Agrupación de modelos
A partir de la versión 3.43.0 de PreForm para impresoras SLS y de la versión 3.53.0 de PreForm para impresoras SLA, puedes gestionar mejor varios conjuntos de modelos con el agrupamiento de modelos. Los modelos agrupados también pueden beneficiarse de las mismas funciones que los modelos seleccionados a la vez uno a uno, como copiar modelos, eliminarlos o cambiar su visibilidad.
El agrupamiento de modelos puede ser especialmente útil cuando se trabaja con varios conjuntos de modelos que requieren trazabilidad o que se deben gestionar por separado, como los pedidos de empresas de servicios o las impresiones para odontología.
Cómo crear un grupo de modelos
Importing multiple models
When importing a folder of models, the files are automatically grouped together and organized in the Model List. The group is given the same name as the imported folder.
Splitting a multi-body model
If you import a multi-part or multi-body model, you can separate those bodies into discrete models in PreForm. When you do, the separated models are added to a model group:
- Import a multi-part or multi-body model.
- Right-click on the model in the 3D scene or in the Model List. A context menu appears with a list of options.
- Select Separate Bodies. The model is separated into its constituent parts, each of which is added to a new group in the Model List. The group is given the same name as the original model.
- If you had previously added supports to the multi-body model, the supports are removed.
- If the multi-body model was previously oriented such that some of the bodies were positioned above the build platform or print bed, the separated models are lowered such that they are all in contact with the build platform or print bed.
Selecting models in the Model List
You can also group models by selecting them in the Model List.
- Select the models you wish to group and right-click. A context menu appears with a list of options.
- Select Group Models. The models are grouped and given the name "Group X" where X starts at 1 and increments with each group. Double-click the folder’s name to rename the folder.
Cómo separar los modelos
Puedes tener una mezcla de modelos agrupados y no agrupados en tu proyecto de impresión. Para separar modelos, haz clic con el botón derecho en el nombre del grupo o en cualquier modelo dentro del grupo y selecciona Ungroup Models (Desagrupar modelos). Los modelos se separan de la carpeta y se muestran individualmente.
