Adding holes to models in PreForm
On SLA printers, a fully enclosed cavity traps air and resin during the printing process. The resulting suction cup may damage the resin tank or cause print failures. On SLS printers, cavities do not necessarily cause print failures but can still trap powder that could otherwise be reused. Add drainage holes to your model to allow air and material to escape.
Starting with PreForm 3.41.0, you can add holes to your models in PreForm.
Tip:
  • Enable the Show Cups toggle to highlight potential cups in your model.
  • Check the design specifications for 3D models for your printer to find requirements for minimum hole diameter and minimum drain hole diameter.
Adding a hole to a model
To add holes to your models with the Hole tool:
  1. Click Hole on the toolbar to the left of the 3D scene. The Drill Hole panel appears.
Preparing to drill a hole in a model with PreForm
  1. Select the parameters for the hole:
DiameterSets the diameter of the drilled hole.
Depth Mode
Set to Automatic to have PreForm automatically drill through to the next face.
Set to Explicit to set the hole depth manually.
DepthIf Depth Mode is set to Explicit, sets the depth of the hole.
PaddingPreForm adds padding on both ends of the hole to ensure that the hole fully passes through the model. Adjust the Padding parameter to set the amount of padding added to each hole.
  1. Click the location on the model where you want to drill the hole. A preview appears showing the hole location and depth.
Preview of hole to be drilled in a model using PreForm
  1. Click elsewhere on the model to add another hole, or click Delete to remove a previewed hole.
  2. Click Apply Edits. PreForm drills the holes in the model.
Hole drilled in a model using PreForm
