Northwell Health logo
Adaptiiv logoSt. Louis Children's Hospital
Solve big problems with large-scale medical parts
or produce many parts in one print job, so you can accelerate product development or keep production running.
Build Volume
4.6x
Larger build volume compared to Form 4B
Form 4BL
353 x 196 x 350 mm
(13.9 x 7.7 x 13.8 in), 24.2 L
Form 4B
200 x 125 x 210 mm
(7.9 x 4.9 x 8.3 in), 5.2 L
Speed that scales. Same-day turnaround for large prints.
  • 9h56min
    Form 4BL
    QuikBow Arms
    27h6min
    Leading FDM
    16h4min
    Benchmark SLA
    50h18min
    Form 3BL
    Arbutus Medical QuikBow Arms
    QuikBow Arms
  • 7h46min
    Form 4BL
    Spinal Sizing Trials
    43h20min
    Leading FDM
    10h35min
    Benchmark SLA
    68h15min
    Form 3BL
    restor3d Spinal Sizing Trials
  • 11h57min
    Form 4BL
    Scoliotic Rib Cage
    27h25min
    Leading FDM*
    13h5min
    Benchmark SLA*
    92h17min
    Form 3BL
    Axial3D Scoliotic Thorax
    Scoliotic Rib Cage
  • 8h18min
    Form 4BL
    Skulls
    17h28min
    Leading FDM**
    11h8min
    Benchmark SLA**
    47h16min
    Form 3BL
    Skull
    Skulls
  • 2h39min
    Form 4BL
    Ventilator
    13h10min
    Leading FDM
    18h6min
    Benchmark SLA
    21h36min
    Form 3BL
    Ventilator
    Ventilator
* Scaled to 80% to fit
** Reduced number of parts per build
Produce stunning parts that always fit, rivaling injection molding.
Smoothest Surfaces
Lower peel forces, Light Touch Supports, and 46 µm pixel size with pre-tuned anti-aliasing.
Sharpest Details
Highly collimated light and 46 µm pixel size with pre-tuned anti-aliasing for subpixel resolution.
Most Accurate Assemblies
±0.15% XY dimensional tolerances so assemblies always fit.
  • QuikBow® is a sterile-ready, single-use tension bow for skeletal traction in the operating room. It allows trauma centers to use a smaller wire without a Kirschner bow (K-bow).
    QUIKBOW® IS A STERILE-READY, SINGLE-USE TENSION BOW FOR SKELETAL TRACTION IN THE OPERATING ROOM. IT ALLOWS TRAUMA CENTERS TO USE A SMALLER WIRE WITHOUT A KIRSCHNER BOW (K-BOW).
    Smoothest Surfaces
    Sharpest Details
    QuikBow®
    Arbutus Medical
Tackle any problem with our industry-leading materials, including biocompatible options, or Open Material Mode.
BioMed Clear Clear, rigid, biocompatible, sterilizable, transparent
Learn More
Reliability at scale. Large format 3D printing you can depend on.
Formlabs optimization engineers put hundreds of printed parts to the test to ensure each material performs to the most reliable standards, right out of the box.
Learn to print in four simple steps:
  • So intuitive that anyone can learn to print in 15 minutes.
  • 1
    Import your model and prepare your print.
    • Smart auto-orientation
    • Advanced support generation
    • Live printability checks
  • 2
    Load a material and click print.
    • Validated print settings
    • No-hassle cartridge and tanks
    • Automatic resin dispensing
  • 3
    Remove, wash, cure.
    • Quick release part removal*
    • Automatic part cleaning
    • Precision post-curing for peak material properties
    • *Build Platform Flex L is not yet available. Coming soon.
  • 4
    Finish your part.
    • Light touch supports for quick, clean support removal
    • Optional sanding, coating, or painting
Low Force Display™ (LFD)
The Power Behind Form 4BL
The Backlight Unit generates a uniform area projection of an ultra-high power light using 145 LEDs and collimating lenses. It cures resin quickly and precisely, delivering blazing fast print speeds with excellent print quality and accuracy anywhere on the build platform.
Solutions for every stage of the process, from prototyping to commercial product.
Prototyping
Formlabs 3D printers helped PSYONIC create the Ability Hand, an FDA-registered, Medicare-covered, industry-defining upper-limb prosthesis from scratch. In-house printing enables rapid iteration and versatile testing with specialized resins, eliminating the need for costly outsourcing. This accelerates medical device development, saving time and resources while bringing products to market faster and at lower costs.
Prototyping
Prototyping
"With our other 3D printing technologies, producing an anatomical model of a spine would take 20 hours, making it impossible to complete in time for procedure planning. Using Fast Model Resin on Form 4BL, we printed it in just an hour and a half and delivered it the same day. Without that speed, we wouldn’t have been able to respond to the case in time."
Brian Albers,
3D Printing Engineer, St. Louis Children’s Hospital
“Form 4BL is great. We’ve pushed it to its limits and not had any failed prints.”
Allison Sibley,
Product Specialist, Adaptiiv
"Since we're producing surgical-grade equipment, the biocompatibility of the resins is crucial. The ability for prints to start and finish correctly, along with the duration of the prints, can impact patient care if we’re working against a deadline. With Form 4BL, we’ve achieved a 100% success rate on our parts."
Todd Goldstein,
Northwell Health
3D printed spine with scoliosis inside a Form 4BL
3D printed patient-specific surface brachytherapy applicators
Northwell
The Form 4BL Ecosystem
Complete Your 3D Printing Experience
Form Wash L
Form Wash L
Automate Cleaning
Find a Reseller
Form Cure L
Form Cure L
Reliable, Professional Post-Curing
Find a Reseller
