15 minutes.
  • 1
    Import your model and prepare your print.
    • Smart auto-orientation
    • Advanced support generation
    • Live printability checks
  • 2
    Load a material and click print.
    • Validated print settings
    • No-hassle cartridge and tanks
    • Automatic resin dispensing
  • 3
    Remove, wash, cure.
    • Quick release part removal
    • Automatic part cleaning
    • Precision post-curing for peak material properties
  • 4
    Finish your part.
    • Light touch supports for quick, clean support removal
    • Optional sanding, coating, or painting
Low Force Display™ (LFD)
The Power Behind Form 4
The Backlight Unit generates a uniform area projection of an ultra-high power light using 60 LEDs and collimating lenses. It cures resin quickly and precisely, delivering blazing fast print speeds with excellent print quality and accuracy anywhere on the build platform.
A wide range of applications to help you excel in your work.
Pre-Production Validation
Tough 1500 Resin
Forge Motorsport reverse-engineered an underperforming part, 3D printed a new design, and tested it on a vehicle for five months before committing to tooling.
Tough 1500 Resin
Rapid Prototyping
Ford
“Working with Form 4, it's really a game-changer. The speed of the printer will change our workflow. We can deliver more parts, the throughput is higher. We are much more flexible if we have short-time requests. Now we can do these using Form 4.”
Sandro Piroddi
Supervisor of the Rapid Technology Center, Ford
Manufacturing Aids
Eaton
“When we upgraded to Form 4, it truly was like a step change in the technology. All of a sudden, this process that was really intriguing from a quality standpoint and a dimensional accuracy standpoint is now lightning fast. So now we’re combining ease of use with efficiency and accuracy and reliability.”
Cameron Peahl,
Global Industry 4.0 Additive Manufacturing Strategy Manager
End-Use Parts
Maclean Brothers
“The thing that's amazed me most is where the new engineering resins have got to. The strength is really quite impressive and is not far off from what you’d see in a production part. The quality of prints — it's quite amazing. Formlabs, these machines are literally the best."
Ewan Maclean,
Engineer
Rapid Prototyping
Microsoft
"Form 4 is our go-to choice for projects needing tight tolerances and engineering-grade materials. It produces high-performance parts with amazingly fast print times and makes it possible for our model makers to produce multiple iterations in a 24-hour period.”
Mark Honschke,
Additive Prototyping Lead at Microsoft’s Advanced Prototyping Center
Rapid Prototyping
Black Diamond
“On one lighting project, we did three iterations in a single day — designed and printed three different parts before we had a meeting in the afternoon.”
Matt Tetzl,
Product Design Lab Manager, Black Diamond
Rapid Prototyping
OXO
“Form 4 has transformed our workflow. In the past, our queue has often been an issue based on time. With Form 4, it throws that out the window — we’re no longer constrained by time.”
Jesse Emanuel,
Test Engineer, OXO
Rapid Prototyping
Peak Design
“Within an hour of having the Form 4s hooked up and online, they were all going constantly. The big thing that we noticed was the speed — prints done within an hour. Previously, you would get maybe one or two turns on a prototype in a day, now it’s three or four.”
Dane Jones,
Senior Design Engineer, Peak Design
Rapid Prototyping
NASA
“The dramatic increase in print speed for Form 4 has significantly accelerated our fabrication cycle – to the point where I can iterate through many different designs every day and go from design to usable, functional part within the hour."
Matt Mullin,
Laser Engineer, NASA
Rapid Prototyping
Hasbro
"I really appreciate the reliability paired with the speed. It's not one or the other, like many other tools. Now I can commit to internal deadlines and feel confident that I can deliver every time."
Robert Mackowiak,
Rapid Prototyping Engineer
microsoft user story
Black Diamond headlamp
OXO
Peakdesign
crew dragon nasa
Hasbro
Speed That Scales
Powered by the same groundbreaking LFD technology, Form 4L can complete large prints the size of the entire build volume in under 6 hours with unmatched reliability and accuracy, empowering you to solve big problems with big parts.
Form 4L 3D printer
The Form 4 Ecosystem
Complete Your 3D Printing Experience
Form Wash
Form Wash
Automate Cleaning
Find a Reseller
Form Cure
Form Cure
Blazing Fast Post-Curing
Find a Reseller
