Danger:
Fire hazard: IPA is flammable. When cleaning the Fast Cure, allow isopropyl alcohol to fully evaporate before starting a post-cure cycle.
Debris or contaminants may collect in the Fast Cure or on the machine’s internal surfaces over time. In order to preserve the reliability of the Fast Cure, it is important to regularly inspect and clean the machine’s various components and assemblies. The standard maintenance cycle for cleaning the Fast Cure is as needed.
Danger:
Warning:
Wear personal protective equipment (PPE) when performing maintenance tasks. Use tools only as described.
Schedule of maintenance
Follow the cleaning schedule to inspect, clean, and maintain your Fast Cure on a regular basis.
| Procedure | Frequency |
| Clean the turntable | Between uses |
| Clean the post-cure chamber | As needed |
| Clean the door | As needed |
| Clean the touchscreen | As needed |
| Replace LEDs | At the end of service lifetime (about 1,500 hours) |
Maintaining the turntable
The Fast Cure relies on the turntable’s rotation to expose part surfaces to even amounts of light and heat. The turntable must have sufficient clearance to rotate.
To maintain the turntable:
Maintaining the post-cure chamber
The post-cure chamber of the Fast Cure reflects the light from the LEDs to ensure that parts post-cure evenly. If the post-cure chamber is damaged or covered in resin, parts may not post-cure properly.
If parts are washed but not fully dry before post-curing, certain washing solvents, such as tripropylene monomethyl ether (TPM), may evaporate and form deposits on the interior surfaces of the Fast Cure. These deposits cloud the reflective coating and prevent parts from post-curing properly.
To maintain the post-cure chamber of the Fast Cure:
Maintaining the door
The Fast Cure door seals the post-cure chamber and contains the UV light from the LEDs. A damaged or dirty door may reduce the effectiveness of the Fast Cure.
To maintain the Fast Cure door:
Maintaining the touchscreen
The LCD capacitive touch user interface displays post-cure cycle information, settings, and error messages. Damage to the touchscreen may prevent you from interacting with the Fast Cure and starting a post-cure cycle.
To maintain the Fast Cure touchscreen:
Replacing the LEDs
The Fast Cure uses three UV LED assemblies to post-cure parts. The LEDs have an estimated lifetime of 1,500 hours. Once the LEDs reach the end of their lifetime, the Fast Cure displays a message to inform you that the LEDs need to be replaced.
If the LEDs are past their lifetime and require replacement, please contact Formlabs Support or your authorized reseller for details on how to replace them.
