Replacing the Form Wash L display assembly
The Form Wash L has a touchscreen in its top shell. The touchscreen is the primary means of interacting with and controlling the machine, so a broken or malfunctioning touchscreen can prevent the machine from being used normally.
Use this guide to replace the Form Wash L display assembly.
Required supplies:
  • Replacement display assembly
  • Replacement display ribbon cable
  • Electric siphon pump (packaged with Form Wash L)
Third-party:
  • 1.5 mm hex driver
  • 2.5 mm hex driver
  • 5.5 mm socket driver
  • Nitrile gloves
  • Empty solvent container at least 42 L in size
Estimated time: 45–60 minutes
DANGER:
Preparing the workspace
Overview: Prepare the Form Wash L and a dust-free workspace for replacing the display assembly.
Step 1: Prepare the workspace
Clear a workspace around your machine. Ensure that the workspace is well-ventilated and free of dust.
Step 2: Unplug the networking cables and Wi-Fi antenna
Disconnect the Ethernet and USB cables from the unit, if they are connected. Unscrew and remove the Wi-Fi antenna.
Step 3: Unplug the machine
DANGER:
Performing maintenance on the machine while it is plugged in increases the risk of electric shock. Never remove the panels of the machine while it is plugged in. Never reconnect the machine to power while the panels are uninstalled.
Disconnect the power cable from the machine before continuing with maintenance. Do not perform maintenance on the machine while it is connected to power. Wait five minutes after disconnecting the machine from power before proceeding.
Step 4: Empty the Form Wash L
DANGER:
Always consult the safety data sheet (SDS) from the IPA supplier as the primary source of information. IPA is flammable and should be used and stored away from ignition sources. Store small quantities of IPA in appropriately labeled and sealed containers.
Prepare the electric siphon pump that was packaged with the Form Wash L, as well as an empty solvent container at least 42 L in size suitable for the type of solvent in the machine. Lift the Form Wash L lid. Place the intake end of the electric siphon pump into the wash bucket. Securely place the flexible pump hose into the empty solvent container. Turn on the pump switch to transfer solvent from the wash bucket to the solvent container.
Removing the right shell
Overview: Remove the right shell of the machine to access the display assembly.
NOTICE:
The Form Wash L contains sensitive electronic components. Ground yourself before touching any electronics in the machine by using a grounding strap or touching a grounded piece of metal.
Step 1: Unscrew the right shell screws
Use the 2.5 mm hex driver to loosen and remove the 12 screws holding the right shell to the frame of the Form Wash L. Three countersunk screws are located on the right side of the machine and nine button head screws are located on the rear. Set the screws aside.
NOTICE:
There are two screws, accessible through cutouts in the right shell, that secure the lid to the frame of the machine. Do not remove these screws during this procedure.
Step 2: Remove the right shell
Pull the right shell away from the Form Wash L to separate it from the machine’s frame. Set the right shell aside.
Removing the display assembly
Overview: Unscrew and uninstall the display assembly.
Step 1: Locate the display ribbon cable retention clip
Locate the display assembly and the display ribbon cable on the underside of the top shell. The display ribbon cable is held flat against the back of the display assembly with a retention clip. The clip is secured to the assembly with two 1.5 mm hex screws.
NOTICE:
Do not pull on the ribbon cable or pull the display assembly away from the machine. Doing so may damage the display ribbon cable.
Step 2: Remove the display ribbon cable retention clip
Using a 1.5 mm hex driver, unscrew the two screws. Separate the retention clip from the top shell, but do not pull on the display ribbon cable. Set the screws and the retention clip aside.
Step 3: Unlock the latch
The display ribbon cable is secured to its connector with a latch. Lift the latch away from the display assembly to free the display ribbon cable. The latch is unlocked when it is perpendicular to the display assembly. Once the latch is in the vertical position, the latch is unlocked and the ribbon cable can be disconnected.
Step 4: Disconnect the display ribbon cable
Gently pull the ribbon cable to unplug it from the latch. Note the orientation of the exposed contacts on the ribbon cable for later reinstallation.
NOTE:
If you are reseating the display ribbon cable rather than replacing the display assembly, skip to Optional: Reseat the display ribbon cable.
Step 5: Remove the display assembly retention nuts
The display assembly is secured to the top shell with four nuts. Use a 5.5 mm socket driver to loosen and remove the nuts. Remove the washer from each of the threaded posts. Set the washers and the nuts aside.
Step 6: Remove the display assembly
The right-hand lip of the display assembly is sandwiched between two plates in the top shell. Gently lower the left-hand side of the display assembly (closer to the inner wall of the machine) away from the top shell. Slide the display assembly out from between the two plates. Once the display assembly is free, set it aside.
NOTE:
If you are replacing the display assembly, skip to Installing the new display assembly.
Optional: Reseat or replace the display ribbon cable
Overview: If you are reseating or replacing the display ribbon cable rather than replacing the display assembly, perform these additional steps.
Step 1: Remove the display ribbon cable retention clip
Follow the display ribbon cable to its connector on the motherboard.
The display ribbon cable is held flat against the motherboard with a retention clip. The clip is secured to the motherboard with two 1.5 mm hex screws. Using a 1.5 mm hex driver, unscrew the two screws. Separate the retention clip from the motherboard, but do not pull on the display ribbon cable. Set the screws and the retention clip aside.
NOTICE:
Do not pull on the ribbon cable. Doing so may damage the display ribbon cable.
Step 2: Disconnect the display ribbon cable from the motherboard
The display ribbon cable is secured in its connector with a latch. Lift the latch away from the display assembly to free the display ribbon cable. Once the latch is in the upright position, gently unplug the ribbon cable. Note the orientation of the exposed contacts on the ribbon cable for later reinstallation.
Step 3: Reconnect the display ribbon cable to the motherboard
Insert the display ribbon cable back into the connector on the motherboard, orienting the exposed contacts on the ribbon cable as they were previously. Ensure that the ribbon cable is not twisted or folded.
Step 4: Secure the display ribbon cable
Rotate the latch towards the display assembly to lock the display ribbon cable in place. The latch is locked when it is parallel to the motherboard.
Step 5: Reinstall the display ribbon cable retention clip
Align the display ribbon cable retention clip with its mounting points on the motherboard, ensuring that it holds the ribbon cable flat against the motherboard. Insert one 1.5 mm hex screw into both of the two screw holes in the retention clip and, using a 1.5 mm hex driver, tighten until finger tight.
NOTE:
If you are not replacing the display assembly, skip to step 3 under Installing the new display assembly and continue following the steps there to reconnect the display ribbon cable to the display assembly and reassemble the machine.
Overview: Mount and secure the new display assembly.
Step 1: Mount the replacement display assembly
Orient the display assembly so that the mounting points for the ribbon cable retention clip are closer to the inner wall of the machine. Insert the right-hand side of the display assembly between the two plates of the top shell. Raise the display assembly into place, ensuring that the four cutouts in the display assembly are aligned with the four threaded posts in the top shell.
Step 2: Secure the replacement display assembly
For each of the four threaded posts, place one washer on the post and loosely thread a retention nut into place. Tighten the nuts with the 5.5 mm socket driver until finger tight.
Insert the display ribbon cable into the connector on the new display assembly, orienting the exposed contacts on the ribbon cable as they were on the old display assembly. Ensure that the ribbon cable is not twisted or folded.
Rotate the latch towards the display assembly to lock the display ribbon cable in place. The latch is locked when it is parallel to the display assembly.
Align the display ribbon cable retention clip with its mounting points on the top shell, ensuring that it holds the ribbon cable flat against the display assembly. Insert one 1.5 mm hex screw into both of the two screw holes in the retention clip and, using a 1.5 mm hex driver, tighten until finger tight.
Reinstalling the right shell
Overview: Reinstall and secure the right shell.
Step 1: Reinstall the right shell
Hold the right shell against the Form Wash L. Check that the screw holes in the right shell line up with the corresponding screw holes in the frame of the machine. Loosely thread the three countersunk 2.5 mm hex screws into the screw holes on the right side of the machine and the nine button head screws into the screw holes on the back of the machine.
Step 2: Secure the right shell
Starting with the screws on the right side of the machine, tighten the screws using a 2.5 mm hex driver until finger tight.
Finalizing the repair
Overview: After reinstalling the right shell, power on the machine and perform final checks.
Step 1: Power on the machine
Reconnect the power cable to the Form Wash L. Flip the breaker switch on the back of the unit to the ON position to turn on the machine.
Step 2: Test the repair
The touchscreen should respond to touch if the repair is successful. Test a variety of inputs, such as viewing the machine’s settings or starting a wash cycle. Contact Formlabs Support or your authorized reseller to share the results of the procedure.
