Replacing the Form 4L Light Processing Unit fan filter
The LPU (Light Processing Unit) fan filter prevents dust and debris from contaminating the Form 4L optical system. A dirty filter can cause issues with print quality; clean or replace it to keep printing and to prevent damage to your printer.
Use this guide to clean or replace the LPU fan filter on the Form 4L.
Required Supplies:
  • Form 4L LPU fan filter (if replacing the filter)
  • 2.5 mm hex driver (included in the Form 4L tool caddy)
Third-party:
  • Vacuum cleaner (if cleaning the filter)
  • Nitrile gloves
Estimated time: 10 minutes
Preparing the workspace
Overview: Prepare the Form 4L and a dust-free workspace for replacing the LPU fan filter
Remove the build platform first to avoid dripping resin onto the Light Processing Unit (LPU).
Step 2: Remove the resin cartridges
Remove the resin cartridges and close the vent caps to prevent resin from dripping off of the bite valves and into the printer.
Step 3: Remove and store the resin tank and mixer
NOTICE:
Step 4: Prepare the workspace
Step 5: Clean the printer
WARNING:
Open the printer cover and clean any resin pooled on and around the LPU with non-abrasive wipes. Dampen the wipes with isopropyl alcohol if necessary to fully remove the resin.
DANGER:
Step 6: Unplug the printer
DANGER:
Performing maintenance on the printer while it is plugged in increases the risk of electric shock. Never remove the printer panels while the printer is plugged in. Never reconnect the printer to power while the panels are uninstalled.
Removing the LPU fan filter
Overview: Access and remove the LPU fan filter.
Step 1: Remove the mesh filter
Remove the mesh filter from the right side of the printer. Set the filter aside.
Step 2: Remove the lower right panel
Use a 2.5 mm hex driver to remove the four screws securing the lower right panel to the printer. Remove the screws and the panel and set them aside.
Step 3: Remove the LPU fan filter
Disengage the fan retainer by pulling downwards and swinging the wire arm towards you. Remove the LPU fan filter by pulling straight down on the filter’s body. Set the filter aside.
Step 4: Vacuum the fan filter (optional)
If you are cleaning the fan filter rather than replacing it, vacuum both sides of the filter until it is clean and free from dust or debris. After cleaning the filter, reinstall it following the steps below.
If you cannot fully clean the contamination or you continue to experience issues related to the filter after cleaning, replace the filter.
Install the replacement LPU fan filter
Overview: Mount and secure the replacement LPU fan filter.
Step 1: Install the replacement filter
Slide the fan filter under the wire filter retainer and push upwards until fully seated. Pull downwards on the filter retainer and swing it beneath the filter to secure the filter in place.
Step 2: Mount and secure the lower right panel
Align the screw holes in the lower right panel with those in the printer frame. Thread one mounting screw into each of the four screw holes. Use a 2.5 mm hex driver to tighten until snug.
Step 3: Reinstall the mesh filter
Place the mesh filter over the grate on the right side of the printer.
Finalizing the repair
Overview: After installing the new LPU fan filter, power on the printer and perform final checks.
Step 1: Power on the printer
Close the printer door and connect the power cable to the printer and the power supply. Turn on the switch at the back of the printer. The printer will turn on and initialize.
Step 2: Run a test print
Insert any missing consumables and upload and start a print. Perform a small test print to ensure that the printer works normally. Contact Formlabs Support or your authorized reseller to share the results of the procedure.
