Resin tank lifetime and monitoring (Form 3/Form 3B)
Resin tanks are consumables and require replacement. The lifetime of an individual resin tank depends on a combination of factors:
  • Time exposed to resin (i.e., the amount of time that a tank is holding resin, regardless of where the tank is stored)
  • Time spent printing
  • Resin
  • Model geometry
  • Temperature
  • Physical damage
We recommend that you replace a Form 3/Form 3B resin tank as soon as one of the following occurs:
  1. Noticeable physical damage (can occur anytime, but expected by 600–800 hours of printing)
    • Wear on the film begins to affect print quality
      • Repeatedly printing the same model in the same location on a tank can cause the tank film to wear more quickly.
    • Punctures, cuts, wrinkles, or gouges in the film
  2. Your tank reaches its maximum lifetime (shown in the table below)
    • Some resin formulations degrade components of the resin tank over time. This will eventually cause the tank to leak resin. To prevent this from happening, replace your resin tank once you reach the maximum lifetime shown below even if your resin tank is otherwise physically undamaged. Your Form 3/Form 3B warns you when your tank is nearing this recommended lifetime.
Aviso:
Reemplaza tu tanque de resina si ha sufrido un daño físico (se espera que ocurra en torno a las 600-800 horas de impresión, para la mayoría de las aplicaciones) o si alcanza su vida útil máxima (dada en la tabla de abajo), lo que ocurra primero. Realizar una producción de grandes cantidades de piezas puede acortar la vida útil máxima de un tanque de resina. Pueden producirse otros fallos de impresión en cualquier momento, no relacionados con la vida útil del tanque.
Resin groupResinForm 3/3B Resin Tank V1Form 3/3B Resin Tank V2Form 3/3B Resin Tank V2.1
AggressiveTough 2000 Resin
Elastic 50A Resin V1
Rigid 4000 Resin
Grey Pro Resin
Rigid 10K Resin
ESD Resin
Not compatibleCompatible
Maximum lifetime: 10 weeks (75 days) exposed to resin or 250 hours of printing, whichever occurs first
PU Rigid 650 Resin
PU Rigid 1000 Resin
Not compatibleNot compatibleCompatible
Moderately aggressiveDraft Resin V2
Elastic 50A Resin V2
Flexible 80A Resin
Model Resin V3
Dental LT Clear Resin V2
BioMed Black Resin
BioMed Clear Resin
BioMed White Resin
Dental LT Comfort Resin
BioMed Durable Resin
BioMed Elastic 50A Resin
BioMed Flex 80A Resin
IBT Flex Resin
Premium Teeth Resin
Compatible
Maximum lifetime: 35 weeks (250 days) exposed to resin or 600 hours of printing, whichever occurs first
Not aggressiveAlumina 4N Resin
Castable Wax 40 Resin
IBT Resin
No maximum lifetime. Estimated lifetime for most applications: 600–800 hours of printing. Actual lifetime will depend on the accumulation of physical damage to the tank films.
All other resinsCompatible
Supervisión de la vida útil del tanque de resina
Form 3/Form 3B printers have software features to monitor how close a resin tank is to the end of its maximum lifetime. When a resin tank reaches certain levels of remaining lifetime, the printer will display a warning message when starting a print.
ColorVida útil restanteComportamiento de la impresora
Verde100 %–25 %La impresora no mostrará ninguna advertencia
Amarillo25 %La impresora mostrará una advertencia al iniciar una impresión:
El tanque está llegando al final de su vida útil recomendada y podría empezar a tener fugas en las siguientes impresiones.
Rojo0 %La impresora mostrará una advertencia cuando inicies una impresión:
El tanque ha llegado al final de su vida útil recomendada y podría empezar a presentar fugas que dañen la impresora. Te recomendamos desechar este tanque inmediatamente.
Consulta de la vida útil restante
Para consultar la vida útil restante de un tanque de resina:
  1. Pulsa el icono de la impresora en la pantalla táctil de la impresora. Aparecerá el estado actual de la impresora.
  2. Toca la sección de la pantalla táctil etiquetada con el tipo de tanque para ir a la pantalla de Tank Details (Información del tanque).
  3. La pantalla de Tank Details (Información del tanque) te informará de la vida útil restante de tu tanque de resina.
Remaining Form 3 resin tank lifetime
Tanques de resina con una vida útil incorrecta
Los cálculos de la vida útil de un tanque de resina se basan en el momento en que se utilizó por primera vez. En algunos casos excepcionales, la impresora puede informar de que un tanque sin usar se utilizó por primera vez en 1970 y ya ha llegado al final de su vida útil. Para resolver este problema:
  1. Actualiza el firmware de tu impresora a su versión más reciente. La versión 1.18.3 del firmware de la Form 3 y la versión 1.9.9 del firmware de la Form 3L, ambas lanzadas el 16 de marzo de 2022, contienen actualizaciones destinadas a resolver este problema.
  2. Realiza una impresión con el tanque afectado. Esto debería restablecer la vida útil del tanque en función de su primer uso real.
Si la vida útil del tanque de resina sigue siendo incorrecta, prepara tu impresora para la resolución de problemas a distancia activando las funciones Remote Assistance (Asistencia remota) y Dashboard Logging (Inicio de sesión en Dashboard) y, a continuación, ponte en contacto con el servicio de asistencia de Formlabs o con tu revendedor autorizado.
