Replacing the Form Cure L V2 turntable motor and coupler
The Form Cure L V2 has a turntable motor that rotates the glass turntable, ensuring that all the surfaces of the part are exposed evenly for adequate curing. A faulty or malfunctioning turntable motor or coupler will not rotate the turntable or run inconsistently, resulting in unevenly-cured parts.
Use this guide to replace the turntable motor and coupler on a Form Cure L V2.
Required Supplies:
  • Replacement turntable motor and coupler
    • 120 V: RP-CU2L-MTR-120-01
    • 230 V: RP-CU2L-MTR-230-01
  • 2.5 mm hex driver (included in the Form 4 or Form 4L tool caddy)
Third-party:
  • 3 mm hex driver
  • Nitrile gloves
  • Anti-static grounding strap
Estimated time: 40 minutes
Danger:
Preparing the workspace
Overview: Prepare the Form Cure L V2 and workspace for replacing the turntable motor and coupler.
Step 1: Prepare the workspace
Clear a workspace around your machine. Ensure that the workspace is well-ventilated and free of dust.
Step 2: Unplug the machine
Turn off the machine using the power switch on the back of the unit. Disconnect the power cable before continuing with maintenance. Do not perform maintenance on the machine while it is connected to power. Wait five minutes after disconnecting the machine from power before proceeding. If the machine was recently in use, the post-cure chamber will be warm. Wait at least 10 minutes for the chamber to cool.
Danger:
Performing maintenance on the machine while it is plugged in increases the risk of electric shock. Never remove the machine's shells while it is plugged in. Never reconnect the machine to power while the shells are uninstalled.
Step 3: Remove the glass turntable
Open the curing chamber door. Gently lift the glass turntable off of the turntable coupler and set it aside.
Step 2: Remove the glass turntable
Step 4: Remove the turntable coupler
Pull the turntable coupler up off of the motor shaft. Set the coupler aside for disposal. Close the curing chamber door.
Step 3: Remove the turntable coupler
Removing the shells
Overview: Remove the rear, side, and bottom shells to access the turntable motor.
Step 1: Remove the rear shell
Rotate the machine so you can access its rear shell. Using a 2.5 mm hex driver, loosen and remove the 14 screws securing the rear shell to the frame of the machine. Set the screws and shell aside.
Step 2: Remove the side shells
Slide the two side shells towards the back of the machine. If they are difficult to remove, use a vice grip with a towel between the jaws to avoid scratching the panel coating.
Step 3: Remove the screws securing the bottom shell
Using a 2.5 mm hex driver, loosen and remove the six screws along the upper edges of the bottom shell. Set the screws aside.
Step 4: Remove the bottom feet
Carefully rotate the Form Cure L V2 so you can access the bottom of the machine. Using a 2.5 mm hex driver, loosen and remove the 12 screws securing the rubber feet to the bottom of the machine. Set the screws and the four feet aside.
Step 5: Remove the screws securing the bottom shell
Using a 2.5 mm hex driver, remove the remaining eight screws securing the bottom shell to the machine. Set the screws aside.
Step 6: Remove the bottom shell
Lift the bottom shell off of the machine and set it aside.
Removing the turntable motor
Overview: Disconnect and remove the original turntable motor.
Step 1: Unscrew the motor mounting screws
Locate the motor, positioned at the middle of the bottom face of the machine. Using a 3 mm hex driver, remove the two screws securing the motor to the machine. Set the screws aside for disposal.
Step 2: Disconnect the motor cable
Follow the wires from the motor and locate the cable connector. Squeeze the locking tab and pull the connectors apart. Do not pull on the wires themselves. If the wire or connector is caught between layers of insulation, carefully move the insulating foam out of the way first.
Installing the replacement turntable motor
Overview: Mount, secure, and connect the new turntable motor.
Step 1: Mount and secure the turntable motor
Insert the motor shaft through the hole in the bottom of the Form Cure L V2. Align the two screw holes in the motor with the corresponding holes in the machine. Thread one motor mounting screw into both of the screw holes, then use a 3 mm hex driver to tighten until snug.
Step 2: Connect the motor cable
Reconnect the motor cable. The cable only fits into its connector in the correct orientation. The locking tab clicks into place when the cable is fully connected.
Reinstalling the shells
Overview: After replacing the turntable motor, reinstall the rear, side, and bottom shells.
Step 1: Mount and partially secure the bottom shell
Place the bottom shell onto the Form Cure L V2. Align the six screw holes along the edges of the shell with the corresponding holes in the insulation panel. Thread one mounting screw into each of the six screw holes, then use a 2.5 mm hex driver to tighten until snug.
Step 2: Reinstall the side shells
Slide the two side shells back into place between the top and bottom shells.
Step 3: Mount and secure the rear shell
Mount the rear shell back onto the machine. Thread one rear shell retention screw into each of the 14 screw holes in the rear shell. Using a 2.5 mm hex driver, tighten the screws until snug.
Step 4: Fully secure the bottom shell
Check that the installed panels sit flush against one another. Thread one bottom shell mounting screw into each of the eight screw holes marked in the image here. Using a 2.5 mm hex driver, tighten the screws until snug.
Step 5: Mount and secure the feet
Place the four feet on the bottom shell, aligning the three screw holes in each foot with the corresponding holes in the shell. Thread one mounting screw into each of the 12 screw holes, then use a 2.5 mm hex driver to tighten until snug.
Finalizing the repair
Overview: After installing the new turntable motor, power on the machine and perform final checks.
Step 1: Install the turntable mount
Carefully rotate the machine to its upright position. Open the curing chamber door and press the new turntable mount onto the motor shaft. The shaft has a D-shaped profile, so the mount should fit snugly on it in one orientation. Close the curing chamber door.
Step 2: Power on the machine
Connect the power cable to the machine and its power supply. Turn on the switch at the back of the machine.
Step 3: Test the repair
Start a post-cure cycle and check that the turntable rotates normally once the machine reaches its target temperature.
