Uso de las Finishing Tools
Es necesario utilizar soportes para realizar con éxito una impresión SLA. La eliminación de las marcas y protuberancias que dejan los soportes es un paso crucial del proceso de acabado. Las Finishing Tools de Formlabs incluyen suministros básicos para el acabado de las piezas impresas con las impresoras SLA de Formlabs.
Después de la impresión, utiliza las Finishing Tools para eliminar los soportes y las marcas durante el posacabado. Las Finishing Tools son un complemento adicional a los Finish Kit de Formlabs recomendados.
Componentes de las Finishing Tools
Kit de Finishing Tools de Formlabs
Formlabs Finishing Tools help you post-process high-quality finished parts quickly and easily.
  • Ergonomic pen sander: A power tool ideal for sanding flat and gently-curved surfaces to create a uniform surface finish.
  • Rotary tool: A multi-purpose precision power tool for removing support marks, enlarging holes, modifying geometry, and buffing parts to create a uniform surface finish.
  • Rotary tool bit kit: A curated selection of stainless steel bits for grinding, polishing, and buffing support tips.
  • Rotary tool buffing pads: A selection of various grit buffing pads for creating a uniform surface finish after grinding and sanding.
  • Flush cutters: Robust flush cutters for removing support tips.
  • Hobby knife: For precisely removing individual support tips, modifying part geometry, or cutting sandpaper for use with the pen sander. Replacement blades are included.
  • Microfiber cloth: For cleaning dust from sanding and polishing parts.
  • Spray bottle: Fill with isopropyl alcohol (IPA), water, or mineral oil to help remove dust from sanding and to polish surfaces.
  • Silicone work mat: A large silicone mat (16 × 24 in / 40 × 60 cm) for protecting work surfaces when removing supports and finishing parts.
Aviso:
Asegúrate de limpiar todos los derrames de resina líquida con alcohol isopropílico después de su uso.
Especificaciones técnicas de las Finishing Tools
Comprende las especificaciones técnicas de las Finishing Tools de Formlabs.
Lijadora ergonómica en forma de lápiz:
  • Entrada: 100–240 VAC, 50/60 Hz
  • Salida: 12 V, 0,5 A
  • Velocidad: 1000–6000 carreras lineales/min
  • Longitud de carrera: 3 mm
Herramienta giratoria:
  • Salida: 18 V, 1 A
  • Velocidad: 1800–12 500 rpm
Adaptador de alimentación
El adaptador de alimentación viene con el enchufe eléctrico adecuado para tu región.
Para insertar el enchufe eléctrico en el adaptador:
  1. Alinea el enchufe con el hueco del adaptador.
  2. Introduce la pestaña de la parte superior del enchufe en la ranura correspondiente del adaptador.
  3. Presiona el enchufe hasta que encaje en su sitio.
Para quitar el enchufe:
  1. Desliza el pasador del adaptador hacia abajo, alejándolo del enchufe.
  2. Retira el enchufe del adaptador.
Lijadora de lápiz
La lijadora de lápiz viene con una variedad de formas de broca y papel de lija adhesivo.
  1. Broca
  2. Vástago de la broca
  3. Mandril
  4. Selector de velocidad
Imagen de la lijadora de lápiz con anotaciones
Para preparar las brocas:
  1. Recorta un trozo de papel de lija del tamaño adecuado para la broca que elijas.
  2. Despega la lámina protectora del papel de lija.
Papel de lija y broca para la lijadora de lápiz de las Finishing Tools de Formlabs
  1. Adhiere el papel de lija a la cara de la broca.
Lijadora de lápiz de las Finishing Tools con papel de lija adherido
Para insertar una broca en la lijadora de lápiz:
  1. Afloja el portabrocas, pero no lo retires.
Afloja el portabrocas de la lijadora
  1. Desliza el vástago de la broca completamente hasta el interior del portabrocas. Las brocas solo encajan en el portabrocas en determinadas orientaciones.
Introduce la broca en la lijadora de lápiz de las Finishing Tools de Formlabs
  1. Aprieta el portabrocas hasta que quede ajustado.
Aprieta el portabrocas de la lijadora de lápiz de las Finishing Tools de Formlabs
Para utilizar la lijadora de lápiz:
  1. Conecta la lijadora de lápiz a una fuente de alimentación utilizando el adaptador de corriente incluido.
  2. Gira lentamente el dial de velocidad situado en la parte posterior de la lijadora para ajustar la velocidad.
  3. Lija tu pieza impresa, manteniendo un agarre firme en la lijadora de bolígrafo.
  4. Apaga la lijadora de lápiz antes de desenchufarla o cuando no la utilices. Para apagar la lijadora de lápiz, gira el dial de velocidad hacia la broca hasta que haga clic.
Atención:
La lijadora de lápiz puede calentarse tras un uso prolongado. Haz una pausa de 10 minutos cada 30 minutos de uso.
Herramienta rotatoria
La herramienta rotatoria viene con un portabrocas de 2,35 mm preinstalado, un portabrocas de 3 mm y una variedad de brocas.
  1. Broca
  3. Cabezal de sujeción
  4. Pinza de sujeción (dentro del cabezal de sujeción, no se muestra)
  5. Bloqueo del cabezal de sujeción
  6. Selector de velocidad
Herramienta giratoria de las Finishing Tools de Formlabs con anotaciones
  1. Portabrocas
  2. Varias brocas para la herramienta rotatoria
Brocas y boquilla de sujeción de la herramienta giratoria
Para introducir una broca en la herramienta giratoria:
  1. Mantén pulsado el botón situado en la parte frontal de la herramienta giratoria para bloquear el portabrocas. Afloja el portabrocas, pero no lo retires.
Pulsa el botón de la herramienta giratoria para liberarla
  1. Introduce el vástago de la broca aproximadamente 12-25 mm en la boquilla de sujeción. Si la broca no entra fácilmente en la sujeción, es posible que tengas que cambiar de boquilla.
Introduce el vástago de la broca en la herramienta giratoria.
  1. Pulsa y mantén pulsado el botón situado en la parte delantera de la herramienta giratoria para bloquear el portabrocas en su sitio. Aprieta el portabrocas hasta que quede ajustado.
Pulsa el botón y aprieta el portabrocas.
Para cambiar las boquillas de sujeción:
  1. Pulsa y mantén pulsado el botón situado en la parte delantera de la herramienta giratoria para bloquear el portabrocas en su sitio. Afloja y retira el portabrocas.
Pulsa el botón y afloja el portabrocas.
  1. Sujeta la parte delantera de la boquilla y extráela de la herramienta giratoria.
Retira la boquilla de sujeción de la herramienta giratoria.
  1. Introduce completamente la boquilla de sujeción de recambio en la herramienta giratoria.
  2. Enrosca sin apretar el portabrocas en la boquilla de sujeción.
  3. Introduce el vástago de la broca aproximadamente 12-25 mm en la boquilla de sujeción.
Para utilizar la herramienta rotatoria:
  1. Conecta la herramienta rotatoria a una fuente de alimentación mediante el adaptador de corriente incluido.
  2. Gira lentamente la rueda situada en la parte posterior de la herramienta giratoria para ajustar la velocidad.
  3. Lija tu pieza impresa, manteniendo un agarre firme sobre la herramienta giratoria.
  4. Apaga la herramienta giratoria antes de desenchufarla o cuando no la utilices. Para apagar la herramienta giratoria, gira la rueda hacia la parte posterior de la herramienta (marcada como MIN) hasta que haga clic.
Atención:
La herramienta giratoria puede calentarse tras un uso prolongado. Haz una pausa de 10 minutos cada 30 minutos de uso.
Recursos de seguridad
Advertencia:
Orienta las herramientas con bordes afilados en sentido contrario a ti, sobre todo cuando cortes o raspes las piezas. Ten cuidado al utilizar el cuchillo de precisión y la herramienta giratoria, o cuando cambies las puntas de la herramienta giratoria.
Atención:
  • Cuando utilices herramientas eléctricas, lleva siempre gafas de seguridad y una máscara antipolvo.
  • Las herramientas eléctricas pueden calentarse tras un uso prolongado. Haz descansos de 10 minutos cada 30 minutos de uso.
  • Las temperaturas de funcionamiento de las herramientas eléctricas están entre 0 y 40 °C. No las utilices en condiciones si están mojadas o en condiciones de humedad.
  • Mantén las herramientas fuera del alcance de los niños.
  • Asegúrate de que tu superficie de trabajo esté limpia, seca y estable cuando utilices estos productos.
Aviso:
La herramienta giratoria puede dañar las piezas impresas si las RPM son demasiado altas.
Proceso de trabajo de posacabado
  1. Lava y cura tus piezas impresas según las indicaciones para el tipo de resina.
  2. Retira las puntas de los soportes de la pieza impresa con los alicates de corte o el cúter.
  3. Utiliza la lijadora para pulir suavemente cualquier marca o hendidura que sobresalga en la superficie de la pieza.
    Consejo:
    Usa una botella con pulverizador para enjuagar las partes con alcohol isopropílico o agua, o cepilla las impresiones con un cepillo de dientes para quitar el polvo.
  4. Utiliza la herramienta giratoria para eliminar cualquier accidente no deseado de tus piezas impresas. Elige la punta adecuada para la herramienta giratoria con la que obtener el acabado correcto de tu pieza impresa.
  • Utiliza la fresa cilíndrica para cortar las partes no deseadas o crear bordes redondeados.
Fresa cilíndrica vista de cerca
  • Utiliza el mandril dividido para pulir las superficies con papel de lija.
Mandril dividido visto de cerca
  • Utiliza la fresa cónica para eliminar el material no deseado de zonas estrechas.
Fresa cónica vista de cerca
  1. Utiliza los discos de pulido con paño para pulir la pieza hasta conseguir el acabado deseado.
  2. Rocía la pieza con alcohol isopropílico y luego límpiala con un paño de microfibras para eliminar todo el polvo.
  3. Limpia la pieza con un paño de microfibras y unas gotas de aceite mineral. Abrillanta con un paño para dar un brillo mate.
  4. Otra opción es aplicar una capa muy fina de resina sobre la superficie de la pieza. Cura en luz ambiental o en la Form Cure.
Si necesitas más información sobre el posacabado, consulta Eliminación de marcas de soportes.
Garantía y piezas de recambio
Las Finishing Tools de Formlabs incluyen una garantía de un año. Para obtener información completa, consulta los términos de la garantía de Norteamérica o los términos de la garantía de la UE.
Purchase replacement tools and rotary tool bits from David Union:
Recursos de acabado
