Form 3B+
Form 3B+
An Advanced Desktop 3D Printer Designed for Healthcare
Rapidly print patient-specific parts at the point of care and bring innovative R&D and commercial production in-house with Form 3B+, an advanced 3D printer for healthcare professionals and medical device engineers.
Form 3B+ is compatible with our entire SLA materials library, including biocompatible, sterilizable materials.
Form 3B+ is now succeeded by Form 4B, our next-generation medical 3D printer, which improves upon its foundation in every possible way.
Form 4B 3D printer
The Next Generation of Medical 3D Printing
Form 4B is powered by our Low Force Display™ Print Engine, setting the new industry standard for blazing-fast speed, leading reliability and accuracy, and the widest range of performance 3D printing materials.
Speed That Scales
Powered by the same groundbreaking LFD technology, Form 4BL can complete large prints the size of the entire build volume in under 6 hours with unmatched reliability and accuracy, empowering you to solve big problems with big parts.
Form 4BL 3D printer
Meet the Form 3B+
From First Print to Standard of Care
With a compact footprint, affordable price point, and access to a multitude of high-performance materials, use the Form 3B+ for your first print and add more as you scale.
Precision 3D Prints
Precision 3D Prints
The Form 3B+ is large enough to print several surgical instruments and medical devices. With a compact footprint, nimbly scale capacity as demand increases. Over 70M medical devices were printed on Formlabs SLA printers in 2020 alone.
Medical Workflow
On-Demand Printing
From time-sensitive point of care printing to groundbreaking medical devices, work faster and have full control with a versatile, accessible, and scalable 3D printer on site.
Medical Certificate
Validated Workflows
The Form 3B+ has been validated in FDA-cleared workflows. It is also compatible with a wide range of biocompatible, sterilizable materials manufactured in our FDA-registered, ISO 13485 certified facility.
Form 3B+ is ideal for:
Small and medium parts requiring biocompatibility and sterilization compatibility
Medical device prototypes, jigs, fixtures, molds, and end-use parts
Patient-specific anatomical models and surgical instruments
Visual aids for diagnosis and education
Surgical planning models for diagnostic use in FDA-cleared workflows
Research and development with advanced materials
Note: print time and cost will vary based on part geometry, material, layout, and orientation.
Always on call
clock icon
Always on call
The Form 3B+ works around the clock with minimal supervision. With finely tuned settings that optimize print times, the Form 3B+ helps you meet critical deadlines, even for time-sensitive parts and models for trauma surgery.
250mW
Laser Power
25-300μm
Layer Thickness
Intuitive and efficient
intuitive icon
Seamlessly integrate the Form 3B+ into your existing clinical workflows. With automatic resin dispensing, simple print preparation software, and intuitive accessories like Build Platform 2 with patented Quick Release Technology, the Form 3B+ is designed for efficiency.
Incredible part quality
3D printed samples
Part Quality Icon
The Form 3B+ resolves fine details down to the micron level, critical for printing surgical tools and intricate medical devices, while the smooth surface finish and high accuracy of the Form 3B+ ensure medical devices meet production standards.
25μm
XY Resolution
85μm
Laser Spot Size
Materials for a Wide Array of Applications
Access a library of 40+ materials compatible with the Form 3B+. Our technology has been validated in multiple FDA-cleared workflows and we develop and manufacture our own biocompatible materials in an ISO 13485 certified, FDA-registered facility. Parts can be sterilized using steam, e-beam, gamma, or EtO.
3D printed samples
Ecosystem
Open System to Unlock Innovation in Healthcare
Formlabs Open Platform empowers healthcare professionals to drive groundbreaking advancements. Customizable print settings and the ability to print with any 405nm photopolymer resin on Form 3B+ allow users to unleash unlimited possibilities for medical R&D.
The Form 3B+ Workflow
Get more done and work more efficiently with an end-to-end 3D printing workflow. From printing to post-processing, each step of the process was designed with efficiency in mind.
Design
Design
Prepare your parts for printing with PreForm, our free print preparation software.
Print
Print
Print your parts in just a few clicks on your Formlabs 3D printer.
Wash
Wash
Insert the build platform directly into Form Wash after printing, for a consistent, automatic rinse.
Remove Part
Remove Part
Instantly release parts from the print surface with Build Platform 2 and our patented Quick Release Technology.
Remove Supports
Remove Supports
Enhanced light touch support structures detach from the parts in seconds.
Cure
Cure
Transfer the parts to the Form Cure to maximize material properties and ensure peak dimensional accuracy.
Build Platform 2 with patented Quick Release Technology quickly and easily releases parts from the build platform without tools.
Find a Reseller
Enhanced Light Touch Supports
Decrease post-processing time with our enhanced light touch supports structures that break off easier and cleaner than ever before.
See What’s New
Achieve a Flawless Finish
Streamline your workflow and enhance surface finish with Formlabs’ curated set of Finishing Tools.
Learn More
Part of the Formlabs Ecosystem
Formlabs is known for designing end-to-end additive workflows you’ll be excited to use. The Form 3B+ is trusted by clinical innovators as part of surgical workflows.
Automated Wash and Cure
Deliver strong, ready-to-use parts with less time and effort. Form Wash and Form Cure streamline and automate rinsing and post-curing of prints.
Learn More
Form 3B Post Processing
Explore the Form 3B+
Maximize Your 3D Printer Fleet’s Throughput with 24/7 Production
Reach new levels of productivity with a fully automated fleet of Form 3B+ 3D printers that you can operate from anywhere. Skyrocket your ability to produce high-quality, affordable parts with 24/7 back-to-back production with the Formlabs Automation Ecosystem: Form Auto, Fleet Control, and Resin Pumping System.
AECO Ecosystem
Form 3B+
Join Thousands of Your Peers and Adopt Validated, Accessible, and Versatile Medical 3D Printing Today
Meet critical deadlines in-house without prohibitive costs. Formlabs brings unprecedented reliability, quality, and ease of use, with validated workflows tested by a team of medical experts.
