Printing with the Form 4L Flex Build Platform
The Form 4L Flex Build Platform enables a quick and controlled release of printed parts from the build platform, allowing for an easier and more reliable post-processing workflow.
The Form 4L Flex Build Platform is made of two components: the build platform body and the flexible print surface. The print surface is attached to the build platform body with magnets positioned within the alignment channels and throughout the top surface of the build platform body. The print surface bends when you push the part release tabs inwards, causing printed parts to release for easier post-processing.
When using the Form 4L Flex Build Platform, make sure that both the build platform and your models are properly prepared before printing. Ensure that the build platform is clean and properly assembled. Certain part orientations and support options release more easily from the build platform than others, so set up your print with this in mind.
For the best print results:
  • Ensure the flexible print surface is clean and properly aligned
  • Orient models parallel to the short end of the build platform
  • Overlap rafts on small prints
  • Avoid mini-rafts
Printing with Formlabs resins
  • The Form 4L Flex Build Platform is approved for use with Formlabs resins for biocompatible applications. Always follow the Instructions for Use when using Formlabs resins to produce biocompatible parts. For full compliance with biocompatibility requirements, the Form 4L Flex Build Platform should not be used with any other resins.
  • The Form 4L Flex Build Platform is not compatible with Durable Resin, Flexible 80A Resin, and Elastic 50A Resin. Use the standard build platform for these resins.
  • If you experience issues with print reliability, fine-tune the Z-axis of your printer.
Inspecting the print surface
Before printing with the Form 4L Flex Build Platform:
  1. Inspect the build platform and make sure that it is clean and dry.
  2. Check that the flexible print surface is flat and properly aligned with the build platform body.
  3. Actuate the part release tabs closest to you and check that the two alignment rods are fully seated in their respective alignment channels.
Printing with an improperly assembled Form 4L Flex Build Platform can damage the build platform, your resin tank, or your printer.
Preparing your models in PreForm
Orient models perpendicular to the front of the build platform
Align the long edge of the models perpendicular to the bend axis of the build platform so that parts are more likely to release. Place models perpendicular to the front of the build scene for easy part removal as the surface flexes.
Parts oriented parallel to the long axis of the Form 4L Flex Build Platform
Parts oriented parallel to the short axis of the Form 4L Flex Build Platform
Overlap support rafts on smaller parts
Overlapping rafts of parts to be printed on a Form 4L Flex Build Platform
Note:
Avoid using mini-rafts with the Form 4L Flex Build Platform. The surface area on mini-rafts is too small to release from the flexible print surface when it bends.
Print parts with large flat surfaces directly on the build platform
Printing parts directly on the build platform can reduce print time and resin consumption, as well as simplifying post-processing steps.
Removing parts from the Form 4L Flex Build Platform
Warning:
Wear gloves when handling printed parts and surfaces that are contaminated with solvent or liquid resin to prevent skin contact.
Caution:
Do not point the flexible print surface of the Form 4L Flex Build Platform toward your face. Flying parts or debris may lead to injury.
The Form 4L Flex Build Platform’s print surface bends, releasing printed parts for post-processing. Released parts may separate entirely from the build platform or remain partially adhered due to liquid resin, allowing them to be removed by hand.
Remove the build platform from the printer and wash the attached parts using your solvent of choice.
For large parts:
  1. After washing, mount the build platform onto the build platform jig with the printed parts facing up.
  2. Gradually push the part release tabs nearest you forwards with your thumbs.
  3. Parts separate from the build platform as the surface bends.
Removing large parts from the Form 4L Flex Build Platform
For smaller parts:
  1. Place the build platform on its side with the printed parts facing away from you.
  2. For better control during part removal, cover the parts with a paper towel to contain them.
  3. Gently press down on the top two part release tabs towards the center of the build platform.
  4. Parts separate from the build platform as the surface bends.
Removing small parts from the Form 4L Flex Build Platform
For large or fragile parts:
  1. Place the Form 4L Flex Build Platform flat on your work surface.
  2. Support the printed part with one hand.
  3. Push one part removal tab at a time to better control the release.
If parts remain on the build platform, use a part removal tool or scraper to manually remove them or pull them off with a gloved hand.
Clean the flexible print surface if you plan to print again with the same resin, or thoroughly clean the entire Form 4L Flex Build Platform to completely remove all traces of resin before printing with a different material.
Store the build platform inside the printer or somewhere out of direct sunlight.
Other removal methods may be effective, depending on your part geometry. Experiment to find the method that works best for your parts and your workflow.
Troubleshooting with the Form 4L Flex Build Platform
Non-adherence
When printing solid rectangular parts, the flexible print surface may flex or decouple due to the internal stresses of the printing process. If this occurs, do not print the part directly on the build platform. Add support rafts to prevent the part from decoupling from the Form 4L Flex Build Platform during the printing process.
Warped parts
Printing large parts directly on the build platform surface near the short edges may cause warping. If this occurs, do not print the part directly on the build platform. Add support rafts and reorient the part to prevent warping.
