Note:
To protect privacy, print jobs cannot be downloaded from your printer or from Dashboard. Refer to the support article Connectivity and security for more information about privacy.
Save your print job as a FORM file in PreForm for later access to the model's orientation and supports.
Note:
Save changes in Preform
To save changes in PreForm:
(*.form).
Saving projects
Starting with PreForm 3.62.0, PreForm supports projects—you can set up builds across different printers and materials, switch between them from the new project panel, and move parts freely as your project plan evolves.
Saving all builds in a project
Projects with multiple builds save as a single FORM file. Use the File menu or keyboard shortcuts to save and load project FORM files normally without needing to save each build separately.
Saving a single build from a project
To save one build out of multiple in a project:
