Supplies:
Formlabs:- Touchscreen assembly
- 2.5 mm hex driver (included in the Form 4L tool caddy)
- 3 mm hex driver (included in the Form 4L tool caddy)
- 7 mm nut driver
- 1.5 mm hex driver
- Nitrile gloves
The Form 4L touchscreen is the primary means of interacting with and controlling the printer. A broken or malfunctioning touchscreen may prevent the printer from being used normally.
Use this guide to replace the Form 4L touchscreen assembly.
Supplies:
Formlabs:Estimated time: 30 minutes
Preparing the workspace
Overview: Prepare the Form 4L and a dust-free workspace for replacing the touchscreen assembly.
Remove the build platform first to avoid dripping resin onto the optical surfaces.
Step 2: Remove the resin cartridges
Remove the resin cartridges and close the vent caps to prevent resin from dripping off of the bite valve and into the printer.
Step 3: Remove and store the resin tank and mixer
Step 4: Prepare the workspace
Step 5: Clean the printer
Warning:
Open the printer cover and clean any resin pooled on and around the LPU with paper towels. Dampen the paper towels with isopropyl alcohol if necessary to fully remove the resin.
Danger:
Step 6: Unplug the printer
Removing the side panels
Overview: Remove the side panels to access the touchscreen assembly.
Step 1: Remove the mesh filter
Remove the mesh filter from the right side of the printer. Set the filter aside.
Step 2: Remove the lower right panel screws
Use a 2.5 mm hex driver to remove the four screws securing the lower right panel to the printer. Set the right panel and the screws aside.
Step 3: Remove the lower left panel screws
Use a 2.5 mm hex driver to remove the four screws securing the lower left panel to the printer. Set the left panel and the screws aside.
Removing the touchscreen assembly
Overview: Remove the front panel to access the touchscreen assembly.
Step 1: Remove the left front panel retention screws
Use a 2.5 mm hex driver to remove the three screws securing the left side of the front panel to the printer. Set the screws aside.
Step 2: Remove the right front panel retention screws
Step 3: Position the printer
With a second person, position the Form 4L near the front edge of the workspace to access the bottom screws.
Step 4: Remove the bottom front panel retention screws
Use a 1.5 mm hex driver to remove the two screws securing the front panel to the bottom of the printer.
Step 5: Reposition the printer
With a second person, position the Form 4L so that there is at least 6 inches (150 mm) of workspace in front of the printer.
Step 6: Remove the front panel
Grip the front panel by its bottom corners. Carefully pull the front panel towards you. Rotate the front panel until its back surface is visible. Do not pull away from the printer until the touchscreen ribbon cable is disconnected. Lay the front panel with the glass face down on a clean, level surface.
Step 7: Disconnect the touchscreen ribbon cable
The touchscreen ribbon cable connects the touchscreen assembly to the motherboard. The motherboard is located on the left side of the printer.
Once the black tabs are properly released, the cable slides out of the connectors with minimal force.
Step 8: Release the ribbon cable clamps
Use a 2.5 mm hex driver to loosen the four screws securing the ribbon cable clamps to the front panel. Do not fully remove the screws. Once the ribbon cable clamps are properly loosened, slide the touchscreen ribbon cable out of the clamps and set it aside for disposal with electronic waste.
Step 9: Remove the touchscreen assmbly nuts
Use a 7 mm nut driver to remove the five nuts securing the touchscreen assembly to the front panel. Set the nuts aside.
Step 10: Remove the touchscreen assembly
Lift the touchscreen assembly from the front panel and set it aside for disposal with electronic waste.
Installing the replacement touchscreen assembly
OVERVIEW: Install the replacement touchscreen assembly.
Step 1: Position the replacement touchscreen assembly for installation
Position the replacement touchscreen assembly on the front panel. The touchscreen assembly will only fit the front panel in the correct orientation. Make sure that the front panel bolts align with the screw holes on the touchscreen assembly.
Step 2: Secure the replacement touchscreen assembly
Place a nut on each of the five bolts on the front panel. Use a 7 mm nut driver to tighten the five nuts securing the touchscreen assembly to the front panel.
Step 3: Route the replacement touchscreen ribbon cable
Route the replacement ribbon cable through the clamps and behind the other cables on the left side of the printer. Do not pull or bend the cable. Do not tighten the ribbon cable clamp screws.
Step 4: Connect the touchscreen ribbon cable to the touchscreen assembly
Slide the ribbon cable into the connector on the replacement touchscreen assembly. Make sure the cable is inserted evenly. The blue mark should face upward.
Step 5: Connect the touchscreen ribbon cable to the motherboard
Slide the other end of the ribbon cable into the connector on the motherboard. Make sure the cable is inserted evenly. The blue mark should face upward.
Step 6: Secure the ribbon cable
Flip down the black tabs on the connectors to secure the cable to the touchscreen assembly and motherboard. Take care not to pull on the cable during installation.
Step 7: Secure the ribbon cable clamps
Use a 2.5 mm hex driver to tighten the clamps. Ensure there is slack in the touchscreen ribbon cable on both sides. Do not overtighten.
Step 8: Position the front panel for installation
Position the front panel at an angle to the printer. Make sure that the sheet metal tabs are positioned outside of the printer frame and that they align with the screw holes on the printer. Take care not to crush or fold the new touchscreen ribbon cable.
Step 9: Mount the front panel
Mount the front panel onto the printer frame. Ensure the two tabs on the bottom of the front panel slide the corresponding slots in the printer frame.
Step 10: Secure the right front panel retention screws
Step 11: Secure the left front panel retention screws
Thread one screw into each of the three screw holes in the printer frame. Using a 3 mm hex driver, tighten the screws until finger tight.
Step 12: Position the printer
Step 13: Secure the bottom front panel retention screws
Using a 1.5 mm hex driver, secure the bottom front panel retention screws to the printer. Tighten the screws until finger tight.
Reinstalling the side panels
Overview: After performing any other maintenance procedures, reinstall and secure the side panels.
Step 1: Align the left side panel with the printer
Lift the left side panel and align it with the left side of the printer.
Step 2: Secure the left side panel
Thread the four 2.5 mm screws into the screw holes on the left side of the printer. Using a 2.5 mm hex driver, tighten the screws until snug.
Step, 3: Align the right side panel with the printer
Lift the right side panel and align it with the right side of the printer.
Step 4: Secure the right side panel
Thread the four 2.5 mm screws into the screw holes on the right side of the printer. Using a 2.5 mm hex driver, tighten the screws until snug.
Step 5: Reattach the mesh filter
Vacuum the mesh filter until it is free from debris. If the mesh filter cannot be cleaned, replace it. Reattach the mesh filter to the printer, ensuring that it is aligned with the air intake vents.
Finalizing the repair
OVERVIEW: After replacing the touchscreen assembly, power on the printer and perform final checks.
Step 1: Power on the printer
Step 2: Test the touchscreen
The touchscreen should respond to touch inputs if the repair was successful. Test a variety of inputs, such as viewing the printer’s settings or exploring past prints via the print queue. Contact Formlabs Support or your authorized reseller to share the results of the procedure.
