Resin tank lifetime and monitoring (Form 3/Form 3B)
Resin tanks are consumables and require replacement. The lifetime of an individual resin tank depends on a combination of factors:
  • Time exposed to resin (i.e., the amount of time that a tank is holding resin, regardless of where the tank is stored)
  • Time spent printing
  • Resin
  • Model geometry
  • Temperature
  • Physical damage
We recommend that you replace a Form 3/Form 3B resin tank as soon as one of the following occurs:
  1. Noticeable physical damage (can occur anytime, but expected by 600–800 hours of printing)
    • Wear on the film begins to affect print quality
      • Repeatedly printing the same model in the same location on a tank can cause the tank film to wear more quickly.
    • Punctures, cuts, wrinkles, or gouges in the film
  2. Your tank reaches its maximum lifetime (shown in the table below)
    • Some resin formulations degrade components of the resin tank over time. This will eventually cause the tank to leak resin. To prevent this from happening, replace your resin tank once you reach the maximum lifetime shown below even if your resin tank is otherwise physically undamaged. Your Form 3/Form 3B warns you when your tank is nearing this recommended lifetime.
Replace your resin tank if it is physically damaged (expected by 600–800 hours of printing, for most applications) or if it reaches its maximum lifetime (given in the table below), whichever comes first. High volume production may shorten the maximum lifetime of a resin tank. Other print failures may occur at any time, unrelated to tank lifetime.
Resin groupResinForm 3/3B Resin Tank V1Form 3/3B Resin Tank V2Form 3/3B Resin Tank V2.1
AggressiveTough 2000 Resin
Elastic 50A Resin V1
Rigid 4000 Resin
Grey Pro Resin
Rigid 10K Resin
ESD Resin
Not compatibleCompatible
Maximum lifetime: 10 weeks (75 days) exposed to resin or 250 hours of printing, whichever occurs first
PU Rigid 650 Resin
PU Rigid 1000 Resin
Not compatibleNot compatibleCompatible
Moderately aggressiveDraft Resin V2
Elastic 50A Resin V2
Flexible 80A Resin
Model Resin V3
Dental LT Clear Resin V2
BioMed Black Resin
BioMed Clear Resin
BioMed White Resin
Dental LT Comfort Resin
BioMed Durable Resin
BioMed Elastic 50A Resin
BioMed Flex 80A Resin
IBT Flex Resin
Premium Teeth Resin
Compatible
Maximum lifetime: 35 weeks (250 days) exposed to resin or 600 hours of printing, whichever occurs first
Not aggressiveAlumina 4N Resin
Castable Wax 40 Resin
IBT Resin
No maximum lifetime. Estimated lifetime for most applications: 600–800 hours of printing. Actual lifetime will depend on the accumulation of physical damage to the tank films.
All other resinsCompatible
Resin tank lifetime monitoring
Form 3/Form 3B printers have software features to monitor how close a resin tank is to the end of its maximum lifetime. When a resin tank reaches certain levels of remaining lifetime, the printer will display a warning message when starting a print.
ColorRemaining lifetimePrinter behavior
Green100%–25%Printer will not display any warning
Yellow25%Printer will display a warning when you start a print:
Tank is nearing the end of its recommended lifetime and could begin leaking in the next few prints.
Red0%Printer will display a warning when you start a print:
Tank has reached the end of its recommended lifetime and is likely to begin leaking, which will damage your printer. We recommend that you discard this tank immediately.
Checking remaining lifetime
To check the remaining lifetime of a resin tank:
  1. Tap the printer icon on the printer’s touchscreen. The printer’s current status appears.
  2. Tap the section of the touchscreen labeled with the tank type to go to the Tank Details screen.
  3. The Tank Details screen will report the remaining lifetime of your resin tank.
Remaining Form 3 resin tank lifetime
Resin tanks with incorrect lifetime
Resin tank lifetime calculations are based on when a tank was first used. In some rare cases, the printer may report that an unused tank was first used in 1970 and has already reached the end of its lifetime. To resolve this issue:
  1. Update your printer to the latest firmware. Form 3 firmware version 1.18.3 and Form 3L firmware version 1.9.9, both released March 16, 2022, contain updates intended to address this issue.
  2. Run a print using the affected tank. This should reset its tank lifetime based on its actual first usage.
If the resin tank’s lifetime is still incorrect, prepare your printer for remote troubleshooting by enabling Remote Assistance and Dashboard Logging, then contact Formlabs Support or your authorized reseller.
