FROM PRINTED TO POLISHED IN 60 MINUTES
Fuse Sift + Fuse Blast
Fuse Sift with glovebox
Fuse Sift
Compact and efficient powder management station.
Fuse Blast
Fuse Blast
Fully automated cleaning and polishing solution.
The Fuse Workflow
The Fuse ecosystem is enabling fast and affordable SLS 3D printing of industrial-grade parts and reinventing SLS post-processing to go from printed to finished parts in as little as 15 minutes and consumer-ready parts in under 60 minutes with an efficient, hands-off workflow.
Watch the Product Demo
Fast, Automated Post-Processing
Fuse Sift filters, measures, mixes, and stores powder for you, while Fuse Blast delivers 100% hands-off part cleaning and polishing.
PRINT
Same-Day Turnaround
laser in SLS 3D printer
Fuse 1+ 30W
Fast and Reliable Printing
Easily set up your printer and achieve fast printing thanks to the 30W laser. Print same-day prototypes and enable small series manufacturing of durable end-use parts in under 24 hours.
See the Fuse 1+ 30W
RECLAIM
5-10 minutes
3D printed parts being depowdered
Fuse Sift
Convenient, Compact Powder Management
Our all-in-one powder management station combines part extraction, powder recovery, storage, and mixing in a single device. Fuse Sift will dispense and mix used and new powder automatically so you can reduce waste and control your powder supply.
FINISH
10-60 minutes
parts being post-processed in Fuse Blast
Fuse Blast
Fully Automated Part Cleaning And Polishing
Fuse Blast is an advanced automated finishing solution for SLS parts that quickly removes powder and consistently delivers professional parts that are clean to the touch. Deliver a smooth, semi-gloss, and dye-ready surface finish with the Fuse Blast Polishing System.
Fuse Sift
Fuse Sift
Reclaiming
Parts are extracted and unsintered powder is collected and sifted to remove debris so it can be reused.
Preparing
New and used powder are automatically measured, mixed with fresh powder, and stored for the next print.
Contact SalesTech Specs
Fast, Simple
Compact, Enclosed System
A Fuse Sift is equipped with an HEPA filter, as well as a negative air pressure system that keeps powder inside, while enabling open access and easy cleanup.
Units
1.0 × 0.6 × 1.5 m
Fuse Sift Dimensions
Manageable
Low Waste
Fuse Sift efficiently collects unsintered powder and filters out debris so it can be reused in the next print. Competitive material recyclability allows you to use up to 80% used powder.
MATERIAL REFRESH RATE
20-50%
Powder Recovery
Automatic Powder Mixing
Fuse Sift will dispense, mix, and store used and new powder automatically so you can reduce waste and control your powder supply easily.
Consistent
Nonstop Printing
Reduce downtime by transferring modular build chambers and powder cartridges between the printer and Fuse Sift for a nonstop, cyclical workflow with minimum downtime — even during cooldown.
build chamber transfer
Fuse Blast
Fuse Blast
Cleaning
Choose between automatic or manual cleaning to deliver professional parts that are clean to the touch.
Polishing
The Fuse Blast Polishing System allows you to take it to another level with customer-ready parts that exhibit a smooth, semi-gloss surface finish.
Powder Recovery
Consumer-Ready Parts
Deliver clean-to-the-touch parts thanks to the in-line ionizer that prevents dust and media from re-settling on your parts and get a smooth, semi-gloss, and dye-ready surface finish with the Fuse Blast Polishing System.
Contact Sales
Fast, Simple
Automated Cleaning
The best option to effortlessly clean parts with Fuse Blast. The 100% hands-off post-processing cleans a full build volume of parts in as little as 10 minutes with pre-programmed routines that take out the guesswork.
Consistent
Saving Time and Costs
Minimize overhead costs thanks to the waste separation system that reduces media saturation and extends media life by four to eight times, while reducing time spent extracting parts on Fuse Sift by 80%.
Manageable
Versatile Manual Modes
Switch between automatic, manual-assisted, or handheld modes to ensure thorough cleaning for any part size or geometry.
Fuse Depowdering Kit
Affordable Depowdering Solution for Low-Volume Production and Multiple Materials
Perfect for low-volume users, this all-in-one manual post-processing kit for SLS is an alternative to Fuse Sift that enables you to easily clean parts and recover and mix the used powder to prepare for the next print, all at an affordable price point. The Fuse Depowdering Kit also enables you to seamlessly switch between materials on Fuse Series printers without requiring you to clean Fuse Sift.
Powder 3D Printer: Fuse 1+ 30W
A New Wave of Independent Manufacturing Starts Now
Rethink product development and take control of your own manufacturing. Configure your Fuse Series setup today.
