Required supplies:
- 1.3 mm hex driver (flat-end)
- 2.5 mm hex driver (flat-end)
- #2 Phillips screwdriver
- ESD-safe spudger (recommended) or ESD-safe tweezers
- Hot rework tweezers or other SMD soldering equipment
- Antistatic wristband
- Appropriate personal protective equipment for the powder in use, as defined in the safety data sheet (SDS)
- Loctite 243 or equivalent threadlocker 99% ethanol (anhydrous) or 99% isopropyl alcohol (anhydrous)
- Non-abrasive lint-free wipes
