Tip:
Contact Formlabs Support or your authorized reseller if the spill damages a Formlabs product.
A solvent spill can contaminate sensitive machine components or damage the surrounding area. They can also present a slipping or fire hazard, depending on the solvent you use. If you have a solvent spill, promptly clean and inspect the machine as well as the immediate area to minimize the damage.
Tip:
Required supplies
Keep emergency tools in a known, accessible location. When working with isopropyl alcohol or other flammable chemicals, consider purchasing a flammable solvent cleanup kit.
Supplies:
Cleaning an IPA spill
Spilled IPA presents an immediate fire and health hazard. IPA spills must be cleaned immediately. Use only disposable supplies to clean up an IPA spill to avoid risk of fire.
Danger:
When handling isopropyl alcohol, always consult the safety data sheet (SDS) from the isopropyl alcohol supplier as the primary source of information. Handle isopropyl alcohol with gloves in a well-ventilated area. Keep away from heat, sparks, and open flame. Isopropyl alcohol evaporates rapidly, so keep the wash bucket and bottles closed whenever possible.
Tip:
For extensive IPA spills, consider using a flammable solvent cleanup kit.
To clean an IPA spill:
Cleaning a TPM spill
Spilled TPM does not present an immediate fire or health hazard, but it does leave an oily residue that can be slippery. TPM evaporates very slowly, so the spill won’t dry by itself.
To clean a TPM spill:
Cleaning the Form Wash/Form Wash L
If any solvent spills on the display or knob, promptly clean and inspect the Form Wash/Form Wash L to minimize any cosmetic or functional damage to the device. If you experience a solvent spill that damages the machine, document the problem with photos and clean the unit as well as possible. Contact Formlabs Support or your authorized reseller as soon as possible.
