Caution:
Do not use compressed air or an air gun to clean the print enclosure, build chamber, or any other component. Mobilizing loose powder increases the risk of unintentional inhalation or ingestion.
Fuse 1 generation printers use an infrared (IR) sensor to monitor temperature changes in the top powder layer. IR sensor data is crucial for print quality, accuracy, and repeatability. Any obstruction or contamination of the sensor can cause print defects.
During nylon sintering, a white powder called laurolactam builds up on components, including the IR sensor housing. To maintain accurate readings, inspect the housing before each new print and clean it if any laurolactam is spotted.
Caution:
Required supplies
Estimated time: 5 minutes
Cleaning the IR sensor housing
If there is laurolactam buildup obstructing the IR sensor, clean it with a swab wetted with ethanol.
