| 0.9.26 Documentation |
- Updated PreFormServer for PreForm release 3.60.3.
July 14, 2026 |
PreFormServer Windows Download
PreFormServer MacOS Download
| 0.9.25 Documentation |
- Updated PreFormServer for PreForm release 3.60.2.
June 23, 2026 |
| 0.9.24 Documentation |
- Updated PreFormServer for PreForm release 3.60.1.
June 10, 2026 |
| 0.9.23 Documentation |
- Updated PreFormServer for PreForm release 3.60.0.
- Memory leak in Scan to Model: Fixed a memory leak in the Scan to Model feature that could cause PreForm (and PreForm Server) to consume increasing amounts of RAM over time when running repeated scan-to-model operations, leading to system instability in high-volume workflows.
June 9, 2026 |
| 0.9.22 Documentation |
- Updated PreFormServer for PreForm release 3.59.1.
- "Separate Bodies" is now available in public release builds.
May 22, 2026 |
| 0.9.21 Documentation |
- Updated PreFormServer for PreForm release 3.59.0.
- Added POST /scene/{scene_id}/thin-wall-detection/ endpoint to detect thin-wall regions in models below a configurable thickness threshold. Returns per-model results including total thin volume, region count, and per-region breakdown (volumes and bounding boxes).
May 12, 2026 |
| 0.9.20 Documentation |
- Updated PreFormServer for PreForm release 3.58.1.
April 23, 2026 |
| 0.9.19 Documentation |
- Updated PreFormServer for PreForm release 3.58.0.
April 15, 2026 |
| 0.9.18 Documentation |
- Updated PreFormServer for PreForm release 3.57.2.
March 31, 2026 |
| 0.9.17 Documentation |
- Updated PreFormServer for PreForm release 3.57.1.
March 24, 2026 |
| 0.9.16 Documentation |
- Updated PreFormServer for PreForm release 3.57.0.
March 18, 2026 |
| 0.9.15 Documentation |
- Updated PreFormServer for PreForm release 3.56.2.
March 5, 2026 |
| 0.9.14 Documentation |
- Updated PreFormServer for PreForm release 3.56.1.
February 26, 2026 |
| 0.9.13 Documentation |
- Updated PreFormServer for PreForm release 3.56.0.
February 24, 2026 |
| 0.9.12 Documentation |
- Updated PreFormServer for PreForm release 3.55.1.
January 28, 2026 |
| 0.9.11 Documentation |
- Updated PreFormServer for PreForm release 3.55.0.
January 13, 2026 |
| 0.9.10 Documentation |
- Updated PreFormServer for PreForm release 3.54.1.
December 9, 2025 |
| 0.9.9 Documentation |
- Updated PreFormServer for PreForm release 3.54.0.
November 18, 2025 |
| 0.9.8 Documentation |
- Updated PreFormServer for PreForm release 3.53.0.
- Fixed a bug where Auto Support did not work with mini raft settings.
October 21, 2025 |
| 0.9.7 Documentation |
- Updated PreFormServer for PreForm release 3.52.1.
- Added delete scene endpoints.
- Added the “enable_smooth_contour_extended_sides” option to the scan to model endpoint.
September 25, 2025 |
| 0.9.6 Documentation |
- Updated PreFormServer to match PreForm 3.51.1 release.
August 29, 2025 |
| 0.9.5 Documentation |
- Updated PreFormServer to match PreForm 3.51.0 release.
August 19, 2025 |
| 0.9.4 Documentation |
- Updated PreFormServer to match PreForm 3.50.2 release.
August 4, 2025 |
| 0.9.3 Documentation |
- Updated PreFormServer to match PreForm 3.50.1 release.
- Fixed issue where printing multiple jobs at the same time may cause layers from different jobs to appear in the same job
- No API changes
July 30, 2025 |
| 0.9.2 Documentation |
- Updated PreFormServer to match PreForm 3.50.0 release.
- Update /scene/{scene_id}/scan-to-model/ endpoint to support new list of files input.
- Fixed bug preventing uploading Fuse 1+ scenes to Dashboard group queues.
- Fixed where custom fps files were not registered on scene creation.
- Fix loading and applying custom print settings when loading .form files
July 22, 2025 |
| 0.9.1 Documentation |
- Updated PreFormServer to match PreForm 3.49.0 release
June 17, 2025 |
| 0.9.0 Documentation |
- Updated PreFormServer to match PreForm 3.48.0 release
- Added support for editing multiple scenes in parallel. Previously, the Formlabs Local API only allowed creating and editing a single scene at a time but now you can create and use API endpoints targeting separate scenes. For example, you can estimate the print time on one scene while importing a model into another scene at the same time.
- API endpoints have been updated to target specific scene IDs.
- API endpoints to modify scenes without a scene ID are still available but are deprecated and will be removed in a future release.
- Added custom_bounds parameter to /scene/{scene_id}/scan-to-model/ endpoint to keep selected models inside in the layout operation.
- Added /scene/pack-and-cage/ endpoint to automatically arrange models in the build volume and create a cage around them.
May 27, 2025 |
| 0.8.14 Documentation |
- Updated PreFormServer to match PreForm 3.47.0 release
- Added /scene/add-drain-holes/ endpoint for adding drain holes to parts
- Added /scene/label/ endpoint to adding labels to parts
- Added support for asynchronous loading and saving .form files
- Added shell and wall thickness parameters to /scene/scan-to-model/ endpoint
April 23, 2025 |
| v0.8.13 Documentation |
- Updated PreFormServer to match PreForm 3.46.1 release
- No changes to API
April 7, 2025 |
- Updated PreFormServer to match PreForm 3.46.0 release
- Added /scene/hollow/ endpoint to hollow models in a scene
- Added /scene/interferences/ endpoint that Returns a list of pairs of IDs of interfering models.
- Allow generating supports on models already on the build platform with the MINI_RAFTS_ON_BP option in the /scene/auto-support/ endpoint
- Fixed incorrectly document return type of /scene/scan-to-model/ endpoint
- Add cutoff_below_gumline_mm option to /scene/scan-to-model/ endpoint
- Support saving .webp images and a flyaround_transform option in the /scene/save-screenshot/ endpoint
- Fixed issue creating biocompatible material scenes for Form 4B printers
March 24, 2025 |
| v0.8.12 Documentation |
- Added new /scan-to-model/ endpoint, encompassing functionality of the “Scan to Model” wizard in the PreForm dental workspace
- /auto-orient/, /auto-support/, /auto-layout/, and /auto-pack/ endpoints can all now be directly called with no further arguments
- Allow saving empty .form files
- /save-screenshot endpoint can now output an animated image flyaround of models
- Added start_or_connect_to_preform_server() pattern to python repo, to allow optionally connecting to a server which is already running
- Update PreFormServer functionality to match PreForm 3.45.1
February 28, 2025 |
| v0.8.11 Documentation |
- Updated PreFormServer to match PreForm 3.44.2 release
- No changes to API
February 17, 2025 |
| v0.8.10 Documentation |
- Updated PreFormServer to match PreForm 3.44.1 release
- No changes to API
February 10, 2025 |
| v0.8.9 Documentation |
- /scene/save-screenshot/ now allows arbitrary angles
- /scene/auto-support/ now has only_minima option to produce PreForm's "Support all minima" functionality
- /scene/auto-layout/ now allows mode: "DENTAL" option to produce results of auto-layout in a dental workspace. In this mode, auto-layout attempts turning the models at finer angles in order to better nest shapes like dental arches
- /scene/estimate-print-time/ now includes a breakdown of pre-print and cooldown times for SLS machines
- formlabs-api-python repo:
- Added full docker instructions for running PreFormServer in a linux docker container running Wine
- Added speedrun.py example for finding settings to produce lower print times and exporting as a .fps file
- Updated PreFormServer to match PreForm 3.44.0 release
January 29, 2025 |
| v0.8.8 Documentation |
- Updated PreFormServer to match PreForm 3.43.2 release
- No changes to API
January 21, 2025 |
| v0.8.7 Documentation |
- Updated PreFormServer to match PreForm 3.43.1 release
- No changes to API
December 18, 2024 |
| v0.8.6 Documentation |
- Updated /list-materials/ endpoint:
- Fixed: don't include biocompatible materials for non-biocompatible printers
- Included build volume dimensions and supported product names for each printer type
- Included description text for each material
- Updated device listing endpoints:
- Included ready_to_print_now property if a printer will start printing newly uploaded jobs immediately
- Added new parameter can_print to filter the list to only devices that can have jobs uploaded to them for printing
- Updated Fleet Control Printer Group information to include queue paused status, list of supported machine types, and the list of printer IDs
- Updated print endpoint to support the optional print_now parameter which can be used to control queueing vs. printing now for printer types that support it
- Added endpoint to upload new firmware to a device
- Added support for making more operations asynchronously: save screenshot, import model, auto orient, auto support, auto layout, auto pack, calculate print validations, estimate print time, discover devices, upload firmware
- Added endpoints to logout and get logged in user information
- Removed the need to whitelist the PreFormServer application on MacOS
- Updated PreFormServer to match PreForm 3.43.0 release
December 10, 2024 |
| v0.8.5 Documentation |
- Update PreFormServer to match PreForm 3.42.1 release
- No changes to API
November 27, 2024 |
| v0.8.3 Documentation |
- Added async support for the print upload endpoint and new endpoints to poll for the progress of the long running operation
- Added support for Print Settings Editor .fps files when creating a scene and updating a scene's properties
- Added endpoint to export a scene's current settings as a .fps file
- Update PreFormServer to match PreForm 3.42.0 release
November 6, 2024 |
| v0.8.2 Documentation |
- Updated PreFormServer to match PreForm 3.41.2 release
- No changes to API
October 31, 2024 |
| v0.8.1 Documentation |
- Updated PreFormServer to match PreForm 3.41.1 release
- No changes to API
October 25, 2024 |
| v0.8.0 Documentation (Beta) |
First release |
October 15, 2024 |
