Improving dimensional accuracy with the Print Settings Editor
When tuning a material with the PreForm Print Settings Editor, accurately setting the scaling factors and Outer Boundary Offset is critical to getting dimensionally-accurate parts.
The Dimensional Accuracy section of the Print Settings Editor has four key parameters:
  • X Correction Factor: a scaling factor that applies in the X direction
  • Y Correction Factor: a scaling factor that applies in the Y direction
  • Z Correction Factor: a scaling factor that applies in the Z direction
  • Outer Boundary Offset: also called OBO, this is a static dimensional shift that applies in the XY plane
Tuning scaling factors and the Outer Boundary Offset
To tune these parameters:
  1. Open the Print Settings Editor. Select the custom print setting you are editing or create a new one.
  2. Set all of the X, Y, and Z Correction Factors to 1. Set the Outer Boundary Offset to 0.
  1. Using your custom print setting, print a part with several different dimensions in X and Y. Shown here is an example print Formlabs uses in testing.
  2. Post-process the print as needed.
  3. Measure various features on the part. Use a micrometer or other high-precision tool to be as consistent and accurate with these measurements as possible.
Scaling and OBO test print
  1. Find the slope and intercept of a line of best fit for your measurement data. An example, with spreadsheet formulas for Google Sheets, is shown below.
NominalX measurementsY measurements
2.52.7892.746
55.2315.234
1010.23010.208
1515.24815.220
2020.29620.208
2525.23725.184
Calculations
 XY
Slope0.99990.9977
Intercept0.2560.246
OBO-0.128-0.123
Average OBO-0.126
  • Slope
    • X: =SLOPE(B2:B7,A2:A7)
    • Y: =SLOPE(C2:C7,A2:A7)
  • Intercept
    • X: =INTERCEPT(B2:B7,A2:A7)
    • Y: =INTERCEPT(C2:C7,A2:A7)
  • OBO
    • X: =-1*B11/2
    • Y: =-1*C11/2
    • Average: =AVERAGE(B12:C12)
  1. Input the calculator slopes as the new X Correction Factor and Y Correction Factor in the Print Settings Editor. Input the average Outer Boundary Offset as the new Outer Boundary Offset in the Print Settings Editor.
    • If you did not initially set the correction factors to 1, multiply the calculated correction factor values by the previous ones.
    • If you did not initially set the Outer Boundary Offset to 0, add the calculated Outer Boundary Offset value to the previous one.
