Replacing the Form 4L power supply
The Form 4L power supply is located behind the back panel and powers the printer. A broken or malfunctioning power supply prevents the printer from functioning.
Use this guide to replace the Form 4L power supply.
Required Supplies:
  • Power supply
  • 2 mm hex driver (included in the Form 4L tool caddy)
  • 2.5 mm hex driver (included in the Form 4L tool caddy)
Third-party:
  • Nitrile gloves
  • Phillips or flat head screwdriver
Estimated time: 30-40 minutes
Preparing the workspace
Overview: Prepare the Form 4L and a dust-free workspace for replacing the power supply.
Remove the build platform first to avoid dripping resin onto the Light Processing Unit (LPU).
Step 2: Remove the resin cartridges
Remove the resin cartridges and close the vent caps to prevent resin from dripping off of the bite valves and into the printer.
Step 3: Remove and store the resin tank and mixer
NOTICE:
Step 4: Prepare the workspace
Step 5: Clean the printer
WARNING:
Open the printer cover and clean any resin pooled on and around the LPU with non-abrasive wipes. Dampen the wipes with isopropyl alcohol if necessary to fully remove the resin.
DANGER:
Step 6: Unplug the printer
DANGER:
Performing maintenance on the printer while it is plugged in increases the risk of electric shock. Never remove the printer panels while the printer is plugged in. Never reconnect the printer to power while the panels are uninstalled.
Removing the lower rear panel
Overview: Remove the lower rear panel to access the power supply.
Step 1: Unplug the networking cables and Wi-Fi antenna
Disconnect the Ethernet and USB cables from the unit, if they are connected. Unscrew and remove the Wi-Fi antenna.
Step 2: Remove the lower rear panel screws
Use a 2 mm hex driver to remove the eight screws securing the lower rear panel to the printer. Set the screws aside.
Step 3: Remove the lower rear bumper screws
Use a 2.5 mm hex driver to remove the three screws securing the lower rear panel to the bumper. Set the screws aside.
Step 4: Remove the lower rear panel
Pull the lower rear panel directly away from the printer. Set the panel aside.
Removing the power supply
Overview: After removing the lower rear panel, remove the power supply.
Step 1: Remove the power supply assembly screws
Use a 2.5 mm hex driver to remove the three screws that secure the power supply to the printer. Set the screws aside.
Step 2: Gently slide the powder supply assembly out
Hold the power supply assembly by its mounting plate. Tilt the bottom of the power supply away from the printer. Gently slide the power supply assembly out of the printer. Take care while removing as the power supply assembly cables are still attached to the printer. Lay the power supply assembly down with the mounting plate on the workspace.
Step 3: Remove the power supply assembly cable harness screws
Use a 2 mm hex driver to remove the two screws that secure the power supply cable harness to the power supply assembly. Set the screws aside.
Step 4: Remove the power supply screw terminal screws
Using a Phillips or flat head screwdriver, pry off the plastic covers at the screw terminals labelled -V and +V. Set the plastic covers aside. Using a Phillips or flat head screwdriver, remove the five screws securing the cables to the screw terminals. Set the screws aside.
Step 4: Disconnect the power supply ring terminal cables
Disconnect the five ring terminal cables connected to the power supply.
Step 5: Remove the power supply mounting plate screws
Lean the power supply assembly against the printer to access the mounting plate screws. Use a 2.5 mm hex driver to remove the four screws that secure the power supply to the mounting plate. Set the screws aside.
Lift the power supply from the mounting plate. Set the power supply aside for disposal with electronic waste.
Installing the replacement power supply
Overview: After removing the power supply, install the replacement power supply.
Step 1: Align the replacement power supply
Align the replacement power supply with the screw holes in the mounting plate, ensuring that the power supply fans are on the same side as the power switch.
Step 2: Secure the replacement power supply
Thread one screw into each of the four screw holes in the mounting plate and replacement power supply. Use a 2.5 mm hex driver to tighten the screws until finger tight.
Step 3: Reconnect the ring terminal cables to the power supply
With the power supply laying flat on the workspace, slide the open end of the ring terminals under the square washer on their respective screws on the power supply. Ensure the colored cables are in the correct position. Do not pull on the wires.
  • N: Blue cable
  • L: Brown cable
  • Grounded terminal icon: Green and yellow striped cable
  • -V: Black cables
  • +V: Yellow cables
There is space for two ring terminals underneath the -V and +V screw terminals. Stack the two ring terminals for both of the black cables under the -V screw terminal. Stack the two ring terminals for both the yellow cables under the +V screw terminal.
Step 4: Secure the ring terminals to the power supply
Thread a screw through each ring and screw terminal. Use a Phillips or flathead screwdriver to tighten the five screws to secure the ring terminals to the power supply until finger tight. Snap the two plastic covers over the -V and +V screw terminals.
Step 4: Secure the power supply assembly cable harness
Thread one screw into each of the two screw holes in the power supply assembly cable harnesses. Using a 2 mm hex driver, secure the cable harnesses to the power supply.
Step 5: Position the power supply assembly
Slide the top of the power supply assembly underneath the printer frame.
Ensure the cables attached to the power switch and cable harness are fully seated and are not pinched between the power supply assembly and the printer frame.
Angle the top of the power supply assembly towards the printer. Slide the top of the power supply assembly underneath the printer frame. Ensure the cables attached to the power switch and cable harness are fully seated and are not pinched between the power supply assembly and the printer frame.
Step 5: Push the power supply assembly into the printer frame
Gently push the power supply assembly into the printer until the bottom of the mounting plate is flush with the printer frame.
Step 6: Mount and secure the power supply assembly
Mount and secure the power supply assembly.
Thread one mounting screw into each of the three screw holes. Use a 2.5 mm hex driver to tighten until snug.
Reinstalling the lower rear panel
Overview: Reinstall the lower rear panel and the Wi-Fi antenna.
Step 1: Replace the lower rear panel
Place the lower rear panel back onto the printer. Press it towards the front of the printer to ensure that it fully seats in place. There should be no gaps between the lower rear panel and the side or bottom shells.
Step 2: Secure the lower rear panel
  • Use a 2 mm hex driver to secure the eight screws highlighted in red attaching the lower rear panel to the printer.
  • Use a 2.5 mm hex driver to secure the three screws highlighted in yellow attaching the lower rear panel to the bumper.
Step 3: Plug in the networking cables and Wi-Fi antenna
Connect the Ethernet and USB cables to the unit, if needed. Screw in the Wi-Fi antenna.
Finalizing the repair
Overview: After installing the replacement power supply, power on the printer and perform final checks.
Step 1: Power on the printer
Step 2: Run a test print
Insert any missing consumables and run a test print. Check that the print starts normally and the parts print successfully. Contact Formlabs Support or your authorized reseller to share the results of the procedure.
