Note:
Silicone 40A Resin requires careful print preparation. For best success and part quality, please reference Formlabs design guidelines article.
Release notes from the year 2024 are available to view. To find the most recent versions of PreForm, check the support article PreForm downloads and release notes.
2024 releases
Previous versions of PreForm are available for download, as well as a list of their associated changes.
PreForm 3.43.1 — December 18, 2024
PreForm 3.43.1 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 4L, Form 4BL, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features bug fixes for issues with PreForm 3.43.0 and new Default print settings for Form 4 and Form 4L generation printers.
PreForm 3.43.0 — December 10, 2024
PreForm 3.43.0 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 4L, Form 4BL, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release introduces Model grouping on Fuse 1 generation printers, improves Hollowing, and reduces touch tip size to 0.1 mm on Form 4 and Form 4L generation printers.
PreForm 3.42.1 — November 27, 2024
PreForm 3.42.1 is a recommended update for all Formlabs printers. This release features improved raft label text for Form 4 and Form 4L generation printers, a new Form X materials category, and support for High Temp, Flame Retardant, ESD, Clear Cast, and Tough 2000 Resin on Form 4L generation printers.
PreForm 3.42.0 — November 6, 2024
PreForm 3.42.0 is a recommended update for all Formlabs printers. This release features added support for the Timelapse feature on Form 4L generation printers, improved part texturing performance and part hollowing, and updated Default print settings for Flame Retardant Resin on Form 4 generation printers.
PreForm 3.41.2 — October 31, 2024
PreForm 3.41.2 is a recommended update for all Formlabs printers. This release features an updated Scan to Model workflow in Dental Workspace, restored support for Windows 7, and various new print settings for Form 3L, Form 3BL, and Form 4L generation printers.
PreForm 3.41.1 — October 25, 2024
PreForm 3.41.1 is a recommended update for all Formlabs printers. This release features a bug fix for an issue with Nylon 12 Powder v5.1 Speed Optimized Print Settings on Fuse 1+ 30W printers, and a fix for a crash that would occur when communicating with Form 4 or Form 4L generation printers over a network.
PreForm 3.41.0 — October 15, 2024
PreForm 3.41.0 is a recommended update for all Formlabs printers. This release features added support for Form 4L materials, introduces Formlab API, adds model label and texture editing in PreForm, and various new materials for Formlabs printers.
PreForm 3.40.3 — October 7, 2024
PreForm 3.40.3 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features a bug fix for where PreForm was generating excessive supports on Form 3 and Form 4 generation printers.
PreForm 3.40.2 — October 1, 2024
PreForm 3.40.2 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features a bug fix for an issue where PreForm would crash on startup and added support for Silicone 40A Resin with 100 micron print settings on Form 4 generation printers.
Note:
PreForm 3.40.1 — September 17, 2024
PreForm 3.40.1 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features bug fixes causing false debris detefction with viscous resins on Form 4 generation printers, and updated Speed Optimized print settings for Nylon 12 Powder on Fuse 1+ 30 W printers.
Note:
Form 4 generation printers require an update to firmware version 1.7.2 or later.
PreForm 3.40.0— September, 12 2024
PreForm 3.40.0 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release introduces Formlabs Certified Materials that let you print with a curated selection of premium certified third-party materials with validated print settings on Form 4 and Form 4B printers. Additional updates include an added Print Report for SLS printers and the launch of Formlabs Clear Cast Resin for investment casting applications.
PreForm 3.39.2— September, 3 2024
PreForm 3.39.2 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features new Fast Arch print settings and a bug fix for false positive debris detection for Fast Model Resin on Form 4 generation printers.
PreForm 3.39.1— August, 29 2024
PreForm 3.39.1 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features improved debris detection on Form 4 and Form 4B printers, and new Default print settings for Preium Teeth Resin for Form 4B printers.
PreForm 3.39.0 — August, 13 2024
PreForm 3.39.0 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features the ability to view the camera feed from Form 4 generation printers, cup mitigration improvements, bug fixes for issues with manual supports, and improvements to the Model Powder parameter for SLS printers.
New features:
Improvements:
Bug fixes:
Print settings updates:
PreForm 3.38.1 — August 1, 2024
PreForm 3.38.1 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features added support for Open Material Model for Form 4 and Form 4B printers, improved cup artifact migration on Form 4, Form 4B, Form 3L, Form 3BL, Form 3/3+, and Form 3B/3B+ printers, and a bug fix affecting Dental Workspace for Form 2 printers.
PreForm 3.38.0 — July 24, 2024
PreForm 3.38.0 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features improvements to the Job Setup card, the ability to rotate parts in 15° by holding down the Shift key, bug fixes for the auto-orientation feature in Dental Workspace, and new print settings for Form 4 and Form 4B printers.
For more information about PreForm 3.38.0, click here.
PreForm 3.37.5 — July 3, 2024
PreForm 3.37.5 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features new Default print settings for Tough 2000 on Form 4 and Form 4B printers.
| Product | What's New |
| Fuse 1 |
| Fuse 1+ |
| Form 4B |
| Form 4 |
| Form 3BL |
| Form 3L |
| Form 3B/Form 3B+ |
| Form 3/Form 3+ |
| Form 2 |
PreForm 3.37.4 — June 27, 2024
PreForm 3.37.4 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features new Beta print settings for Nylon 11 Powder on Fuse 1+ printers and introduces new Default print settings for Form 4 and Form 4B printers.
| Fuse 1 |
| Fuse 1+ |
| Form 4B |
| Form 4 |
| Form 3BL |
| Form 3L |
| Form 3B/Form 3B+ |
| Form 3/Form 3+ |
| Form 2 |
PreForm 3.37.3 — June 20, 2024
PreForm 3.37.3 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features new Default settings for Form 4 and Form 4B printers, and a bug fix for Form 3L, Form 3BL, Form 3B/3B+, and Form 3/3+ printers for when some print settings were not applied to jobs in Fleet Control.
| Fuse 1 |
| Fuse 1+ |
| Form 4B |
| Form 4 |
| Form 3BL |
| Form 3L |
| Form 3B/Form 3B+ |
| Form 3/Form 3+ |
| Form 2 |
PreForm 3.37.2 — June 11, 2024
PreForm 3.37.2 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features improved slicing performance for jobs with complex lattice structures when printing with TPU 90A Powder on Fuse 1 and Fuse 1+ printers, and a bug fix for v2.0 Speed Optimized Print Settings for TPU 90A Powder on Fuse 1+ printers.
| Fuse 1 |
| Fuse 1+ |
| Form 4B |
| Form 4 |
| Form 3BL |
| Form 3L |
| Form 3B/Form 3B+ |
| Form 3/Form 3+ |
| Form 2 |
PreForm 3.37.1 — June 10, 2024
PreForm 3.37.1 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release introduces support for the Open Material License for LFS printers, new Speed Optimized Print Settings for TPU 90A Powder on Fuse 1+ printers, and new Default Print Settings for Form 4 and Form 4B printers.
| Fuse 1 |
| Fuse 1+ |
| Form 4B |
| Form 4 |
| Form 3BL |
| Form 3L |
| Form 3B/Form 3B+ |
| Form 3/Form 3+ |
| Form 2 |
PreForm 3.37.0 — June 3, 2024
PreForm 3.37.0 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features improvements to Nylon 12 v4.0 Print Settings for Fuse 1+ printers, added support for Form 4 and Form 4B printers to use the Print Settings Editor, and various bug fixes.
| Fuse 1 |
| Fuse 1+ |
| Form 4B |
| Form 4 |
| Form 3BL |
| Form 3L |
| Form 3B/Form 3B+ |
| Form 3/Form 3+ |
| Form 2 |
PreForm 3.36.3 — May 22, 2024
PreForm 3.36.3 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features new Default Print Settings for Form 4 and Form 4B printers, and improvements to their starting print temperatures.
| Fuse 1 |
| Fuse 1+ |
| Form 4B |
| Form 4 |
| Form 3BL |
| Form 3L |
| Form 3B/Form 3B+ |
| Form 3/Form 3+ |
| Form 2 |
PreForm 3.36.2 — May 16, 2024
PreForm 3.36.2 is a recommended update for Fuse 1, Fuse 1+ 30W, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This PreForm update adds support for printing new materials on Form 4/Form 4B and improvements to printing some existing materials on Form 4/Form 4B.
| Form 4B |
| Form 4 |
| Fuse 1 |
| Fuse 1+ |
| Form 3BL |
| Form 3L |
| Form 3B/Form 3B+ |
| Form 3/Form 3+ |
| Form 2 |
PreForm 3.36.1 — May 9, 2024
PreForm 3.36.1 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features new Default Print Settings for Form 4 and Form 4B printers, and various bug fixes.
| Fuse 1 |
| Fuse 1+ |
| Form 4B |
| Form 4 |
| Form 3BL |
| Form 3L |
| Form 3B/Form 3B+ |
| Form 3/Form 3+ |
| Form 2 |
PreForm 3.36.0 — April 30, 2024
PreForm 3.36.0 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release introduces improvements for Form 4 and Form 4B printers: added support for generating timelapse videos, improved print job generaton times, reduced motor noises at the start of prints, and the ability to send print jobs remotely to Dashboard from anywhere.
| Fuse 1 |
| Fuse 1+ |
| Form 4B |
| Form 4 |
| Form 3BL |
| Form 3L |
| Form 3B/Form 3B+ |
| Form 3/Form 3+ |
| Form 2 |
PreForm 3.35.0 — April 17, 2024
PreForm 3.35.0 is a recommended update for Fuse 1, Fuse 1+, Form 3BL, Form 3L, Form 4B, Form 4, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features added support for Form 4 and Form 4B printers, reduced print time calculations for Fuse 1 and Fuse 1+ 30W printers, and also introduces support for the Form Wash (2nd Generation) in the FormWashCureUpdater package.
| Fuse 1 |
| Fuse 1+ |
| Form 4B |
| Form 4 |
| Form 3BL |
| Form 3L |
| Form 3B/Form 3B+ |
| Form 3/Form 3+ |
| Form 2 |
PreForm 3.34.3 — March 28, 2024
PreForm 3.34.3 is a recommended update for Fuse 1, Fuse 1+, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features updated Fuse 1+ Nylon 12 Print Settings.
| Fuse 1 |
| Fuse 1+ |
| Form 3BL |
| Form 3L |
| Form 3B/Form 3B+ |
| Form 3/Form 3+ |
| Form 2 |
PreForm 3.34.2 — February 22, 2024
PreForm 3.34.2 is a recommended update for Fuse 1, Fuse 1+, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release added support for Elastic 50A Resin V2 and fixed a bug related to the build height increases (from PreForm version 3.34.0) on Form 3B, Form 3B+, and Form 3BL printers.
| Fuse 1 |
| Fuse 1+ |
| Form 3BL |
| Form 3L |
| Form 3B/Form 3B+ |
| Form 3/Form 3+ |
| Form 2 |
PreForm 3.34.1 — February 13, 2024
PreForm 3.34.1 is a recommended update for Fuse 1, Fuse 1+, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release fixed a bug that caused print failures when printing with Polypropylene Powder on the Fuse 1+.
| Fuse 1 |
| Fuse 1+ |
| Form 3BL |
| Form 3L |
| Form 3B/Form 3B+ |
| Form 3/Form 3+ |
| Form 2 |
PreForm 3.34.0 — February 5, 2024
PreForm 3.34.0 is a recommended update for Fuse 1, Fuse 1+, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features reduced file upload and print times when printing with Nylon 12 on the Fuse 1+, added support for taller parts on Form 3 and Form 3L printers, and updates to the manipulator to improve model rotation in the 3D scene.
| Fuse 1 |
| Fuse 1+ |
| Form 3BL |
| Form 3L |
| Form 3B/Form 3B+ |
| Form 3/Form 3+ |
| Form 2 |
PreForm 3.33.3 — January 18, 2024
PreForm 3.33.3 is a recommended update for Fuse 1, Fuse 1+, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features added support for Polypropylene Powder on Fuse 1+ 30W printers, added support for Premium Teeth Resin on Form 3B printers, and promoted Beta Fast Arch Print Settings to Default Fast Arch Print Settings for Grey V4 Resin and Draft Resin at 100 microns on the Form 3 and Form 3B.
| Fuse 1 |
| Fuse 1+ |
| Form 3BL |
| Form 3L |
| Form 3B/Form 3B+ |
| Form 3/Form 3+ |
| Form 2 |
PreForm 3.33.2 — January 9, 2024
PreForm 3.33.2 is a recommended update for Fuse 1, Fuse 1+, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release introduces automatic updates for PreForm (Windows only) and various bug fixes for all printers.
| Fuse 1 |
| Fuse 1+ |
| Form 3BL |
| Form 3L |
| Form 3B/Form 3B+ |
| Form 3/Form 3+ |
| Form 2 |
Older versions
PreForm versions that released before 2024 can be found in the following archives:
