Preparing prints for painting
Required resources
  • Spray primer
  • Sandpaper or flexible sanding strips (220/320, 400/600 grit)
  • Soft toothbrush
  • Tack cloth
  • Drill
  • Dowel
  • Wood block
  • Safety equipment: gloves and mask
  • Flush cutters (optional)
  • Rotary tool or hand file (optional)
Step 1: Remove supports
Use a set of flush cutters or your hands to remove supports.
alt text
Step 2: Sand down support marks
Use a rotary tool, hand file, or 220-grit sandpaper to remove support marks.
alt text
Step 3: Sand the surface
Sand the surface with 220 or 320 grit sandpaper or flexible sanding strips. Follow up with 400 or 600 grit.
alt text
Step 4: Mount the print
Drill a starter hole in an inconspicuous spot and mount your print on a thin dowel. Insert the dowel into the wood block.
alt text
Step 5: Wash the surface
Use a toothbrush and water to wash away dust.
alt text
Step 6: Wipe the surface
Run the tack cloth over the surface using long, gentle strokes.
alt text
Step 7: Mix the primer
Gently swirl the primer for 2 to 3 minutes in a circular motion. Avoid shaking the can to prevent bubbly paint.
alt text
Step 8: Spray the first coat of primer
Spray in short, rapid strokes, 6 to 8 inches away from the part. Start each stroke before the part and end after the part.
alt text
Inspect the first coat for any areas that need additional sanding or filing. If necessary, rework and polish the part with fine sandpaper. After sanding, repeat steps 5 to 6 to clean off dust before respraying.
9. Spray the final coat of primer
Add another thin coat of paint.
alt text
