Replacing the Form 4 power supply
The Form 4 power supply is located behind the touchscreen assembly and powers the printer. A broken or malfunctioning power supply prevents the printer from functioning.
Use this guide to replace the Form 4 power supply.
Form 4 power supply replacement part
Required Supplies:
  • Power supply
  • 2.5 mm hex driver (included in the Form 4 tool caddy)
Third-party:
  • Phillips screwdriver
  • Nitrile gloves
Estimated time: 45 minutes
Preparing the workspace
Overview: Prepare the Form 4 and workspace for replacing the power supply.
Remove the build platform first to avoid dripping resin onto the Light Processing Unit (LPU).
Step 3: Remove and store the resin tank and mixer
Step 4: Prepare the workspace
Step 5: Clean the printer
Warning:
Open the printer cover and clean any resin pooled on and around the LPU with non-abrasive wipes. Dampen the wipes with isopropyl alcohol if necessary to fully remove the resin.
Danger:
Step 6: Unplug the printer
Danger:
Performing maintenance on the printer while it is plugged in increases the risk of electric shock. Never remove the printer panels while the printer is plugged in. Never reconnect the printer to power while the panels are uninstalled.
Removing the touchscreen assembly
Overview: Remove the touchscreen assembly from the printer to access the power supply.
Step 1: Remove the touchscreen assembly
To remove the touchscreen assembly, follow the instructions in the repair guide Replacing the Form 4 touchscreen assembly. Complete the steps in the section Removing the touchscreen assembly.
Removing the power supply
Overview: After removing the touchscreen assembly, remove the power supply.
Step 1: Open the plastic shroud
Form 4 power supply plastic shroud
Release the five tabs holding the shroud closed. Unfold the top of the shroud.
Step 2: Unplug the output cable
Unplugging the Form 4 power supply output cable
Hold the connector by its plastic housing and gently squeeze the plastic tab to unplug the output cable from the power supply. Do not pull on the individual wires.
Step 3: Remove the input wire mounting screws
Form 4 power supply input wire ring terminals and screws
The input wires attach to the power supply with a ring terminal and screw. Using a Phillips screwdriver, remove each screw securing the ring terminal to the power supply. Set the screws aside. Do not remove the ring terminal from the input wire.
Step 4: Remove the power supply mounting screws
Form 4 power supply mounting screws
Use a 2.5 mm hex driver to remove the four hex screws that secure the power supply to the printer. Set the screws aside.
Step 5: Remove the power supply
Once all the cables are disconnected, gently lift the power supply from the printer. Set the power supply aside for disposal with electronic waste.
Installing the replacement power supply
Overview: Mount and connect the replacement power supply.
Step 1: Position the replacement power supply
Align the replacement power supply with the four screw holes on the printer frame. Take care to place the power supply in the correct orientation.
Step 2: Secure the power supply
Securing Form 4 power supply mounting screws
Thread one hex screw into each screw hole. Using a 2.5 mm hex driver, hand-tighten the four hex screws to secure the power supply to the printer. Tighten the screws until snug.
Step 3: Connect the input wires
Match the correct input wire to the correct screw terminal. The black wire with the – label attaches to the upper screw terminal. The yellow wire with the + label attaches to the lower screw terminal. Thread a screw through the ring terminal into the screw terminal. Using a screwdriver, hand-tighten the two screws to secure the input cables to the power supply. Tighten the screws until snug.
Connecting the Form 4 power supply input wires to screw terminals
Step 4: Connect the output cable
Connect the output cable to the power supply. The connector makes an audible and tactile click when secured.
Connecting the Form 4 power supply output cable
Step 5: Close the plastic shroud
Fold the plastic shroud to cover the power supply. Reinsert the five tabs into the corresponding slots.
Closing the Form 4 power supply plastic shroud
Reinstalling the touchscreen assembly
Overview: After replacing the power supply, reinstall the touchscreen assembly onto the printer.
Step 1: Reinstall the touchscreen assembly
To reinstall the touchscreen assembly, follow the instructions in the repair guide Replacing the Form 4 touchscreen assembly. Complete the steps in the section Installing the replacement touchscreen assembly.
Finalizing the repair
Overview: After replacing the power supply, power on the printer and perform final checks.
Step 1: Power on the printer
Step 2: Run a test print
Insert any missing consumables and run a test print. Check that the print starts normally and the parts print successfully. Contact Formlabs Support or your authorized reseller to share the results of the procedure.
