Form 3L - Large resin 3D printer
Form 3L
A Large Format 3D Printer Compact Enough for the Office and Robust Enough for the Factory Floor
Take control of large-format prototyping and bring your biggest ideas to life with the Form 3L, a cost-effective large scale 3D printer that doesn’t compromise on the details.
Form 3L is now succeeded by Form 4L, our next-generation MSLA 3D printer, which improves upon its foundation in every possible way.
Speed That Scales
Form 4L is powered by our Low Force Display™ (LFD) Print Engine, setting the new industry standard for blazing-fast speed, unmatched reliability and accuracy, and the widest range of performance 3D printing materials. Complete large prints the size of the entire build volume in under 6 hours and solve big problems with big parts.
Form 4L 3D printer
Big Parts, Big Ideas
With a large build volume of 33.5 × 20 × 30 cm (13.2 × 7.9 × 11.8 in),
you can print full-scale bulky prototypes or detailed models.
Outsourcing icon
Stop outsourcing large-scale prints
Work faster with a large format 3D printer that’s versatile enough to bring large scale fabrication in-house.
Large Ideas icon
Life-sized prints for larger-than-life ideas
The Form 3L is large enough to print human-scale models, like a prototype of a helmet that’s ready to try on.
Scale Perfectionism icon
Perfectionism that scales
Two precision Light Processing Units inside this large resin printer achieve consistent accuracy and detail across the entire build platform.
Material
Draft Resin
Print Time
8 hours
Print Cost
$88
Part By
Black Diamond Equipment
Helmet
Black Diamond Equipment is prototyping climbing helmets at 1:1 scale to test for form and fit, producing several iterations per week in-house and reducing costs. Read more about how Black Diamond uses the Form 3L.
Note: print time and cost will vary based on part geometry, material, layout, and orientation.
100,000,000 Parts Printed With Formlabs Technology
Google
Sony
New Balance logo
Ford
Gilette
Harvard University
Intuitive
Efficient icon
Intuitive and efficient
No specialized technicians required. The Form 3L offers automatic resin dispensing, simple print preparation software, and a thoughtfully designed interface.
form 3l large resin 3d printer screen
High-resolution touchscreen interface:
A 5.5” interactive full-color display minimizes error and eliminates the need for constant monitoring.
Automated print setup:
Tested over millions of prints, our free print preparation software, PreForm, automatically suggests optimal orientation, supports, and layout, with the ability to manually refine as needed.
Continuously evolving:
We believe the best products grow better over time, and we’re committed to continually evolving our hardware through software improvements.
Nonstop Printing
Print Around the Clock Icon
Print around the clock
The Form 3L constantly monitors print performance so you can focus on bringing your most creative ideas to life. Integrated sensors help maintain ideal print conditions for nonstop throughput with minimal supervision.
Cloud monitoring:
Remotely monitor and manage your fleet of large format 3D printers with the online Dashboard.
Fast-printing material:
Draft Resin balances detail and speed to save time on bulky prototypes and enable quick iteration.
In-field repairs:
The Light Processing Units, rollers, optics window, and other components can be replaced in-house to ensure 24/7 uptime.
Quality
Part Quality icon
Professional parts
Stop sacrificing on quality for large-format 3D prints. The Form 3L provides the smooth surface finish, fine details, and high-performance properties that resin 3D printing is known for.
25μm
XY Resolution
25 - 300μm
Layer Thickness*
* Available layer thickness settings vary by material. Find the latest information on material and setting availability here.
3D printed sample
Smooth surface finish:
Models printed on the Form 3L resemble polished injection-molded parts and can reach high translucency, for realistic looks-like prototyping.
Consistent precision:
A system of lasers and mirrors ensures uniform print quality, for an XY resolution of 25 microns across the entire build platform.
Advanced materials:
Each Formlabs material comes with optimized print settings to guarantee industry-leading print success and reliability, as well as standout mechanical, thermal, or biocompatible properties.
The Form 3L Workflow in Five Minutes
Get more done and work more efficiently with an end-to-end 3D printing workflow. From printing, to post-processing, each step of the process was designed with efficiency in mind.
Watch the Webinar
Advanced Materials for Industrial-Quality Parts
Bring your parts to life with the most comprehensive library of high-performance materials on the market, developed specifically for Formlabs printers by a team of in-house materials scientists. With simplified material switching and automatic resin dispensing, the Form 3L allows you to walk away and focus on other work once your print job starts.
Total freedom with Developer Platform
Enhance your printer’s versatility with certified third-party materials, customizable print settings, or the ability to experiment with any unvalidated 405 nm photopolymer resin (optional, paid license).
Switch Icon
Switch materials in minutes.
Avoid the hassle and mess of purging materials with our swappable cartridge system, cross-compatible with other Formlabs SLA printers.
Resins icon
Automatic resin dispensing.
Our automated resin system dispenses resin as parts print. The Form 3L holds two cartridges of resin to avoid mid-print interruptions.
Explore All MaterialsLearn More About Open Platform
Available layer thickness settings vary by material. Visit our material settings roadmap for more details.
Large resin 3D printer Form 3L
Part of the Formlabs Ecosystem
Formlabs is known for designing end-to-end additive workflows you’ll be excited to use. The Form 3L brings the Formlabs experience to large format 3D printing.
Compare Formlabs SLA 3D Printers
Printer
Form 3
Form 3L
Build Volume (W × D × H)
20.0 × 12.5 × 21.0 cm
7.9 × 4.9 × 8.3 in
5.25 liters
35.3 x 19.6 x 35.5 cm
13.9 x 7.7 x 14.0 in
24.2 liters
33.5 × 20 × 30 cm
21.4 liters
Technology
Masked Stereolithography (MSLA)
Stereolithography (SLA)
Light Source
Backlight Unit (60 LEDs)
Backlight Unit (145 LEDs)
Two 250 mW lasers
Biocompatible Materials
No (available on Form 4B)
No (available on Form 4BL)
No (available on Form 3BL)
Weight
18.3 kg
40.4 lb
58.5 kg
129 lb
54.4 kg
120 lb
Printer Dimensions (W × D × H)
39.8 × 36.7 × 55.4 cm
15.7 × 14.5 × 21.9 in
66.4 x 52.8 x 79.4 cm
26.1 x 20.8 x 31.3 in
77 × 52 × 74 cm
30.3 × 20.5 × 29.1 in
Built on Low Force Stereolithography (LFS)™ technology for groundbreaking print quality and printer reliability.
