Tackle any problem with our industry-leading materials, or use Open Material Mode.
Form4L
Solve big problems with big parts
Large prints in under 6 hours
Parts that always fit
Industry-leading materials and Open Material Mode
Large format 3D printing you can depend on
Anyone can learn in 15 minutes
Form4L
Solve big problems with large-scale parts.
Or print multiple parts in one job, so you can accelerate product development or keep production running.Speed at scale. Large prints in under 6 hours.
- 4h54minForm 4L
14h24minLeading FDM62h32minBenchmark FDM21h57minForm 3LLacrosse Head
- 2h37minForm 4L
0minLeading FDM - part doesn't fit42h3minBenchmark FDM21h6minForm 3LRadio Flyer Seat Prototype
- 4h12minForm 4L
12h48minLeading FDM86h49minBenchmark FDM22h52minForm 3LSpaceCraft Display Holders
- 5h50minForm 4L
10h38minLeading FDM68h34minBenchmark FDM17h17minForm 3LGolf Training Club Assembly
- 4h58minForm 4L
12h43minLeading FDM76h48minBenchmark FDM18h47minForm 3LRadioFlyer Scooter Cover
Stunning parts that always fit.
Sharpest Details
Highly collimated light and 46 µm pixel size with pre-tuned anti-aliasing for sub-pixel resolution.
Smoothest Surfaces
Lower peel forces, Light Touch Supports, and 46 µm pixel size with pre-tuned anti-aliasing.
Most Accurate Assemblies
±0.15% XY dimensional tolerances so assemblies always fit.
LAPTOP BOTTOM CHASSISSharpest Details
Smoothest Surfaces
Laptop ChassisConsumer Electronics
UNILEVER SOAP BOTTLE BLOW MOLDSharpest Details
Smoothest Surfaces
Bottle MoldManufacturing
STEERING WHEEL ERGONOMIC MODELSharpest Details
Smoothest Surfaces
Steering WheelAutomotive
OUTSOLE COMPRESSION MOLDSharpest Details
Smoothest Surfaces
Outsole MoldManufacturing
ESD-SAFE PCB TRAYSharpest Details
Smoothest Surfaces
PCB TrayManufacturing
IMPELLER CASTING PATTERNSharpest Details
Smoothest Surfaces
ImpellerInvestment Casting
Unmatched reliability. Large format 3D printing you can depend on.
Formlabs optimization engineers put hundreds of printed parts to the test to ensure each material performs to the most reliable standards, right out of the box.
Learn to print in four simple steps:
So intuitive that anyone can learn to print in 15 minutes.
- 1
Import your model and prepare your print.
- Smart auto-orientation
- Advanced support generation
- Live printability checks
- 2
Load a material and click print.
- Validated print settings
- No-hassle cartridge and tanks
- Automatic resin dispensing
- 3
Remove, wash, cure.
- Quick release part removal
- Automatic part cleaning
- Precision post-curing for peak material properties
- 4
Finish your part.
- Light touch supports for quick, clean support removal
- Optional sanding, coating, or painting
Low Force Display™ (LFD)
The Power Behind Form 4LLow Force Display™ (LFD)
The Power Behind Form 4LA wide range of applications to help you excel in your work.
Forge Motorsport reverse-engineered an underperforming part, 3D printed a new design, and tested it on a vehicle for five months before committing to tooling.
