Powder flammability and combustion of selected Formlabs SLS powders
The properties of combustible dusts are discussed in A Practical Guide to 5 Important Properties of Combustible Dusts:
  • MEC (Minimum Explosible Concentration) is the minimum amount of dust suspended in air that supports an explosion and is usually measured in g/m3.
  • MIE (Minimum Ignition Energy) is the minimum amount of energy required to cause flame propagation when released at a point in a dust cloud.
  • MIT (Minimum Ignition Temperature) is the minimum temperature required to ignite dust and comes in two types:
    • MIT for a dust cloud: the air temperature required to ignite a dust cloud.
    • MIT for a dust layer: the temperature of a surface that will cause dust to ignite.
Additional information is available in the OSHA Technical Manual - Section IV, Chapter 6, Combustible Dusts. For more information about safety with Formlabs SLS products, see our support article on the topic.
Below is a table detailing the combustible properties of selected Formlabs SLS powders.
MaterialMinimum Explosive Concentration (MEC) (g/m3)Minimum Ignition Energy (MIE) (mJ)Minimum Autoignition Temperature (MIT) (°C)Maximum Explosion Pressure (Pmax) (bar-g)Deflagration Index (Kst) (bar*m/s)
Nylon 12 Powder40650430 > MIT < 8056.970
Nylon 11 Powder801000 < MIE460 < MIT < 10004.288
Nylon 12 GF Powder80300 < MIE < 10004406.080
Nylon 11 CF Powder80300 <MIE < 10004806.399
Polypropylene Powder80100 < MIE <3004005.871
TPU 90A Powder100300 < MIE < 10004407.2110
Particle size distribution
Particle size is analyzed using low-angle laser light scattering (LALLS). Particle size distribution is often represented by a mass fraction with key percentile indicators known as D10, D50, and D90.
  • D10: Particles that make up 10% of the total weight of the sample are smaller than this diameter.
  • D50: Particles that make up 50% of the total weight of the sample are smaller than this diameter.
  • D90: Particles that make up 90% of the total weight of the sample are smaller than this diameter.
Particle size distribution data for selected Formlabs SLS powders:
MaterialD10 (µm)D50 (µm)D90 (µm)
Nylon 12 Powder375886
Nylon 11 Powder194375
Nylon 12 GF Powder406090
Nylon 11 CF Powder114078
Polypropylene Powder355575
alttext
