Understanding dental application print speed (Form 4BL)
Form 4L generation printers deliver blazing fast print speeds with excellent reliability, print quality, accuracy, materials performance, and build volume size. Most MSLA printers sacrifice one or several aspects of print performance to achieve comparable speeds.
Print speed is mostly impacted by material and layer height and slightly impacted by print geometry. The most accurate way to calculate the print time for your model is by using the Print Time estimation feature in PreForm, our free print preparation software.
The table below shows print speeds for a variety of dental applications, resins, and numbers of models per print. For general information about Form 4L generation print speeds, see Understanding print speed (Form 4L generation).
Tip:
Click each image for a full-size view.
ApplicationResinLayoutLayer thickness (microns)Number of parts/jobMax job height (mm)Print time (min)1 Print time per part (min)Print speed (mm/hr)
Clear aligner modelsFast Model 32 aligner models in Fast Model Resin on a Form 4BL 1603212140.451.4
Clear aligner modelsFast Model 75 aligner models in Fast Model Resin on a Form 4BL 1007551.61061.429.2
Clear aligner modelsFast Model 60 aligner models in Fast Model Resin on a Form 4BL 1006050.21001.730.1
Clear aligner modelsGrey V5 75 aligner models in Grey Resin V5 on a Form 4BL 1007551.61301.723.8
Occlusal splints and guardsDental LT Comfort 24 occlusal splint and guard models in Dental LT Comfort Resin on a Form 4BL 1002427.2793.320.7
Occlusal splints and guardsDental LT Comfort 80 occlusal splint and guard models in Dental LT Comfort Resin on a Form 4BL 1008057.91301.626.7
Occlusal splints and guardsDental LT Clear V2 24 occlusal splint and guard models in Dental LT Clear Resin V2 on a Form 4BL 1002427.2923.817.7
Restorative modelsPrecision Model 28 restorative models in Precision Model Resin on a Form 4BL 502822.81686.08.1
Surgical guidesSurgical Guide 36 surgical guide models in Surgical Guide Resin on a Form 4BL 1003624.9691.921.7
1 Using PreForm 3.41.0
