Can I dye Formlabs powders?
Adding dye to Formlabs powder is not recommended and may void your warranty. However, Formlabs recommends dyeing parts printed in Nylon 12 White Powder after post-processing to achieve a range of colors.
SLS printed parts on Formlabs Fuse 1+ 30W can be enhanced with color to better fit a specific application. Dyeing is an economical method to impart color to SLS printed parts and components without modifying the parts' mechanical properties. With Nylon 12 White Powder, users of Fuse 1+ 30W can reliably achieve a range of colors, from oranges to pinks, blues, and almost everything in between. Whether color is required for product differentiation, to meet a specific aesthetic standard, or for safety-critical visibility purposes, dyeing is a viable solution.
Learn more about the best practices for dyeing SLS printed parts in the white paper Dyeing SLS 3D Printed Parts: Benefits and Workflow.
