How do I find the serial name of my product?
The serial name is on the back panel of all Formlabs machines in the format AdjectiveAnimal.
Printer serial name on the backpanel of a Form 3
For Formlabs products with a touchscreen display, the serial name is also available through the display.
Device Accessing the serial name
Fuse 1 generation printer
  1. Tap the printer icon on the Home screen. A new screen appears.
  2. The serial name is listed in the top-left corner in the format AdjectiveAnimal.
Form Studio 1
The serial name is listed in the status bar at the top of the touchscreen in the format ColorAdjectiveAnimal.
If your printer has a custom name, that is displayed instead of the serial name. To find the serial name, check the back label or tap Settings > General > About this printer on the touchscreen.
Form 4 generation printer
Form 4L generation printer
The serial name is listed in the status bar at the top of the touchscreen in the format AdjectiveAnimal.
Form 3 generation printer
Form 3L generation printer
Form 2 printer
  1. Tap the printer icon on the home screen. The Your Printer screen appears.
  2. The serial name is listed in the top-right corner in the format AdjectiveAnimal.
Form Wash L
Form Cure L
  1. Return to the Home screen if you are currently viewing a different screen.
Form Wash
Form Cure
  1. Disconnect and reconnect the power cable.
  2. When the Formlabs screen appears, press and hold the knob to display the serial name and firmware version.
Fuse Sift
  1. Tap the wrench icon. The Settings screen appears.
  2. Tap System > Sift Details. The serial name is shown next to the word Serial.
Fuse Blast The serial name is listed in the top-left corner of the screen in the format AdjectiveAnimal.
