Form Studio Wash+Cure time settings
Aviso:
Consulta siempre la ficha de datos de seguridad (FDS) del proveedor de tu disolvente como fuente primaria de información para el almacenamiento y la manipulación.
The Form Studio Wash+Cure removes uncured resin from the surface of printed parts by simultaneously soaking and moving them in a solvent. The machine can be used with Formlabs Resin Washing Solution, isopropyl alcohol (IPA), or tripropylene glycol monomethyl ether (TPM).
After your parts are washed and dried, swap the wash bucket for the turntable and switch the machine to cure mode. Place the printed parts on the turntable and post-cure them so the resin achieves its optimal mechanical properties.
The table below indicates the recommended times to wash and post-cure parts printed in Formlabs resins using the Form Studio Wash+Cure. Formlabs updates wash settings periodically with new and improved materials. Check for updated wash settings when using a new resin or revised formulation.
Note:
When using TPM, wash your printed parts as you would with IPA. Use longer wash times if necessary—some resins will not absorb TPM or swell as much with exposure to the solvent. Refer to the support article Washing prints with TPM for more information about the TPM wash process and the effect of TPM on resins.
Resin Wash time Post-cure time
Alpha Black Resin V1 5 minutes (or until clean) 5 minutes
Alpha Clear Resin V1 5 minutes (or until clean) 5 minutes
Alpha Fast Resin V1 5 minutes (or until clean) 5 minutes
Alpha Grey Resin V1 5 minutes (or until clean) 5 minutes
Alpha Model Resin V1 5 minutes (or until clean) 5 minutes
Alpha White Resin V1 5 minutes (or until clean) 5 minutes
Flexible 80A Resin V2
5 minutes + 5 minutes (or until clean)
Wash parts printed in Flexible 80A Resin V2 in two cycles, preferably using fresh solvent for the second wash.
Step 1 (optional): Place dry parts in a glass beaker (or other UV-transparent container) and completely submerge the parts in room temperature water. Cure for 5 minutes.
Step 2: Remove parts from water. Cure for 30 minutes.
Tough 1500 Resin V2 (Form Studio 1)
10 minutes (or until clean)
Formlabs does not recommend using Resin Washing Solution to wash parts printed in this resin.
25 minutes
True Cast Resin V1
5 minutes
Dry with compressed air, rinse with fresh solvent, then dry with compressed again.
3 minutes
Cambios respecto al tiempo de lavado recomendado
Consejo:
Sigue estas buenas prácticas para lavar las impresiones y conseguir que las piezas queden lo más limpias posible.
Reciclaje o eliminación del disolvente usado
Consulta los artículos de asistencia Alcohol isopropílico (IPA), Formlabs Resin Washing Solution y Éter monometílico de tripropilenglicol (TPM) para obtener más información sobre la eliminación segura del disolvente usado.
Aviso:
No viertas resina líquida o parcialmente curada en desagües ni la deseches con la basura doméstica. No viertas disolvente que contenga resina disuelta en desagües ni lo deseches con la basura doméstica. Los métodos seguros y apropiados para desechar el disolvente varían según donde te encuentres.
