Tuning the bed temperature of your Fuse 1 generation printer for improved part yield with Nylon 12 Powder
The print process for Fuse 1 generation printers requires that the material be sintered at a precise temperature, which is measured by the printer’s IR sensor. While most printers maintain this temperature without the need for adjustment, some print defects and issues can be addressed by fine-tuning the print bed temperature.
Formlabs recommends tuning the bed temperature of your printer before printing with Nylon 12 Powder for the first time. Fine-tuning the bed temperature prior to printing your first build results in fewer surface defects on your parts caused by variable printer temperatures. This process is run as a diagnostic print, uploaded through PreForm to the printer. The print contains several parts that need to be cleaned and inspected to determine the necessary temperature offset for your printer. This process should be run on aged powder, refreshed with 30% fresh powder. If you do not have any used powder on hand, age a batch of fresh powder before printing the bed temperature tuning diagnostic tool.
alttext
Impresión de ajuste de la temperatura del lecho en PreForm
Realiza la impresión de ajuste de temperatura del lecho
  1. If you have previously used the printer with an applied offset, reset the printer’s offset to 0 prior to beginning the fine-tuning process. This can be done by following the directions to Set the Bed Temperature Target, and setting the printer offset to 0.
  2. Update PreForm to the latest version.
  3. Download the appropriate FLZ file for your printer from the links below.
  4. Open PreForm and select Job Settings.
  5. In the Job Setup window, make sure the correct printer is selected.
  6. Select Upload Diagnostic Print.
alttext
  1. Upload the file from your computer and start the print.
  2. Load the hopper with 3 kg of powder. Fill the hopper to the 7 L mark.
  3. Allow the print to fully cool per Formlabs recommendations.
Si la impresión falla al principio debido a desgarros en el lecho de impresión, reduce el valor de Bed Temperature Target (Objetivo de temperatura del lecho) en 2 °C y vuelve a intentar la impresión.
Clean parts
Extract parts using the Fuse Sift or the Fuse Depowdering Kit. Excess powder can be sifted with fresh powder and re-used.
Clean parts prior to inspection either using the Fuse Blast or other media blasting solutions. Extract the five plaques with cones. The additional flat plaques in the build create equal cooling and separation between the cone plaques during the print and can be discarded.
alttext
Example of a cleaned cone plaque ready for inspection.
Each plaque lists the temperature offset it was printed with (-2 ºC, -1 ºC, 0 ºC, +1 ºC, +2 ºC). Line the plaques up from -2 ºC to +2 ºC to prepare them for inspection.
Inspecciona las placas
Note:
If the test print fails and not all plaques are completed, complete the inspection using the plaques that printed successfully. The correct offset will be included in the parts that printed successfully.
To determine the appropriate temperature offset for your printer, look for two things:
  • More than one instance but less than six instances of orange peel on a single plaque. This is most visible on the cones.
  • No pitting. This is most visible on the side of the plaque opposite the cones.
Rotate the plaques to inspect the cones from all angles. Orange peel appears as a slightly layered surface on the cones. Pitting appears as a tiny dot on the opposite side of the plaques.
alttext
Orange peel on the cones
alttext
Pitting on the side opposite the cones
After inspecting all five plaques, determine the offset temperature that best matches the above criteria using the temperature offsets listed on the plaques. This offset can then be manually set on the machine.
Note:
The correct offset temperature may lie between two plaques, and the correct offset may be a half degree between the printed plaques (ie. +1.5 ºC).
Establece el objetivo de temperatura del lecho de impresión
El valor de Bed Temperature Target (Objetivo de temperatura del lecho de impresión) se puede ajustar hasta ±5 °C en incrementos de 0,25 °C. Después de completar la impresión de ajuste de la temperatura del lecho, ajusta el valor de Bed Temperature Target (Objetivo de temperatura del lecho) en la impresora para que coincida con la compensación determinada durante la inspección de Ajuste de la temperatura del lecho.
Dos impresoras que funcionen una al lado de la otra pueden requerir diferentes valores de Bed Temperature Target (Objetivo de temperatura del lecho).
Para ajustar el objetivo de temperatura del lecho:
  1. Asegúrate de que la impresora no está realizando un trabajo de impresión y está actualmente en estado Idle (Inactiva). La cama de impresión La temperatura objetivo solo se puede ajustar antes de una impresión, no mientras la impresión está en curso.
  2. Pulsa el icono del engranaje en la pantalla táctil de tu impresora. Aparecerá la pantalla Settings (Ajustes).
  3. Pulsa Calibration (Calibración). Aparecerá la pantalla Calibration (Calibración).
  4. Pulsa
  5. Bed Temperature Target (Objetivo de temperatura del lecho de impresión). Aparecerá una pantalla con información sobre la temperatura objetivo.
  6. Pulsa Next (Siguiente). Aparecerá la pantalla Bed Temperature Target (Objetivo de temperatura del lecho).
alttext
  1. Pulsa + o - para aumentar o disminuir la temperatura Compensación.
  2. Cuando hayas terminado de ajustar la Diferencia de temperatura, pulsa Siguiente. Confirma la nuevo valor de compensación y pulsa Set (Establecer)
