Glosario del producto (Fuse 1)
Consejo:
Visita la guía interactiva de la Fuse 1 tour para ver en 3D muchos de los componentes que detallamos a continuación.
Componentes externos
ItemDescriptionImage/video
Print enclosure doorProvides access to the print enclosure and optical cassette tray.
Door handleA grab slot to help close the door.Door handle
Manual door releaseThe print enclosure door is normally opened via the touchscreen. In case of emergency, pull the door release handle inside the filter cabinet to open the print enclosure door.
Card readerEach package of Formlabs powder includes an ID card. This card contains powder credit which must be loaded onto the printer via the card reader to tell the printer how much powder is available.
Filtros
Filter cabinetThe filter cabinet houses the exhaust and intake filters.
Filter cabinet doorSealed door for accessing the intake and exhaust filters.Filter cabinet door
Exhaust filterThe exhaust filter removes powder and sintering byproducts from the printer's exhaust that would otherwise be expelled into the workspace.
Intake filterThe intake filter removes contaminants from air being drawn into the printer.
Tolva de polvo
HopperStores up to 9 kg (19.8 lb) of powder for printing.
Hopper lidPrevents debris from entering and powder from leaving the hopper.Hopper lid
Hopper windowAllows for visual check of powder level in the hopper.Hopper window
Conjunto de la pantalla
Display assemblyThe display assembly contains the touchscreen and the display circuit board. A ribbon cable connects the display assembly to the motherboard.
TouchscreenThe LCD capacitive touch user interface displays print information, settings, and error messages.
Placa base y sistemas electrónicos
MotherboardThe main circuitry through which all systems in the machine communicate.
Power supplyThe Fuse 1 requires a 230 VAC (50 Hz), 7.5 A power supply (EU) or 120 VAC (60 Hz), 15 A power supply (US) for nominal operation.
Motor and temperature control boardThis board handles motor control and temperature sensing in the Fuse 1. These subsystems allow the Fuse 1 to print accurate and high-quality parts.
Heater control boardThis board controls the heaters in the Fuse 1. A precise and consistent internal temperature is key for successful prints.
Front display connectorThis connector links the display to the motherboard via a ribbon cable.Front display connector
Wi-Fi antennaThe Wi-Fi antenna enables the Fuse 1's wireless connectivity. The antenna is connected to the machine's motherboard.Wi-Fi antenna
Ethernet and USB portsThe Fuse 1 can connect to a network via Ethernet or to a computer via USB. These ports are connected to the motherboard and can be accessed from the back of the machine.
FanA cooling fan pulls warm air away from electronic components.Cooling fan
Sensor infrarrojo (IR)
IR sensorAn infrared (IR) sensor monitors conditions inside the print enclosure, and functions as a secondary interlock measure for the laser.
IR sensor doorProvides top-down access to the IR sensor and powder card reader.
Sensor windowThe exposed surface that allows infrared radiation to enter the sensor.Sensor window
Ethernet socketUsed to connect the sensor to the machine and disconnect for cleaning.Ethernet socket
Status lightIndicates if the sensor is seated correctly (green) or incorrectly (yellow). Status light
Cámara de impresión
Build chamberAn interchangeable component of the Fuse 1 that contains the print bed, heaters and temperature sensors, and encapsulates the sintered parts and loose powder from a print. The accompanying plug allows the Fuse 1 and Fuse Sift to monitor the build chamber, and differentiate one build chamber from another.
Print bedThe moving surface (Z-axis) on which powder is deposited and sintered.Print bed
Print bed pistonThe print bed is the moving surface on which powder is deposited and sintered. The print bed piston moves the print bed to the correct position for each layer during a print.
Front handleSilicone handle for loading and unloading the build chamber.Front handle
Side handlesSilicone handles on each side for moving the build chamber.Side handles
Plug holsterA retainer to keep the plug secure when moving or storing the build chamber. Plug holster
Build chamber latchSecures the build chamber. Build chamber latch
Build chamber plugMain connector for the build chamber’s heaters and temperature sensors.Build chamber plug
Build chamber socketConnects the build chamber’s plug.Build chamber socket
Recinto de impresión
Print enclosureHouses the build chamber and optics system for printing.Print enclosure
Recoater rollerA bar that moves from left-to-right to pick up powder from either side of the upper print enclosure, then deposits it as a layer on the print bed or the previous layer.Recoater roller
Powder troughsTwo powder troughs run along the sides of the print enclosure above the build chamber. The recoater roller deposits powder from the troughs as a layer on the print bed or the previous layer.Powder troughs
FlippersTwo paddles, one on the left and right side of the powder handling system, that move powder into position for the recoater roller to pick-up and deposit onto the print bed. Flippers
Quartz heatersA heating system consisting of a tungsten element sealed inside quartz tubes that emits infrared radiation to heat the print enclosure during a print.
InterlockA safety mechanism that automatically shuts off the laser if the print enclosure door is open, or if the IR sensor is misaligned.Interlock
Sistema óptico
LaserThe laser is the source of sintering energy in the Fuse 1 with a wavelength of 1065 nm, and a maximum output of 10 W. The Fuse 1 is a Class 1 laser product.
Galvanometer (galvo)A high-speed precision motor that positions a mirror used for reflecting the laser spot. The Fuse 1 uses two galvos to position the laser spot along the X and Y-axes of the print area.Galvanometer
Cassette óptico
Optical cassetteA cassette that contains two glass windows—one for the printer's laser and the other for the printer’s camera—a set of corresponding gaskets, and a pass-through for the IR sensor. The windows protect the components behind them from excess wear and off-gassing that results from sintering powder.
Cassette trayHolds the optical cassette in place. To open the cassette tray, loosen the thumb screw on the ceiling of the print enclosure.Cassette tray
Tray catchTwo hooks that align the optical cassette to the cassette tray.Tray catch
Laser window Protects the laser during printing.Laser window
Laser window gasketSeals the top of the laser window from the print enclosure.Laser window gasket
Camera windowProtects the camera lens during printing.Camera window
Camera window gasketSeals the camera window from the print enclosure.Camera window gasket
Cartucho de polvo
Powder cartridgeThe container in which SLS powder is mixed and transported to from the Fuse Sift to the printer’s hopper.
Cartridge wingsTwo brackets for locking the cartridge to the mixer.Cartridge wings
Cartridge valveThe primary opening for filling and depositing powder.Cartridge valve
Valve knifeUsed to close and open the cartridge valve.Valve knife
Cartridge handlesFor holding and lifting the cartridge.Cartridge handles
