Updating firmware for Formlabs SLA printers
Formlabs regularly releases updated firmware to fix bugs and improve functionality. Check your printer's firmware to ensure you're always up to date.
Accepting a firmware auto-update
As long as a Formlabs printer has an active internet connection, it receives notification prompts about new firmware updates becoming available upon their release. Accept the prompts and tap Install on the Firmware Update screen to stay up to date.
To check a printer’s current firmware version:
Form 2 Form 3 generation
Form 3L generation
Form 4 generation
Form 4L generation
Tap Settings > Firmware Update. Tap Settings > System > Firmware Update. Tap Settings > Firmware Updates.
The Update Firmware screen is displayed.
Updating firmware
Download the latest firmware version for your Formlabs SLA printer with PreForm, then upload and install the firmware file on the printer. Review the firmware release notes to learn more about the improvements that come with each version's release.
  1. Open the latest version of PreForm.
  2. Connect the printer to the computer via Wi-Fi, USB or wire the printer to an Ethernet network.
  3. Click Edit Job Setup. The Job Setup window opens.
  4. Select the printer you wish to update.
  5. Click Firmware Update in the Job Setup pane. The Firmware Update window opens.
  6. Click Update. PreForm begins to download the latest firmware to your computer.
  7. Follow the onscreen instructions to download the latest firmware and then upload the file to the printer. To upload firmware, the printer must be connected to the computer via Wi-Fi, USB or the printer must be wired to an Ethernet network.
  8. The printer may automatically recognize you have sent a firmware update. Tap Continue on the printer's touchscreen to finish the installation.
  9. If you are not prompted to Continue, you must continue the firmware update manually:
Form 3L generation
Form 4 generation
Form 4L generation
  1. After the firmware update installs, confirm the system restart on the touchscreen or wait 30 seconds for an automatic restart.
Reverting back to an older firmware
Any version of firmware can be uploaded to your printer as long as it is compatible with your printer's model and the version of PreForm you have installed on your computer. To revert back to an older version of firmware:
  1. Check your printer's model type.
  2. Check the version of PreForm you currently have installed by clicking Help > About PreForm from the menu bar.
  3. Select your printer's model from the list in the article Firmware release notes. PreForm compatibility is noted in the "What's New" section when relevant to the release.
  4. Download the firmware version that is compatible with your printer and version of PreForm you have installed.
  5. Update the printer using the recently downloaded firmware.
Note:
Check and ensure that your PreForm and firmware versions are compatible.
Touchscreen freezes during or after firmware update
If the touchscreen freezes during or after the firmware update, perform a power cycle to restart the printer.
To power cycle the printer:
  1. Unplug the printer.
  2. Wait at least 30 seconds to ensure a complete power cycle.
  3. Reconnect the power cable to restart the printer.
Not enough space error
If the printer reports insufficient space to install a firmware update, selectively delete one or more prints from the print queue.
To delete all prints on a printer:
Form 3L generation
Form 4 generation
Form 4L generation
Tap Settings > Storage. Tap Settings > System > Printer Details > Storage. Tap Settings > General > About this printer > Storage.
Manual firmware update
If the printer is unable to complete an automatic firmware update, or displays a decryption failed error, perform a manual firmware update using PreForm.
To perform a manual firmware update via PreForm:
  1. Download the firmware file and save it where it can be easily found.
  3. Open PreForm.
  4. Click Edit Job Setup. The Job Setup window opens.
  5. Select the printer you wish to update.
  6. Click Firmware Update in the Job Setup pane. The Firmware Update window opens.
  7. Click Upload File. A file selection window opens.
  8. Select the recently downloaded firmware file and click Open.
  9. Click Update. PreForm begins to upload the firmware file to your printer.
  10. Tap Continue on the printer's touchscreen to finish the installation.
  11. If you are not prompted to Continue, you must continue the firmware update manually:
Form 3L generation
Form 4 generation
Form 4L generation
