Based on this understanding, Stonehouse evaluated dust explosion hazard potential by checking oxidizing atmosphere, credible ignition source, and credible suspension mechanism from Formlabs SLS ecosystem. They evaluated both the equipment and the building that are used to house the process, including the SLS powders, the Fuse Series printer, the Fuse Sift, the powder handling and processing areas, and the facilities’ housekeeping process.
DHA Methodology
Stonehouse experts ran laboratory tests on samples from six Formlabs powders to evaluate the associated explosivity data, including Nylon 12 Powder, Nylon 11 Powder, Nylon 11 CF Powder, Nylon 12 GF Powder, TPU 90A Powder, and a powder in development.
The tests included:
- Screening test (go/no-go) to determine if the particulates are at risk of explosion.
- Measures of the minimum ignition energy and temperatures to initiate a fire.
- Measure of the minimum concentration of suspended dust to cause an explosion (MEC).
Stonehouse conducted an investigation of spaces where combustible dust was present or in use and inspected equipment used in those spaces for processing combustible dust such as the Fuse Printers and post-processing equipment.
DHA Results - Equpiment
Powders Explosibility: Stonehouse evaluated the powders' ignitability properties. The table below summarizes the results of their tests and data interpretation.
