Replacing the exhaust filter on a Fuse 1 generation printer
Fuse 1 generation printers contain an intake filter and an exhaust filter that keep the air within the print enclosure free of contaminants that may adversely affect print quality. After extended use, the filters become clogged and cannot be adequately cleaned with a vacuum cleaner. After 2400 hours of printing, old filters should be replaced.
Filter lifetimes and other maintenance steps are tracked by the printer and can be viewed on the touchscreen. It is highly recommended to use the touchscreen prompts as you change filters, as it logs the new filter status and highlights when the filter needs cleaning at an appropriate frequency.
The rate of cleaning is dependent on the age of the filter:
  • Both the intake and exhaust filters should be cleaned after every one to two full build volume prints or 30 hours of printing, whichever comes first.
  • Purge the exhaust lines after 20 full build volume prints or 900–1000 hours of printing, whichever comes first, to remove blockages and ensure optimal airflow through the exhaust system.
  • Old filters that have experienced 2400 hours of printing should be replaced.
Removing and replacing the exhaust filter
Turn off the air system before removing the exhaust filter for replacement.
Step 1: Start the maintenance procedure on the touchscreen
Tap Maintenance > Printer Checklist > Replace Air Filter on the touchscreen.
The Fuse 1's touchscreen is displaying the 'Maintenance' screen
Step 2: Open the filter cabinet door
Open the filter cabinet door on the right side of the printer. The exhaust fan turns off when the filter cabinet door is open.
The cabinet door on the right side of the Fuse 1 is open
Step 3: Vacuum the exhaust filter
Use the vacuum hose on the Fuse Sift to clean the filter grate of clean excess powder. Place the hose against the grate and slowly move the hose up and down until all powder is removed.
The vacuum hose is being brought to the exhaust filter
Step 4: Unclip the retainer
To unclip the retainer and release the exhaust filter:
  1. Depress the retainer hook at the top of the exhaust filter and disengage it from the pin.
  2. Depress the retainer hook at the bottom of the exhaust filter and disengage it from the pin.
  3. Move the retainer out of the way.
Someone is unclipping the bottom retainer hook on the exhaust filter
Step 5: Remove the exhaust filter
Remove the exhaust filter using the fabric pull tabs. Set the filter aside.
Someone is pulling the fabric tabs as the exhaust filter slides out
Step 6: Insert the new exhaust filter
Slide the new exhaust filter into position.
A new exhaust filter is resting in the cabinet
Step 7: Clip the retainer closed
Clip the retainer back into place around the exhaust filter.
The retainer is back in place to secure the exhaust filter
Step 8: Close the filter cabinet door
Close the cabinet door.
The cabinet door on the Fuse 1 is closed
