Required Supplies:
- LPU fan filter
- 2.5 mm hex driver (included in the Form 4 tool caddy)
Third-party:
- Nitrile gloves
The Light Processing Unit (LPU) fan filter prevents dust and debris from contaminating the Form 4 optical system. A dirty filter can cause issues with print quality; replace it to keep printing and to prevent damage to your printer.
Use this guide to replace the Form 4 LPU fan filter.
Estimated time: 15 minutes
Required Supplies:
Third-party:
Preparing the workspace
Overview: Prepare the Form 4 and workspace for replacing the LPU fan filter.
Remove the build platform first to avoid dripping resin onto the Light Processing Unit (LPU).
Step 3: Remove and store the resin tank and mixer
Step 4: Prepare the workspace
Step 5: Clean the printer
Warning:
Open the printer cover and clean any resin pooled on and around the LPU with non-abrasive wipes. Dampen the wipes with isopropyl alcohol if necessary to fully remove the resin.
Danger:
Step 6: Unplug the printer
Danger:
Performing maintenance on the printer while it is plugged in increases the risk of electric shock. Never remove the printer panels while the printer is plugged in. Never reconnect the printer to power while the panels are uninstalled.
Removing the LPU fan filter
Overview: Remove the LPU fan filter from the printer.
Step 1: Remove the left panel retention screws
Use a 2.5 mm hex driver to remove the four screws securing the left panel to the printer. Set the left panel and the screws aside.
Step 2: Locate the LPU fan filter
The LPU fan filter sits in a housing next to the fan and includes a white pull tab on its side to allow for easy removal.
Step 3: Remove the filter
Using the white pull tab, carefully pull the LPU fan filter out of its housing. The LPU fan filter should come out easily. Set the LPU fan filter aside for disposal.
Installing the replacement LPU fan filter
Overview: Install the replacement LPU fan filter.
Step 1: Install the replacement LPU fan filter
Grip the LPU fan filter by its metal frame and insert it into its housing until fully seated. Take care not to touch the filter directly. The LPU fan filter should slide easily into its housing without any resistance.
Step 2: Mount the left panel
Place the left panel on the printer. Ensure that the screw holes in the panel align with those in the printer frame and that it sits flush with the touchscreen assembly and the back of the machine.
Step 3: Install the left panel screws
Use a 2.5 mm hex driver to install the four screws that secure the left panel to the printer. Tighten the screws until snug.
Finalizing the repair
Overview: After installing the new LPU fan filter, power on the printer and perform final checks.
Step 1: Power on the printer
Step 2: Run a test print
Insert any missing consumables and upload and start a print. Perform a small test print to ensure that the printer works normally. Contact Formlabs Support or your authorized reseller to share the results of the procedure.
