Always consult the safety data sheet (SDS) as the primary source of information to understand safety and handling of Formlabs powders.
After completing a print on a Fuse 1 generation printer, the resulting parts are buried in loose, unsintered powder and need to be extracted once the build chamber has cooled. Use the Fuse Depowdering Kit to remove the unsintered powder from your parts and to combine used powder and fresh powder for future printing.
Depowdering kit components
Using the Fuse Depowdering Kit
Step 1: Remove parts from the build chamber
Step 2: Sift the powder
Note:
Prolonged use of the sieve can cause the mesh to bind over time. Replace the sieve as needed.
Step 3: Recover the powder
The refresh rate is the percentage of new, unused powder used for a print. The table below lists the recommended refresh rate for each powder to optimize print success.
| Printing in air | Printing in nitrogen | |||||||
| Material | recommended refresh rate | grams of new powder to add to cartridge | grams of used powder to add to cartridge | recommended refresh rate | grams of new powder to add to cartridge | grams of used powder to add to cartridge | ||
| Nylon 11 | 50% | 1350 | 1350 | 30% | 810 | 1890 | ||
| Nylon 11 CF | Not recommended | 30% | 630 | 1470 | ||||
| Nylon 12 | 30% | 900 | 2100 | Not recommended | ||||
| Nylon 12 GF | 50–70% | 1275–1785 | 1275–765 | Not recommended | ||||
| Nylon 12 Tough | 20% | 600 | 2400 | Not recommended | ||||
| Nylon 12 White | 50% | 1500 | 1500 | 30% | 900 | 2100 | ||
| TPU 90A | 20% | 420 | 1680 | Not recommended | ||||
Cleaning up workspace
Using the same powder type
If you are using the same powder type, you only have to clean the sifter sieve. It is not necessary to clean the other tools in the kit.
To clean the sieve:
Switching powder types
If you are changing powder types, Formlabs recommends buying one Fuse Depowdering Kit per powder. Alternatively, you can clean the tools and replace the sieve.
Safety resources
Caution:
Warranty and replacement parts
The Fuse Depowdering Kit includes a one-year warranty. For complete details, see the full NA warranty terms or EU warranty terms.
Replacement sieves
