Pre-recovery checklist (Fuse X1)
The Fuse X1 is a machine with moving parts that require regular maintenance to sustain optimal performance. Sintering nylon results in the production of off gases and laurolactam, which collect onto the printer’s various components in the print enclosure and air system. In order to preserve the accuracy and reliability of the Fuse X1, it is important to regularly check and clean several components and assemblies.
Human head (left-hand profile) wearing a mask
Caution:
Do not use compressed air or an air gun to clean the print enclosure, build chamber, or any other component. Mobilizing loose powder increases the risk of unintentional inhalation or ingestion.
Before every print
Before starting each print, be sure to:
  • Insert an empty build unit
  • Check the amount of powder credit left available
  • Fill the hopper
After every print
When a print job has completed, be sure to:
  • Wait 30–50% of the actual build time for the build unit to cool, ideally to 35 ºC (95 °F) or cooler, before unpacking or handling prints
  • Remove the build unit and move it to the Fuse Sift X1 to recover your printed parts
  • Clean both powder troughs and the area around the recoater’s path using a compliant vacuum with static dissipative components
  • Inspect and clean the recoater roller
Further maintenance
For more information about maintenance procedures on the Fuse X1, check the printer's manual.
