PreForm downloads and release notes
This article summarizes the changes for each version of PreForm, the print preparation software. Review the release notes to learn more about the improvements that come with each release.
For information about Insider Program PreForm releases, see PreForm Insider Program release notes.
The latest PreForm version can always be downloaded from formlabs.com/software.
Version number Release date Windows Mac
PreForm 3.65.1 November 20, 2026 Link
Apple Silicon ARM64
Intel-based
Note:
The latest version of PreForm compatible with the Form 1+ is PreForm 2.20.0 (released March 12, 2019):
The latest compatible version of PreForm for computers running on a 32-bit operating system is PreForm 2.16.0:
2025/2026 releases
Previous versions of PreForm are available for download, as well as a list of their associated changes.
PreForm 3.65.1 — November 20, 2026
This release updates all Form Studio 1 print settings to prevent false debris detections from stopping prints.
Windows Download: Link
Apple Silicon ARM64 Download: Link
Intel-based Mac Download: Link
  • Print settings updates:
    • Updated all Form Studio 1 print settings to prevent false debris detections aborting prints:
      • Alpha Black Resin V1
        • Default at 50 microns updated to V1.1
        • Default at 100 microns updated to V1.1
      • Alpha Clear Resin V1
      • Alpha Fast Resin V1
        • Default at 150 microns updated to V1.1
        • Default at 250 microns updated to V1.1
      • Alpha Grey Resin V1
      • Alpha Model Resin V1
        • Default at 30 microns updated to V1.1
        • Large Parts at 30 microns updated to V1.1
        • Large Parts at 50 microns updated to V1.1
      • Alpha White Resin V1
      • Tough 1500 Resin V2
      • Flexible 80A Resin V2
      • True Cast Resin V1
      • Open Material
        • Default at 30 microns updated to V1.3
        • Default at 50 microns updated to V1.3
        • Default at 100 microns updated to V1.3
PreForm 3.65.0 — November 17, 2026
This release adds a model feature tree for editing labels, holes, hollowing, and textures, a print settings table in Job Setup, and thumbnails of builds and models when hovering over them in the Project panel. It also brings Supports V2 shading for undersupported areas, timelapse outro improvements for Form Studio 1, a reorganized Print Settings Editor for Fuse 1 and Fuse 1+ 30W printers, bug fixes, and print settings updates.
  • New features:
    • Model feature tree: Labels, drilled holes, hollowing, and textures you apply to a model are listed under the model in the Project panel, like the feature tree in parametric CAD. Expand a model to see its edits, click an edit to reopen and adjust it, drag edits to change their order, or delete a single edit while keeping the rest.
    • Print settings table in Job Setup: See every print setting for your material in one table. Filter by layer thickness or author, search by name, sort any column, and mark your favorites. Each row shows the setting's description and its hash ID, and lets you edit, copy, export, or delete the setting. To go back to the previous layout, toggle Use the print settings table in Job Setup in Preferences.
    • Build and model thumbnails: Hover over a build or model in the Project panel to see a thumbnail of it, so you can find the right parts in a large project without clicking through each build.
  • Improvements:
    • Drag models from the project panel into the scene: Drag a model from an inactive build in the Project panel straight into the 3D view to move it into the active build.
    • Reorder builds: Reorder builds in the Project panel by clicking and dragging.
    • Smoother, numbered holes: Drilled holes have many more edges around their rim, so they come out round instead of faceted. New holes after the first are numbered (Hole, Hole 2, Hole 3, ...) in the model edit tree.
    • Easier-to-navigate Fuse 1 and Fuse 1+ 30W print settings: In the Print Settings Editor, Fuse 1 and Fuse 1+ 30W settings now use the same section names, field names, and order as Fuse X1, and related fields share fewer sections instead of one section per heater zone. Values in existing .fps and .form files are unchanged.
    • Print Validation stops when you turn a check off: Turning off a Print Validation check, or closing the project, stops its calculations right away, so large scenes respond again instead of finishing work for a check you no longer need.
    • Form Studio 1 timelapse outro: After the last layer, the timelapse keeps recording while the printer slowly brings the finished part into focus, so the video ends on the completed print.
    • Supports V2 shading for undersupported areas: on most Supports V2 settings, the red shading that marks undersupported areas is now calculated based on how auto-support places touchpoints.
      • Form Studio 1: all materials except Tough 1500 Resin
      • Form 4 generation: Denture Base Resin V2, Black Resin V5 and True Cast Resin V1 Supports V2 print settings
      • Form 4L generation: Denture Base Resin V2
    • Search in the Print Settings Editor: Search the settings in the Print Settings Editor by name to find a field quickly.
  • Bug fixes:
    • Wrong tank warning on Form Studio 1: Fixed a warning that "This print setting requires a different tank than the one in the printer" on every Form Studio 1 setting, even with the correct resin tank inserted. The tank row now also shows the tank's type (“Resin Tank” or “Resin Tank Pro”) instead of just "Tank."
    • Custom Outer Boundary Offset had no effect on Fuse 1 and Fuse 1+ 30W: In settings without outlines, which includes every Fuse 1 and Fuse 1+ 30W setting, Outer Boundary Offset could be edited but did nothing, while the field that actually set part dimensions was greyed out. Outer Boundary Offset now controls the offset. Settings you have not edited print the same as before.
    • Precoat Dwell Time unit: The Precoat Dwell Time field in the Print Settings Editor now shows seconds instead of millimeters.
    • Renaming a group renamed its models: Renaming a group no longer changes the names of the models inside it.
    • Updated the default layout platform margin to 0 mm for most SLA print settings, fitting more parts.
    • Updated Default (V1.0) print setting for Nylon 12 Powder on Fuse X1, replacing V0.26 and removing its Beta tag. The validated setting improves part accuracy and failure detection.
    • Corrected the Flexible 80A Resin V2 V1.0 setting at 100 microns name from Beta Testing to Default on Form 4L generation printers. It has been the default since PreForm 3.60.0, and its print performance is unchanged.
    • Updated Open Material print settings at 30, 50, and 100 microns on Form Studio 1 to heat resin to 30 °C instead of 25 °C.
  • Firmware updates:
    • Form Cure L V2: Updated firmware to 1.4.1 to support screens on newer units.
    • Fuse Sift X1: The FormWashCureUpdater can now update Fuse Sift X1 firmware.
PreForm 3.64.2 — October 23, 2026
This release adds new print settings for Alpha Model Resin and True Cast Resin for Form Studio 1 printers, streamlines ordering from Form Now via PreForm, and fixes an issue with the Nylon 11 Pro Powder calibration print.
  • Improvements:
    • Order printed parts without signing in: Users in the United States can now get instant quotes and order printed parts from Form Now without signing in to a Formlabs account.
  • New materials and print settings updates:
    • Form Studio 1: Added the following print settings:
      • Default (V1.0) for True Cast Resin V1 at 50 microns
      • Large Parts (V1.0) for Alpha Model Resin V1 at 30 microns, with a more robust support structure for reliable printing of parts larger than 80 mL or taller than 80 mm
  • Bug fixes:
    • Nylon 11 Pro Powder calibration file failed to upload: Fixed an issue where the calibration file for Nylon 11 Pro Powder did not upload completely to Fuse 1+ 30W printers, leaving files the printer needs behind. You can now calibrate your printer for Nylon 11 Pro Powder.
PreForm 3.64.1 — October 15, 2026
This release fixes a crash that happens when selecting Alpha Model Resin for Form Studio 1.
  • Bug fixes:
    • Fixed a crash that occurred when selecting Alpha Model Resin V1 for Form Studio 1 in Job Setup.
PreForm 3.64.0 — October 14, 2026
This release adds support for Form Studio 1 and its launch materials, introduces Nylon 11 Pro Powder, new dental presets for dentures, absolute-angle orientation, and a redesigned manual support tool. It also includes various performance improvements and bug fixes.
  • New features:
    • Form Studio 1: PreForm supports the new Form Studio 1 printer. Select it in Job Setup to prepare, slice, and send jobs. On a computer's first PreForm launch, Form Studio 1 is the default printer.
    • Orient with absolute angles: The X, Y, and Z boxes in the Orient tool show the selection's actual orientation relative to how the model was imported, instead of resetting to zero after each change. The value you type is applied as an absolute angle, and it is saved with the .form file.
    • Order printed parts: Users in the United States now have a direct integration with Form Now to get instant quotes and order parts.
    • Builds named after the project: A build with no set name now uses the project name, or "Name 1," "Name 2," etc. when a project holds several builds. Because the project name follows the .form file name, renaming the file renames its print jobs. This replaces the old naming based on part names.
    • Redesigned .form import dialog: Opening a .form file shows three options: Import Models From File (which adds the file's models to your current build), Add Build(s), and Open Project. You can now import prepared models from .form files into one build by dragging and dropping or with the Open dialog, as with versions before PreForm 3.62.
    • Redesigned manual support tool: A single brush replaces the Create / Select & Edit toggle in manual support editing. Click to add touchpoints; clicking a support no longer deletes touchpoints by accident. An on-screen overlay at the bottom of the 3D view shows the available keyboard shortcuts.
    • Dynamic detail level: PreForm draws simplified versions of models while you move the camera, so the 3D view stays responsive in large, complex scenes. Set the detail level in Preferences.
    • Dental presets for denture bases and denture teeth: Two new presets in the Dental Workspace to set up common denture jobs in one click. The Denture Bases preset orients the intaglio surface at 55° above the build platform to print accurately.
  • Improvements:
    • Place holes and labels with one click: Placing a second hole used to take two clicks: one to deselect the first hole and one to place the next. The first click now places the next hole, with a live preview as you move the cursor. Labels work the same way.
    • Undo/redo now spans the whole project: Undo and redo now operate across all builds in a project instead of being scoped to a single build.
    • Load support settings from a model: With the Supports tool open, selecting a model that already has supports fills the flyout with the settings used to generate them.
    • Edge Offset Distance for Supports V2: Use this new support setting to move touchpoints away from model edges, from 0 to 1.5 mm.
    • Smoother support geometry: Supports now use simpler meshes, and nearby touch tips are merged, so jobs with many supports upload and render faster.
    • Smarter support regeneration: PreForm recomputes touchpoint locations only when needed. For example, switching from a mini raft to a full raft rebuilds only the support structure, while adding a raft where there was none or turning on internal supports correctly recomputes touchpoints.
    • Cleaner manual support undo history: Selecting and deselecting touchpoints in the manual support tool is no longer recorded in the undo history, so Undo steps back through real edits only.
    • Restyled Pack, Layout, and Orient tools: The Pack, Layout, and Orient flyouts have a cleaner layout. Mirror has moved to the Orient flyout, and the Array pop-out is reorganized.
    • SolidWorks 2026 files: SolidWorks 2026 (SP3) files are now supported.
    • Printability warnings no longer recalculate on every build switch: Switching between build volumes in a multi-build project no longer re-triggers a full printability check each time.
    • Form Studio 1: Added support for the following materials:
      • Alpha Grey Resin V1 at 100 microns and 50 microns
      • Alpha Clear Resin V1 at 100 microns and 50 microns
      • Alpha Black Resin V1 at 100 microns and 50 microns
      • Alpha White Resin V1 at 100 microns
      • Alpha Fast Resin V1 at 250 microns and 150 microns
      • Alpha Model Resin V1 at 50 microns and 30 microns
      • Tough 1500 Resin V2 at 100 microns
      • Flexible 80A Resin V2 at 100 microns
    • Nylon 11 Pro Powder V1: Added support for Nylon 11 Pro Powder on Fuse 1+ 30W printers at 110 microns.
    • Renamed the Nylon 12 Powder V1 110 micron print setting on Fuse X1 with Beta tag while final validation is completed.
    • Added a new Production Optimized print setting (V2.0) for Denture Base Resin V2 at 100 microns on Form 4B printers, for all shades, with improvements to z-compensation. The Denture Bases preset in the Dental Workspace uses it.
    • Updated the Default print setting for Clear Resin V5 at 25 microns on Form 4L generation printers from V1.0 to V1.1 to improve surface quality.
  • Bug fixes:
    • Print preparation failed on some Form 4 jobs: Fixed an issue where PreForm could not prepare certain jobs for Form 4 generation printers, showing "PreForm could not generate the job."
    • Freezes in large projects: Fixed PreForm freezing for several seconds when switching builds, selecting a printer, or adding or removing a printer in builds with thousands of models on resin printers.
    • Models disappeared far from the build volume: Fixed models disappearing from view when moved far away from the build volume.
    • Crash in the projects panel: Fixed a crash that could occur while the projects panel updated its list of builds and models.
    • Slice view filled in after hollowing: Fixed the cut-away slice view filling in solid when you drilled holes or placed labels after hollowing a model.
    • Dashboard sign-in not remembered: The Dashboard panel in PreForm now keeps you signed in after you restart PreForm.
    • Realistic rendering toggle lag: Turning realistic rendering off now takes effect right away, instead of waiting until you move the cursor.
    • Model count included hidden models: The count at the top of the model list again counts only visible models, as it did before PreForm 3.62.
  • Bundled firmware updates:
    • Form Cure V2 and Form Cure L V2: Updated firmware for Form Cure V2 (1.4.0) and Form Cure L V2 (1.3.0).
      • These updates add 2 post-cure profiles (Default and Full Cure) for the new Alpha resins (Alpha Black, Alpha Clear, Alpha Fast, Alpha Grey, Alpha Model, and Alpha White).
      • Form Cure L V2 also now runs the Tough 2000 Resin V2 Low Warp profile at 40 °C instead of room temperature, matching Form Cure V2.
PreForm 3.63.1 — September 25, 2026
This release introduces a new Fast Arch print setting for Fast Model Resin and fixes several crashes.
    • Updated 160 micron print settings for Fast Model Resin V1 from Fast Arch (V1.1) to Fast Arch (V1.2) on Form 4 and Form 4L generation printers, improving peel reliability and reducing prevalence of motor stall print failures.
  • Bug fixes:
    • Crash when deleting a build: Fixed a crash that could occur when deleting a build while builds below it in the projects panel were expanded.
    • Crash when preparing or printing certain .form files: Fixed a crash that could occur while preparing or slicing a job containing models with labels, vent holes, hollowing, or textures that were saved in a different PreForm version or on a different computer. This fix also prevents affected layers from occasionally slicing with missing geometry.
    • Crash when preserving supports after changing materials: Fixed a crash that could occur when changing the material in Job Setup and choosing to keep existing supports.
    • Downloading logs from Fuse X1 printer: Fixed the Download Logs functionality for Fuse X1 printers. You can now save diagnostic logs from Fuse X1 in PreForm, including from printers that are not connected to a network.
PreForm 3.63.0 — September 16, 2026
This release introduces a native Apple Silicon version of PreForm for macOS, significant improvements to Nylon 12 Tough Powder print settings, and a variety of bug fixes.
  • New features:
    • ARM64 version available: Native ARM64 (Apple Silicon) macOS builds are available for the latest version of PreForm, giving macOS users faster, fully native performance.
      • This resolves two previous known issues: Slow startup times on macOS for the first application launch after installing or updating PreForm, and macOS showing a warning about support ending for Intel-based apps.
    • Improved mesh repair: Mesh repair covers more models and repairs faster, improving stability of mesh repair functionality.
    • Translation distance display: The move tool in the 3D scene shows the distance you're moving a model. Hold Shift while moving to snap to fixed distances (5 mm or 0.25 in).
  • Improvements:
    • Intuitive project naming: The project name is now the same as the .form file name.
    • Faster access to print settings editing: "Edit Current Print Setting" is available from the Edit menu, and a new "Copy and Edit" shortcut (Cmd/Ctrl+Shift+K) opens the Print Settings Editor with a copy of the current setting.
    • Drag-and-drop into new build: The New Build button now accepts drag-and-dropped files to instantly create a new build.
    • Faster selection actions: Select all, delete, hide, transform, and similar selection actions no longer slow down the interface as model count grows in large builds.
    • Faster automatic support generation: Automatically-generated supports no longer recompute support contact points if only structure generation knobs have changed, so actions like switching raft type generate much faster.
    • Updated 100 micron Denture Base Resin V2 print setting for all shades on Form 4B printers from Default (V1.0) to Default (V1.1) enabling Z-bleed compensation to improve dimensional accuracy.
    • New Default (V2.0) print setting for Nylon 12 Tough Powder on Fuse 1+ 30W printers. This setting optimizes for faster print speed, improved part surface finish, and easier post-processing. You may need to adjust your bed temperature offsets if previously using the V1.1 setting.
      • Renamed the Default (V1.1) print setting to Legacy (V1.1).
    • Renamed the 50 micron Black Resin V5 print setting on Form 4 generation printers from Supports V1 (Formerly ‘Default’) to Supports V1.
    • Improved Form 4 and Form 4L generation print time estimates.
  • Bug fixes:
    • Nylon 12 default print setting on Fuse 1+ 30W printers: Fixed an issue in PreForm 3.62.x where new jobs for Nylon 12 Powder on Fuse 1+ 30W printers started on the Legacy v2.2 print setting instead of Balanced v6.1. New jobs now start on the Balanced setting, which is also the first option listed in Job Setup.
    • Model collision detection lag: Fixed collision detection lagging one step behind actual model movement, which could show phantom collisions or miss real ones.
    • Supports V2 quality for parts outside the build: Fixed automatic support generation producing poor-quality supports for parts positioned outside the build volume.
    • 3MF import placement: Fixed inconsistent model placement when importing 3MF files, where models could load into the wrong position depending on the chosen import option.
    • Measure tool conflicting with manual supports: The measure tool is now disabled while in manual support mode, since it previously produced overlapping previews and conflicting clicks with support placement.
    • Manual support placement blocked by slicer slider direction: Fixed being unable to manually place supports on certain downward-facing surfaces depending on which direction the slicer slider was oriented.
    • Manual touchpoint previews hidden by supports: Fixed manual support touchpoint previews being hidden behind semi-transparent support structures (pillars, touch tips, rafts).
    • More accurate mesh-repair reporting: Improved detection of whether an imported model actually needs mesh repair. PreForm now correctly reports when a repair attempt didn't fully succeed instead of always claiming success.
    • Update Cage button greyed out: Fixed the Update Cage button staying greyed out and non-functional after changing cage parameters. Previously, you had to delete and regenerate the cage to apply changes.
PreForm 3.62.1 — August 19, 2026
This release includes two bug fixes related to switching between builds within a project and crashes during part cost calculations.
Mac Download: Link
  • Bug fixes:
    • Faster build switching: Fixed an issue where switching away from a build with many models took as long as switching into it.
    • Crash while calculating part cost: Fixed a crash that could close PreForm while it was calculating material cost for parts in the background.
    • Form Now upload issue: Fixed “Error submitting quote” error when using Form Now with Fuse X1.
    • Dental Scan-to-Model labeling failure after cut: Fixed a regression where applying a label to a Dental Scan-to-Model mesh after cutting it would fail with a "broken mesh" error. The cut and label workflow now completes successfully, as it did in 3.60.
  • Known issues:
    • Startup times are slow on macOS for the first application launch after installing or updating PreForm. After starting PreForm once, subsequent launches will not have this slowdown.
    • macOS may show a warning about support ending for Intel-based apps. This does not cause any issues within PreForm.
PreForm 3.62.0 — August 11, 2026
This release introduces projects for PreForm, a new Layout Selected function for SLA, the ability to drag models outside the build volume, and several new print settings. It also includes new firmware for the Form Cure V2 and Form Cure L V2, accessible through the bundled FormWashCureUpdater application.
Mac Download: Link
Introducing Projects in PreForm!
Real projects rarely fit on one build platform. Projects in PreForm let you keep everything for one deliverable, client, or large prototype in a single place. Set up builds across different printers and materials, switch between them from the new project panel, and move parts freely as your project plan evolves.
  • New features:
    • Multi-build projects: view, prepare, and print multiple scenes in a single PreForm window. Manage builds within the Project Panel on the left-hand side of the application.
    • Send parts to a specific build: Right-click a selection of parts and choose Send to Build to move them to another build. The submenu lists every existing build plus Create New Build, which creates an empty copy of the current build (same printer and material) and moves the selection into it.
    • Drag parts out of the build: Parts stay constrained to the build during normal moves, but dragging far enough past the boundary pops a part free so it becomes unconstrained. Dragging it fully back inside inside the build volume re-constrains it.
    • Layout Selected for SLA: When only some models are selected, SLA layout arranges just those and treats the rest of the plate as fixed.
  • Improvements:
    • Out-of-build parts grouped in the list: Models that sit outside the build now sort to the bottom of their build list in the Project panel, so you can find and select them together instead of scrolling a long list.
    • Removed persistent touchpoint: Retired the little-used feature that allowed touchpoints to be retained during model rotation.
    • Delete all custom print settings: The custom print settings list in the Print Settings Editor has a new Delete All button (with a confirmation dialog) for quickly clearing out a long list.
  • Bug fixes:
    • Fixed a crash when importing a batch containing an undersized model and choosing Use Inches.
    • Fixed a crash during support generation.
    • Fixed a crash during raft generation on certain files.
    • Fixed a memory leak where generating .form thumbnails left Windows Explorer holding the file open, blocking rename, move, and delete.
    • Fixed the import-time Separate Bodies dialog not preserving the size of separated parts.
    • Fixed Support flyout fields not snapping back to their minimum/maximum, which could make out-of-range values appear to apply.
    • Fixed model hover highlighting that responded only when the cursor moved up, not down.
    • Fixed the FormWashCureUpdater utility crashing when a device was connected.
    • Renamed the 50 micron Form 4 Black Resin V5, 50 microns setting V1.2 from from Default to Supports V1 (Formerly 'Default')
    • Updated the Supports V2 (V2.1) print settings for Black Resin V5 at 50 microns on Form 4 generation printers to offset auto-placed touchpoints from edges and reduce sanding time on parts.
    • Updated Nylon 12 Powder Balanced V6.0 setting to Balanced V6.1 for Fuse 1+ 30W printers to mitigate the underdosing issues observed when using Balanced V6.0.
    • New Supports V2 Beta (V2.0) print settings for True Cast Resin V1 at 50 microns on Form 4 generation printers.
    • Third-party material fields in the Print Settings Editor: When creating open-material (OMM) FPS files, PreForm now requires a third-party manufacturer name, material name, and print setting name before saving.
  • Announcements:
    • Form 2 Ceramic Resin removed: Ceramic Resin V1 has been removed from PreForm following its earlier sunset notice. If you need to keep printing Ceramic Resin on Form 2, stay on an older version of PreForm.
  • Known issues:
PreForm 3.60.4 — July 30, 2026
This release adds a new print setting for Nylon 12 Powder for Fuse 1+ 30W printers.
Mac Download: Link
    • New Balanced V6.0 print settings for Nylon 12 Powder at 110 microns for Fuse 1+ 30W printers. This print settings optimizes for the best surface finish, print reliability and accuracy. You may need to adjust your doser offsets if previously printing using the V5.3 print setting
    • Renamed Default V5.3 to Speed Optimized V5.3 for Nylon 12 Powder at 110 microns for Fuse 1+ 30W printers to better communicate the intent of the print setting. This print setting optimizes for print speed and also provides better accuracy and surface finish than legacy settings. Using this setting may result in less reliable printing with more in-print errors.
  • Known issues:
PreForm 3.60.3 — July 14, 2026
This release adds support for Denture Base Resin V2 and includes corresponding firmware updates for the Form Cure V2 and Form Cure L V2.
Mac Download: Link
  • New features:
    • Denture Base Resin V2: Produce durable, natural-looking dentures that exceed ISO standards with ease using Formlabs' new high-impact, Class II biocompatible denture base material. Select it from the material menu in the dental workflow. Learn more.
  • Improvements:
    • Version-first material selection: For versioned dental materials such as Denture Base Resin, you can now choose the material version first and have the available shades filter to match—instead of having to pick a shade before the version you want becomes selectable.
  • Bug fixes:
    • Form Wash / Form Cure updater crash on device connection: Fixed a crash where connecting a Form Cure L V2 (or certain other USB devices) could cause PreForm to close the moment the device was detected.
    • New Supports V2 (V2.0) print settings for Black Resin V5 at 50 microns on Form 4 generation printers.
    • New Default (V1.0) print settings for Denture Base Resin V2 at 100 microns on Form 4B and Form 4BL printers.
  • Firmware updates:
    • Added post-cure settings for Denture Base Resin V2 for the Form Cure V2 (1.3.4) and Form Cure L V2 (1.2.7)
  • Known issues:
PreForm 3.60.2 — June 23, 2026
This release fixes a bug related to file name lengths and remote prints.
Mac Download: Link
  • Bug fixes:
    • Fixed an issue where PreForm would produce longer file names by default, potentially leading to an Error getting secure URL message during remote prints.
PreForm 3.60.1 — June 10, 2026
This release adds support for Flexible 80A Resin V2 for the Form Cure V2 and Form Cure L V2. Use the FormWashCureUpdater utility, included with PreForm, to update your machine’s firmware.
Mac Download: Link
  • Accessory firmware updates:
    • Added post-cure settings for Flexible 80A Resin V2 for the Form Cure V2 and Form Cure L V2
PreForm 3.60.0 — June 9, 2026
This major release introduces Auto-Recovery to protect against unexpected shutdowns, Realistic View for true-to-life material previewing, Fuse X1 support, Flexible 80A Resin V2, and variable Print Scale Correction in the Z-axis, along with improvements to Separate Bodies, support settings persistence, and numerous bug fixes.
Mac Download: Link
Note:
Form 2 Ceramic Resin deprecation notice: Support for Form 2 Ceramic Resin will be removed in a future PreForm version. Users who need to continue printing with Ceramic on Form 2 should not upgrade past PreForm version 3.60.0. This is the final release in which the resin is supported.
  • New features:
    • Fuse X1 support: PreForm now supports the Fuse X1 SLS printer.
    • Flexible 80A Resin V2: The new Flexible 80A Resin is now available in PreForm for Form 4 and Form 4L generation printers.
    • Auto-Recovery: PreForm now automatically saves local backups of your active work at regular intervals. If PreForm quits unexpectedly, you will be prompted on the next launch to recover lost progress from the most recent backup. The backup interval and the recovery feature can be configured under PreForm > Preferences > General.
    • Realistic View: A new view toggle in the top-right of the 3D scene lets you switch between the standard view and a Realistic View, where parts are rendered as they will actually look when printed, including material color, touchpoints, layer lines, and surface textures. The Realistic View button is always visible; it is greyed out for materials that are not yet supported. Currently supported materials include:
      • Grey Resin V5
      • Black Resin V5
      • White Resin V5
      • Fast Model Resin V1
      • Precision Model Resin V1
      • Tough 1000 Resin V1
      • Tough 2000 Resin V2
      • Rigid 4000 Resin V1
      • Rigid 10K Resin V1.1
      • Nylon 12 Powder V1
      • Nylon 11 Powder V1
      • Nylon 12 Tough Powder V1
      • Nylon 12 GF Powder V1
    • Variable Print Scale Correction in Z-axis: The Print Settings Editor has updated the Z Correction Factor from a single value to an array for SLS materials. Changing values in this array changes the scale factor applied to all models at different heights within the build chamber, allowing print accuracy to be controlled throughout a full build height.
      • The Z Correction Factor array field defines a lookup table of Z height (mm) and scale factors. With one entry, it acts as a constant correction. With multiple entries, it linearly interpolates between them. Click Edit Array Field to open the table popup, where you can add, duplicate, edit, or delete points in the lookup table.
  • Improvements:
    • Separate Bodies refinement: The Separate Bodies context menu option (formerly "Split Bodies," introduced in version 3.59.0) is now disabled when right-clicking a single-body model, making it clear that the feature only applies to multi-body parts.
    • Z-Bleed Compensation control in Print Settings Editor: The Z-Bleed Compensation parameter in the Print Settings Editor has been redesigned for clarity. Instead of entering an offset in layer counts, you now enter the maximum compensation amount directly in millimeters and can adjust it in increments matching the layer height.
    • Biocompatible material Print Settings Editor parameters now fully editable: Previously, biocompatible materials locked out layer height and scale in the Print Settings Editor even after acknowledging the out-of-certification warning. All public fields are now editable once you accept the warning, consistent with the behavior for other materials.
    • Local network permission dialog: If PreForm launches without local network permissions (which is required for printer discovery), it now shows a clear in-app dialog with a link to our support article on network permissions.
    • Dental Form 4B/4BL users: print settings download link: Users on Form 4B and Form 4BL printers now see a link in PreForm to download available dental print settings files (.fps).
    • Elastic 50A Resin V2 renamed to Flexible 50A Resin: As part of the Flexible 80A Resin V2 launch, Elastic 50A Resin V2 has been renamed to Flexible 50A Resin throughout the PreForm and printer UIs.
    • BioMed Elastic 50A Resin renamed to BioMed Flex 50A Resin: As part of the Flexible 80A Resin V2 launch, BioMed Elastic 50A Resin has been renamed to BioMed Flex 50A Resin throughout the PreForm and printer UIs.
  • Bug fixes:
    • Fixed a longstanding issue on macOS where clicking "Check for Updates" would sometimes do nothing, and the automatic update notification never appeared. Mac users should now reliably receive update prompts and be able to update from within the app.
    • Fixed a crash that occurred when cancelling the loading of a large .form file mid-progress. PreForm now correctly handles cancellation and returns to idle without crashing.
    • Fixed an issue where importing a .3mf file caused models to be placed at incorrect positions and flagged as colliding, despite being correctly laid out in the source file (e.g., from Fusion 360 via the Formlabs API).
    • Several keyboard shortcuts using the Alt key were not functioning on Windows. These shortcuts have been restored.
    • Fixed a bug introduced in 3.59.0 where dragging a .form file into PreForm and then opening a new file or switching files would incorrectly trigger an unsaved changes warning, even when no changes had been made.
    • Fixed intermittent failures in the Scan to Model feature caused by edge cases in the Delaunay triangulation algorithm, which could cause the tool to silently fail on certain mesh geometries.
    • Fixed issue where the Separate Bodies feature snapped newly made parts to the bottom of the build chamber in Fuse 1 generation scenes. It now only snaps to the build platform for SLA scenes.
    • Fixed issue where some support flyout settings were lost upon saving and reopening a .form file.
    • New Default print settings for Flexible 80A Resin V2 at 100 microns on Form 4 and Form 4L generation printers.
    • Support presets removed: The support presets dropdown has been removed from the support flyout for Form 4 and Form 4L generation printers. Users who relied on a specific preset can download them at this page.
  • Knowin issues:
    • Very high model counts can slow down rendering when the model list is open. It is recommended to collapse the model list for scenes with more than 1,000 parts.
PreForm 3.59.1 — May 22, 2026
This release fixes a bug related to lag experienced when moving supported models.
Mac Download: Link
  • Bug fixes:
    • Fixed a bug causing lag when moving or rotating models with supports, especially in scenes with many touchpoints.
  • Known issues:
    • Users on macOS may experience a longer startup time on the first launch after an install or update. Subsequent launches will return to normal startup performance.
PreForm 3.59.0 — May 12, 2026
This release adds multi-body part splitting, improvements to support regeneration, updated print settings for Tough 2000 Resin V2 on Form 4 and Form 4L generation printers, and various bug fixes.
Mac Download: Link
  • New features:
    • Part splitting: Split multi-body models in PreForm. Right-click on a multi-body model and select Split Bodies. The separated models appear in a group in the model list.
  • Improvements:
    • Support structures can now be regenerated without modifying touchpoints to apply newly-selected settings.
    • Updated the Default settings for Tough 2000 Resin V2 on Form 4 and Form 4L generation printers to improve print reliability
      • Default Form 4 at 100 microns updated to V2.2
      • Default Form 4L at 100 microns updated to V2.2
      • Default Form 4L at 50 microns updated to V2.1
  • Bug fixes:
    • Fixed issue where using inches causes hollowing models to fail
    • After restarting PreForm, the last selected printer reverted to "No printer selected.” Fixed so the specific printer selection persists across sessions.
    • Fixed issue where deleting custom FPS file crashed PreForm
    • Fixed issue where generating supports with rafts exceeding the build platform area crashed PreForm
    • When importing models, cups were not being detected due to an interaction with the minima detection setting. Cup detection now works correctly on import regardless of the minima detection state.
    • Fixed issue where pasting large numbers of models was very slow
    • Certain .form files opened with the Reinforcements density set to the maximum value (10.18) and the slider frozen and uneditable. Fixed so the correct value loads and the slider is always accessible.
  • Known issues:
PreForm 3.58.1 — April 23, 2026
This release updates print settings for Tough 2000 Resin V2 on Form 4 generation printers and adds various bug fixes.
Mac Download: Link
  • Improvements:
    • Printer discovery improvements: Removed the legacy BonjourBrowser dependency, simplifying networking under the hood and reducing onboarding issues related to printer discovery problems. When using PreForm 3.58.0 or later, Bonjour-related troubleshooting steps are no longer needed.
    • Added a post-exposure cure wait and reduced peel speed for Tough 2000 Resin V2 on Form 4 generation printers to improve print reliability:
      • Default 100 micron setting updated to V2.1
      • Default 50 micron setting updated to V2.1
      • Supports V2 100 micron setting updated to V1.2
      • Supports V2 50 micron setting updated to V1.2
  • Bug fixes:
    • Fixed bug where the default values in the Layout tool’s Platform Margin (SLA) and Pack tool’s Distance to Wall (SLS) were wrong.
    • Fixed bug where certain internal support geometries caused crashes at the end of support generation.
    • Resolved an issue where .obj file import on Windows failed when the path name exceeded 254 characters or contained a non-ASCII character.
PreForm 3.58.0 — April 15, 2026
This release adds multiple UI controls, bug fixes, and print settings updates for Tough 1000 Resin, Tough 2000 Resin, and the General Purpose resins.
Mac Download: Link
  • Announcements:
    • The Insider Program: Join the PreForm Insider Program. Get early access to our latest features, experimental workflows, and cutting-edge algorithms before they hit the mainstream. For more information, see our announcement blog post.
    • Denture Base Resin sunset notice: Formlabs is retiring Denture Base Resin. We will continue to sell through our remaining inventory while supplies last. If you are an active user of Denture Base Resin, please reach out to [email protected] with your printer’s serial name. We have several options available to support you through any supply disruption.
  • New features:
    • Coarse Early Layers in Print Settings Editor: Print early layers at a greater layer thickness to speed up the beginning of your print. You can configure this feature to be On for All Geometries, On for Rafts (will not activate when there are models printed directly on the build platform in the scene), or Off to print layers at the nominal print setting layer thickness.
  • Improvements:
    • Support editing UX improvements: Adjusted increment sizes in the support flyout for more precise and predictable support editing.
    • Consistent terminology for supports: "Touchtips" have been renamed to "Touchpoints" throughout the user interface.
    • Print Settings Editor improvements:
      • Updated header layout in the Print Settings Editor to improve clarity and usability when configuring print settings.
      • Fixed various links throughout the tool.
    • Refreshed material imagery: Updated Clear Resin material image for a more accurate representation in the Job Setup page.
    • More actionable cupping warnings: Pressing the target icon next to cup warnings will now home the yellow cupped regions in the viewport, helping users locate and address cups.
    • New Default (V2.0) print setting for Tough 2000 Resin V2 at 50 microns for Form 4 generation printers. Default V2.0 utilizes Supports V1 for more similar support experience to the previous generation material. The previous Default (V1.1) print setting has been renamed to Supports V2.
    • New Default (V2.0) print setting for Tough 2000 Resin V2 at 50 microns for Form 4L generation printers. Default V2.0 utilizes Supports V1 for more similar support experience to the previous generation material.
    • Updated the Default print setting to V2.1 for Tough 1000 Resin V1 at 100 microns for improved touchpoint geometry accuracy.
    • Updated multiple print settings to mitigate infrequent early layer delaminations.
      • Affected settings:
        • Default Form 4L Tough 1000 V1 Resin at 100 microns updated to V2.1
        • Supports V2 Form 4L Tough 1000 V1 Resin at 100 microns updated to V1.2
        • Default Form 4L Tough 1000 V1 Resin at 50 microns updated to V1.1
        • Default Form 4L Tough 2000 V1 Resin at 100 microns updated to V2.1
        • Supports V2 Form 4L Tough 2000 V1 Resin at 100 microns updated to V1.2
    • Updated Default (V1.2) print settings for General Purpose resins at 50 and 100 microns for Form 4 generation printers, adding tapers to internal support geometry to make de-supporting your parts easier.
      • Affected resins: Black Resin V5, Clear Resin V5, Grey Resin V5, White Resin V5
  • Bug fixes:
    • PreForm memory leaks:
      • Resolved a memory leak affecting macOS when PreForm was left open with no prints ever opened, improving long-term stability.
      • Addressed issues contributing to memory use growth when PreForm is left running for extended periods.
    • Rapid print time calculation continues after closing PreForm (Form 4 generation): Resolved an issue where Form 4 rapid print time calculation did not stop when PreForm was closed.
    • PreForm crash during slicing (SLS): Fixed crashes during SLS print slicing.
    • Support profiles not cleared when changing material: Switching materials now correctly clears support profiles to avoid carrying over incompatible settings.
    • Touchpoint size UI mismatch: Resolved an inconsistency where the touchpoint size shown in the UI could get out of sync with the actual size applied.
    • Incorrect prompt to import print settings: PreForm no longer prompts users to import print settings when they have already been imported.
    • Erroneous undersupported model warnings: PreForm no longer gives false undersupported model warnings when no support points are added or manual supports are added to models not on rafts.
PreForm 3.57.2 — March 31, 2026
This release updates the print settings for Tough 1000 Resin V1 and Tough 2000 Resin V2 at 100 microns for Form 4L generation printers.
Mac Download: Link
    • Promoted the Supports V1 print setting to Default (V2.0) for Tough 2000 Resin V2 at 100 microns for Form 4L generation printers. The previous Default (V1.1) print setting has been renamed to Supports V2.
    • Promoted the Supports V1 print setting to Default (V2.0) for Tough 1000 Resin V1 at 100 microns for Form 4L generation printers. The previous Default (V1.1) print setting has been renamed to Supports V2.
PreForm 3.57.1 — March 24, 2026
This release fixes bugs related to Windows auto-update preferences and the Hole tool.
Mac Download: Link
  • Bug fixes:
    • Fixed issue where auto-update preferences were not saved for Windows users
    • Fixed issue where deleting drilled holes crashed PreForm
PreForm 3.57.0 — March 18, 2026
This release introduces user controls that can enhance print accuracy on SLA and SLS platforms, as well as a variety of bug fixes and print settings updates.
Mac Download: Link
  • New features:
    • Minimum Layer Time (Fuse 1 generation): Set a minimum time to have more consistent layer times and control thermal build-up, simplifying print process development for third-party materials through Open Material Mode. Minimum Layer Time is accessible from the Print Settings Editor.
    • Z-Bleed Compensation enhancements (Form 4 and Form 4L generation): Updated implementation to protect large overhangs while still improving print accuracy on bottom-facing surfaces and threads. Z-Bleed Compensation is accessible from the Print Settings Editor.
    • Promoted Reduced Support Density print setting (V2.0) to Default for Tough 2000 Resin V2 at 100 microns for Form 4 generation printers. The previous Default print setting (V1.1) has been renamed to Supports V2.
    • Promoted Reduced Support Density print setting (V2.0) to Default for Tough 1000 Resin V1 at 100 microns for Form 4 generation printers. The previous Default print setting (V1.0) has been renamed to Supports V2.
    • Promoted the Beta print setting to Default (V1.0) for Tough 2000 V2 Resin at 50 microns for Form 4L generation printers.
    • Updated Default print setting (V1.1) for Tough 2000 Resin V2 at 50 microns for Form 4 generation printers to reduce support density.
    • Updated Default print setting (V1.1) for Tough 2000 Resin V2 at 100 microns for Form 4L generation printers to reduce support density.
    • New Supports V1 Beta print setting (V2.0) for Tough 2000 Resin V2 at 100 microns for Form 4L generation printers. This setting uses fewer and larger touchpoints compared to the Default setting.
    • New Supports V1 Beta print setting (V2.0) for Tough 1000 Resin V1 at 100 microns for Form 4L generation printers. This setting uses fewer and larger touchpoints compared to the Default setting.
    • New Beta print setting (V3.0) for Nylon 12 GF Powder for Fuse 1+ 30W printers.
  • Bug fixes:
    • Fixed issue where importing some .fps files would crash PreForm
    • Fixed issue where the Texture tool used the original model height, limiting where textures are applied
    • Fixed issue where PreForm underestimated total powder usage for a job (Fuse 1 generation)
    • Fixed an issue that caused crashes for some users
PreForm 3.56.2 — March 5, 2026
This release contains various bug fixes and an update to print setting options for Tough 2000 V2 Resin at 100 microns for Form 4 generation printers.
Mac Download: Link
    • New Default print setting (V1.0) for Tough 1000 V1 Resin at 50 microns for Form 4L generation printers
    • New Beta print setting (V1.0) for Tough 2000 V2 Resin at 50 microns for Form 4L generation printers
    • Corrected setting name for Default print setting for Tough 1000 V1 resin at 50 microns for Form 4 generation printers
  • Bug fixes:
    • Stability improvements
PreForm 3.56.1 — February 26, 2026
Mac Download: Link
    • Removed the Reduced Support Density preset support option for Tough 2000 V2 Resin at 100 microns for Form 4 generation printers due to redundancy with the Default setting.
  • Bug fixes:
    • Resolved an issue where Form 3B+ printers were not appearing in the printer list.
    • Fixed a problem causing the Layout tools to malfunction for Form 3/3B/3+/3B+ printers.
    • Addressed a bug in the Print Settings Editor (PSE) where fields containing arrays were disappearing.
PreForm 3.56.0 — February 24, 2026
This release updates the system requirements for macOS. It also introduces new print settings for Tough 1500 Resin V2 on Form 4L generation printers and for Tough 1000 Resin, Tough 1500 Resin V2, and Tough 2000 Resin V2 on Form 4 generation printers.
Mac Download: Link
  • Announcements:
    • This version of PreForm has updated system requirements for macOS. You now require macOS 13 or higher. There has been no change for Windows. Some macOS users may encounter an increased load time during the first application launch following the update. This initialization process will occur on the first launch each time you update PreForm (after version 3.56.0) until Formlabs releases a native ARM64 build of PreForm for macOS.
    • New Reduced Support Density print setting (V2.0) for Tough 2000 Resin V2 at 100 microns for Form 4 generation printers. This setting uses fewer and larger touchpoints compared to the Default setting.
    • New Reduced Support Density print setting (V2.0) for Tough 1000 Resin V1 at 100 microns for Form 4 generation printers. This setting uses fewer and larger touchpoints compared to the Default setting.
    • New Supports V2 print setting (V2.0) for Tough 1500 Resin V2 at 100 microns for Form 4 generation printers. This setting uses smaller and denser touchpoint sizes compared to the Default setting that make support removal easier while improving surface finish and part accuracy.
    • New Supports V2 print setting (V2.0) for Tough 1500 Resin V2 at 100 microns for Form 4L generation printers. This setting uses smaller and denser touchpoint sizes compared to the Default setting that make support removal easier while improving surface finish and part accuracy.
    • Updated Default print setting (V1.1) for Tough 2000 Resin V2 at 100 microns for Form 4 generation printers to reduce support density.
  • Bug fixes:
    • Several bug fixes and usability improvements to the new Supports panel
PreForm 3.55.1 — January 28, 2026
This release introduces new print settings for Tough 1000 Resin V1 on Form 4 and Form 4L generation printers, as well as several bug fixes.
Mac Download: Link
  • Bug fixes:
    • Fixed crash when switching between remote and local printers
    • Fixed issues with printer USB connectivity due to Another version of PreForm is using this printer and/or Unavailable Printer Detected errors
    • Fixed missing Download logs button in the Accessories dialog
    • New Default print setting (V1.0) for Tough 1000 Resin V1 at 50 microns for Form 4 generation printers
    • Updated Default print setting (V1.1) for Tough 1000 V1 at 100 microns for Form 4L generation printers with a minor accuracy improvement
PreForm 3.55.0 — January 13, 2026
This release introduces a new Print Settings Editor parameter for Form 4 and Form 4L generation printers and a variety of new Supports V2-based Reduced Density presets.
Mac Download: Link
  • New features:
    • Z-Bleed Compensation: Print fine features like threads and overhangs with increased precision. Available as a setting in the Print Settings Editor (Form 4 and Form 4L generation only).
  • Bug fixes:
    • Fixed issue where the model Replace function would fail on subsequent attempts.
    • Fixed issue where some FORM files with models imported from CAD could not be opened after adding part cages in PreForm 3.54.
    • Fixed bug where the Print Settings Editor would crash when deleting a setting.
    • New Supports V2-based Reduced Density (Alpha) presets:
Form 4 generation
MaterialLayer Thickness (microns)
Black Resin V525, 50, 100
Clear Resin V525, 50, 100
Grey Resin V525, 50, 100
White Resin V550, 100
Tough 1000 Resin V1100
Tough 1500 Resin V250, 100
Tough 2000 Resin V2100
Tough 2000 Resin V1.150, 100
Form 4L generation
Grey Resin V525, 50, 100, 150
PreForm 3.54.1 — December 9, 2025
This release introduces new print settings for Tough 1000 Resin V1 on Form 4L generation printers and Tough 200 Resin V2 on Form 4 generation printers. It also includes a firmware update for Form Cure V2 and Form Cure L V2.
Mac Download: Link
  • Announcements:
    • Formlabs will be sunsetting the following materials effective Sunday, March 1, 2026:
      • Temporary CB Resin V1
      • Permanent Crown Resin V1
      • Castable Wax 40 Resin V1
    • PreForm displays an end-of-life notice in the Job Setup screen if you select one of these resins.
    • See our article on material formulation updates for more information.
    • New Default print setting (V1.0) for Tough 1000 Resin V1 at 100 microns for Form 4L generation printers
    • New Default print setting (V1.0) for Tough 2000 Resin V2 at 50 microns for Form 4 generation printers
    • New Low Warp setting for Tough 2000 Resin V2 for the Form Cure V2 and Form Cure L V2
PreForm 3.54.0 — November 18, 2025
This release introduces a new measurement tool, improved scene viewing controls, and model grouping for SLA. It also introduces several new SLA Print Settings Editor parameters.
Mac Download: Link
  • Announcements:
    • Updated macOS requirements: Starting with PreForm 3.54.0, PreForm now requires macOS 12 or later.
    • Sunsetting command line support: Most command line functionality has been removed. The only remaining support will be for launching PreForm from the command line and automatically loading models or FORM files.
  • New features:
    • Tough 2000 Resin V2: Manufacture rugged parts that rival the performance of ABS. 3x higher fracture toughness and improved temperature and creep resistance compared to the previous generation with a rich, dark, matte appearance.
    • Tough 1000 Resin: Manufacture impact-resistant parts that rival the performance of HDPE. 5x fracture toughness, 3x impact strength, and 3x elongation at break compared to Durable Resin.
    • Supports V2: Get higher quality, more reliable parts with less work. Supports V2 cuts dimensional inaccuracy in half and uses 50% smaller touchpoints for a smooth finish, ensuring assemblies fit perfectly. A new crushable lattice structure makes support removal fast, easy, and less likely to damage your part. Available for:
      • Tough 2000 Resin V2 (default)
      • Tough 1000 Resin (default)
      • Black Resin V5 (beta)
      • Clear Resin V5 (beta)
      • White Resin V5 (beta)
      • Grey Resin V5 (beta)
      • Tough 2000 Resin V1.1 (beta)
      • Tough 1500 Resin V2 (alpha)
    • Print Cost Estimator for SLA: Get estimated part costs for your SLA prints. Input your material cost per liter in the new cost estimator panel, and PreForm will display the total part cost in the print summary.
  • Improvements:
    • When changing views with the Viewer Cube, you can now frame just the selected part or the entire build volume. Pick your preferred behavior in the View menu.
    • New Default print setting (V1.0) for Tough 2000 Resin V2 at 100 microns for Form 4 and Form 4L generation printers
    • New Default print setting (V1.0) for Tough 1000 Resin at 100 microns for Form 4 generation printers
    • New Supports V2-based Beta print settings for Form 4/4L generation printers. These settings are under validation and are expected to work for most applications. Expect reduced print success rate.
      • Black Resin V5
      • Clear Resin V5
      • White Resin V5
      • Grey Resin V5
    • New Supports V2-based Alpha print settings for Tough 1500 Resin V2 for Form 4/4L generation printers. These settings are unvalidated and for advanced users to test. Expect a higher than usual print failure rate.
  • Bug fixes:
    • Fixed bug where rotation values were not displayed while rotating the model.
    • Fixed issue where values from the Measure Tool would appear over other elements on the screen.
PreForm 3.53.0 — October 21, 2025
Mac Download: Link
  • Announcements:
    • Updated macOS requirements: Starting with PreForm 3.54.0, PreForm will require macOS 12 or later to run.
    • Sunsetting command line support: Starting with PreForm 3.54.0, most command line functionality will be removed. The only remaining support will be for launching PreForm from the command line and automatically loading models or FORM files.
  • New features:
    • Measure tool: Quickly validate dimensions and clearances by measuring precise distances between any two points in your scene, with ΔX, ΔY, and ΔZ components in the summary panel. Hold Shift to snap to mesh vertices for accuracy. Eliminates the need to switch to external CAD software for simple dimensional checks.
    • Viewer cube: Navigate the scene and quickly jump to standard orthographic views.
    • Model grouping for SLA: Organize parts in the model list by grouping them. This builds on the grouping feature we released for SLS last year.
  • Improvements:
    • New SLA Print Settings Editor parameters:
      • New squish parameters: Directly modify the Formlabs smart squish algorithm. This allows for much more robust tuning of the squish phase to eliminate print problems or increase the speed.
      • Resin LevelSense: Control the level at which the printer throws a low resin warning. This will also change the level that the printer keeps the resin tank filled to for Formlabs materials.
      • Resin viscosity: Input the resin viscosity for a print. This can impact some print behaviors.
  • Bug fixes:
    • Fixed several issues with the new Support flyout to ensure it correctly respects selected settings.
    • Fixed a crash that could occur when selecting support profiles in the new Support flyout.
    • Fixed missing FORM file thumbnails on Windows.
    • Fixed incorrect mesh selection behavior when slicing along the X- or Y-axis.
    • Various minor UI improvements and fixes.
  • Known issues:
    • Keyboard shortcuts for the new Support flyout are not displayed in the shortcut dialog, but hovering over the button will display the shortcut.
PreForm 3.52.1 — September 25, 2025
This release introduces new functions to fill the build with models, expands the Slicer tool to let you examine your models along the X-, Y-, and Z-axes, and adds support for importing CAD assembly files. It also introduces a streamlined interface for the new Supports tool.
Mac Download: Link
  • New features:
    • New Support tool: Gain precise control over support generation with presets, customizable touchpoint generators, and comprehensive support structure customization. Use the new flexible visibility controls to inspect models and supports.
    • Section in all axes: Inspect internal geometry, complex support structures, and packed build volumes with confidence. Use the Slicer tool to see inside your model from any orthogonal direction, ensuring a perfect print every time. This is perfect for verifying internal support placement while you work, as the slice view is active while you move, rotate, or edit supports.
    • Fill the Build: Maximize throughput and minimize setup time for both SLA and SLS printers. Automatically populate the entire build platform or build chamber with as many copies of a selected part as can fit, turning a tedious manual layout task into a single click. Fine-tune your layout with advanced controls for part spacing, rotation, and even raft overlap (SLA) to achieve maximum packing density.
    • CAD assembly import: Import assembly files and split them into individual parts.
  • Improvements:
    • CAD import settings: Configure tessellation options for CAD imports.
    • Print time estimator control: Toggle the real-time print time estimator on/off to improve performance on demanding print jobs. Disable real-time print time estimator updates through File > Preferences to prevent interface lag while maintaining estimation accuracy when needed.
    • New Default print setting (V1.2) for Precision Model Resin V1 at 50 microns for Form 4 and Form 4L generation printers with improved dental die fitting.
  • Bug fixes:
    • Fixed an intermittent crash that could occur during cup detection in printability checks.
    • Fixed an intermittent crash when triggering the part cost calculator.
    • Fixed an intermittent crash when applying support presets.
    • Fixed an issue where parts imported into the dental workspace could have an incorrect orientation.
  • Known issues:
    • Keyboard shortcuts for the new Support tool are not displayed in the shortcut dialog, but hovering over the button will display the shortcut.
    • The support generation keyboard shortcut does not correctly apply updated settings. It reuses the last settings submitted via the button, ignoring any subsequent changes.
    • The last-used touch tip size in the Manual Placement tab is reset when supports are generated.
  • Compatibility:
    • Fuse 1: compatible with firmware version 1.15.3 and later
    • Fuse 1+: compatible with firmware version 1.15.3 and later
    • Form 4B: compatible with firmware version 1.7.2 and later
    • Form 4: compatible with firmware version 1.7.2 and later
    • Form 4L: compatible with firmware version 1.9.0 and later
    • Form 4BL: compatible with firmware version 1.9.0 and later
    • Form 3BL: compatible with firmware version 1.10.8 and later
    • Form 3L: compatible with firmware version 1.10.8 and later
    • Form 3B/3B+: compatible with firmware version 1.19.7 and later
    • Form 3/3+: compatible with firmware version 1.19.7 and later
    • Form 2: compatible with firmware version 1.19.25 and later
PreForm 3.51.1 — August 29, 2025
This release fixes a variety of bugs related to the new support tool introduced in PreForm 3.51.0 and adds an option to revert to the old interface.
Mac Download: Link
  • Improvements:
    • Added an option to switch to the previous support tool interface under Preferences.
  • Bug fixes:
    • Fixed bug where PreForm was unable to open some STL or FORM files
    • Fixed bug where PreForm would crash while editing supports manually
    • Fixed inconsistent accordion collapsing behavior
    • Fixed bug where clicking the Generate Structure button would remove manually created touchpoints
    • Fixed bug where PreForm would freeze when manually placing supports
  • Compatibility:
PreForm 3.51.0 — August 19, 2025
This release introduces a revamped SLA supports tool, allowing for precise control over touchpoint locations, streamlined manual placement, and support structure customization.
Mac Download: Link
  • New features:
    • Precise control over touchpoint locations: Adjust touchpoint placement by customizing the Minima, Overhangs, Stabilization, and Reinforcement touchpoint generators.
    • Streamlined manual placement: The Support Brush is now in its own dedicated tab for easier access for power users.
    • Support structure customization: Precisely control how support structures are created, from touchpoint properties to pillar and raft parameters.
    • Support visibility control: Inspect supported models without the support geometry getting in the way. Instantly toggle between showing the model with supports, transparent supports or only touchpoints.
  • Improvements:
    • Bundled Supports turned on by default: PreForm will cluster support pillars into bundles that can be easily removed during post processing. Bundled Supports are turned on by default for select materials and layer thicknesses.
  • Bug fixes:
    • Fixed issue where custom print settings could not be saved in Dental Workspace
    • Fixed issue where some STEP files could not be imported into PreForm
    • Fixed issue where deleting the current print applied print setting would crash PreForm
  • Print settings updates:
    • Speed Optimized Beta v5.3 setting promoted to Default v5.3 for Nylon 12 Powder. Default v4.1 renamed to Legacy v4.1
    • Legacy v1.2 setting for Nylon 12 GF Powder removed. Legacy settings can be found on the Choosing the right print setting (SLS) support article
    • Speed Optimized Beta v2.1 setting promoted to Default v2.1 for Nylon 11 Powder. Default v1.2 renamed to Legacy v1.2
    • Beta v1.1 setting promoted to Default v1.1 for Nylon 12 White Powder. Default v1.0 renamed to Legacy v1.0
    • Speed Optimized v2.1 promoted to Default v2.1 for TPU 90A Powder. Default v1.1 renamed to Legacy v1.1
  • Known issues:
    • Touchpoints may not render or display correctly when switching between support visibility modes
    • In the new Support tool, input fields do not show undo option until another input field is interacted with
    • Support tool window will not scroll if the mouse is over any input field
    • Keyboard shortcuts do not work correctly in the new Support tool
  • Compatibility:
PreForm 3.50.2 — August 4, 2025
This release fixes a bug related to uploading the same Form 4 generation print jobs multiple times.
Windows Download: Link
Mac Download: Link
  • Bug fixes:
    • Form 4 generation: Fixed a bug that caused PreForm to crash if the same job was sent to a printer more than once.
  • Compatibility:
PreForm 3.50.1 — July 30, 2025
This release introduces new and improved print settings for Grey Resin and Clear Resin on Form 3, Form 3L, and Form 4L generation printers. It also fixes two bugs related to custom print settings and support editing.
Mac Download: Link
  • Bug fixes:
    • Form 4 and Form 4L generation: Fixed issue where the printer would not squish for prints with custom squish settings.
    • Fixed bug where touchpoint size was not being applied in Supports Edit mode.
    • New Default print setting (V1.0) for Grey Resin V5 at 25 microns for Form 4L generation printers
    • New Default print setting (V1.0) for Clear Resin V5 at 25 microns for Form 4L generation printers
    • New Default print setting (V1.0) for Grey Resin V4.1 at 25 microns for Form 3 generation printers
    • New Default print setting (V1.0) for Grey Resin V4.1 at 25 microns for Form 3L generation printers
  • Compatibility:
PreForm 3.50.0 — July 22, 2025
This release introduces a limited beta support visibility feature as well as new and improved print settings for Grey Resin V4.1 on Form 3 generation printers and Flame Retardant Resin V1, Black Resin V5, and Tough 1500 Resin V2 on Form 4L generation printers.
Mac Download: Link
  • New features:
    • Support visibility control (Beta): Easily inspect models by cycling through new support visibility modes—fully visible, translucent, and touchpoints only. Inspect, edit, and validate touchpoint locations and support geometry easily. Ideal for all SLA users seeking to speed up their support workflow and more efficiently verify support placement. Note: This is a beta feature and is available to select users.
    • New Default print setting (V1.0) for Grey Resin V4.1 at 160 microns for Form 3 generation printers
    • New Default print setting (V1.0) for Flame Retardant Resin V1 at 50 microns for Form 4L generation printers
    • New Default print setting (V1.0) for Black Resin V5 at 25 microns for Form 4L generation printers
    • New Default print setting (V1.0) for Tough 1500 Resin V2 at 50 microns for Form 4L generation printers
  • Compatibility:
PreForm 3.49.0 — June 17, 2025
This release introduces support for Color Resin V5 and True Cast Resin, as well as a new color coding feature. It also includes new and improved print settings for general purpose resins.
Mac Download: Link
  • New features:
    • Color Resin V5 support: Now print with Color Resin V5, offering custom-ordered resin manufactured in just one week to your exact color specifications. This allows you to achieve rich, vibrant, and accurately matched colors for parts with versatile mechanical properties, all through a fast, affordable, and print-ready workflow. Ideal for users needing to create brand-aligned products, striking prototypes, functional color-coded parts, or unique end-use applications.
    • Introducing True Cast Resin: A new wax-filled material engineered for precise casting of detailed jewelry and complex components up to 5 mm thick. This high-performance resin enables the production of accurate parts with crisp features, smooth surfaces, that have a clean burnout, making it ideal for demanding casting applications. Whether you're a jeweler crafting medium to heavy jewelry pieces, medallions, or figurines, or an engineer producing small, complex parts, True Cast Resin offers a reliable and refined casting solution.
    • Part color coding: Easily assign distinct colors to individual models or entire model lists within your PreForm build, either manually or with one-click random generation. This feature significantly improves build organization and makes identifying specific parts faster, especially in densely packed jobs. Ideal for SLS users who frequently manage and pack numerous models into a single build.
  • Known issues:
    • Unable to add label after using Scan to Model
    • New Default print setting (V1.0) for White Resin V4.1 at 50 microns for Form 3L generation printers
    • New Default print setting (V1.0) for Grey Resin V4.1 at 50 microns for Form 3L generation printers
    • New Default print setting (V1.0) for True Cast Resin V1 at 50 microns for Form 4 generation printers
    • New Default print setting (V1.0) for True Cast Resin V1 at 25 microns for Form 4 generation printers
    • Changed raft text font for compatibility with more system configurations.
    • Lowered printing temperature for general purpose resins for 100 and 50 micron settings for improved resin stability.
  • Compatibility:
PreForm 3.48.0 — May 27, 2025
This release introduces a face selection mode in the Texture tool, a Reduced Supports print setting for certain resins on Form 4 generation printers, and four new parameters in the Print Settings Editor for Form 4 generation printers. It also includes new and improved print settings for Form 3, Form 3L, Form 4, and Form 4L generation printers.
Mac Download: Link
  • New features:
    • Face selection mode in Texture tool: Now you can apply textures to specific faces of your 3D models rather than the entire object. Import color-coded CAD files and easily select faces by color in the Texture panel, giving you greater precision and control over your printed parts' surface finish and appearance.
    • Reduced Supports print settings: reduce support touchpoints by up to 30% resulting in cleaner surfaces and less post-processing work. Heavy or complicated models may not print successfully.
  • Improvements:
    • Debris detection setting in Print Settings Editor: Prevent the printer from stopping a print when it encounters higher than expected forces.
    • Preprint mixer speed setting in Print Settings Editor: Control the speed at which the mixer moves before a print.
  • Bug fixes
    • Fixed incorrect Broken Models Detected warning when importing certain model files
    • Fixed issue where PreForm would incorrectly flag overlapping models
    • Fixed issue to reduce mixer collisions using 160 micron Fast Arch setting with Fast Model Resin on Form 4L generation printers
  • Known issues:
    • New Default print setting (V1.0) for Grey Resin V4.1 at 100 microns for Form 3L generation printers
    • New Default print setting (V1.0) for Grey Resin V4.1 at 50 microns for Form 3 generation printers
    • New Default print setting (V1.0) for White Resin V4.1 at 50 microns for Form 3 generation printers
    • New Default print setting (V1.0) for Tough 1500 Resin V2 at 50 microns for Form 4 generation printers
    • New Default print setting (V1.0) for High Temp Resin V2 at 50 microns for Form 4L generation printers
    • New Default print setting (V1.0) for ESD Resin at 50 microns for Form 4L generation printers
  • Compatibility:
PreForm 3.47.1 — April 28, 2025
This release fixes the names of some Beta print settings for Formlabs SLS printers.
Mac Download: Link
  • Improvements:
    • Fixed print settings names for Formlabs SLS printers
  • Compatibility:
PreForm 3.47.0 — April 23, 2025
This release improves support generation and print time estimation speeds. It also includes new and improved print settings for Fuse 1+ 30W printers.
Mac Download: Link
  • Improvements:
    • Faster support generation: Spend less time waiting for supports to generate on your SLA prints thanks to performance improvements.
    • Saved Print Validation settings: PreForm now remembers your Print Validation toggle choices between sessions, streamlining your setup workflow.
    • Faster, smoother print time estimates: The rapid print time estimator now provides quicker feedback and uses less of your computer's resources.
  • Bug fixes
    • Printer selection remembered: Fixed an issue where the last used printer wasn't always saved. PreForm now reliably remembers your printer choice in Job Setup.
    • Updated Speed Optimized Beta setting for Nylon 12 Powder for Fuse 1+ 30W to improve surface quality while maintaining speed and accuracy.
    • New Speed Optimized Beta setting for Nylon 11 Powder for Fuse 1+ 30W with significant improvements to surface quality and for fastest printing speed.
    • New Default setting for Nylon 11 CF Powder for Fuse 1+ 30W to combat warping in the Z direction and improve surface quality.
    • New Beta setting for Nylon 12 White Powder for Fuse 1+ 30W which improves fine feature resolution and strength.
  • Compatibility:
PreForm 3.46.1 — April 7, 2025
This release improves noise mitigation for Form 4 and Form 4L generation printers. It also includes new and improved print settings for Form 3L, Form 4, and Form 4L generation printers.
Mac Download: Link
  • Improvements:
    • Improves printer noise mitigation: In PreForm 3.46.0, Formlabs released a new feature that made the Form 4 and Form 4L printers quieter. We have further improved the feature to make sure the printer is quieter for most prints.
    • New Default print settings for Precision Model Resin V1 at 25 microns for Form 4L generation printers
    • New Default print setting for BioMed Clear Resin V1 at 50 microns for Form 4BL printers
    • Minor accuracy improvements for:
      • White Resin V4.1 at 100 microns for Form 3L generation printers
      • Tough 1500 Resin V2 at 100 microns for Form 4 generation printers
      • Tough 1500 Resin V1 at 100 microns for Form 4L generation printers
    • Faster on-rafts prints for:
      • Precision Model Resin V1 at 50 microns for Form 4L generation printers
      • Clear Resin V5 at 50 microns for Form 4L generation printers
      • Tough 2000 Resin V2 at 50 microns for Form 4L generation printers
  • Compatibility:
PreForm 3.46.0 — March 24, 2025
PreForm 3.46.0 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 4L, Form 4BL, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release includes a new feature to add parts to a running job on Fuse 1 & 1+. It also has bug fixes for file uploading issues and mouse scrolling, and new Default Settings for Form 4, Form 4L, Form 4BL, Form 3, Form 3L and Form 3BL printers.
Mac Download: Link
  • New features:
    • Maximize printer efficiency with Add to Running Job (Beta): The "Add to Running Job" feature (Beta) for Fuse 1 & Fuse 1+ enables adding parts to ongoing prints, eliminating wait times between jobs. Quickly respond to urgent orders, streamline daily workflows, and minimize downtime—perfect for dynamic environments and efficient production management.
  • Improvements:
    • Grouped prints in Voting Center (for SLS): The SLS voting feature now groups prints by date, making it easier to find and vote on prior prints.
  • Bug fixes:
    • Fixed issue where some Form 4B jobs could not be uploaded to a printer group with Form 4B printers.
    • Fixed issue with mouse scrolling on the slicer slider.
    • New Default print setting for Tough 1500 V2 Resin at 100 microns for the Form 4 and Form 4L generation printers.
    • New Default print setting for Grey V4.1 Resin at 100 microns for the Form 3 generation printers.
    • New Default print setting for White V4.1 Resin at 100 microns for the Form 3L generation printers.
    • Minor Default print settings update for Grey and Black V5 Resin at 50 microns to version 1.2 for the Form 4L generation printers to reduce print failures for very large, solid parts.
    • Minor Default print settings update for Clear and White V5 Resin at 50 microns to version 1.1 for the Form 4L generation printers to reduce print failures for very large, solid parts.
  • Known Issues:
    • When creating new jobs as part of Add to Running Job, the total print time will not update correctly.
  • Compatibility:
PreForm 3.45.2 — March 11, 2025
PreForm 3.45.2 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 4L, Form 4BL, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release includes print settings updates for BioMed Black, BioMed Amber, Surgical Guide, and Color Base resins for Form 4L and Form 4BL. It also has a bug fix to prevent mini-rafts from intersecting with models printed directly on the build platform.
Mac Download: Link
  • Bug fixes:
    • Fixed issue where some mini rafts would intersect with the model when printing directly on the BP for the Form 4 and Form4L generation printers.
    • Added Default setting for BioMed Black Resin at 50 microns for the Form 4BL printer
    • Added Default setting for BioMed Amber Resin at 50 microns for the Form 4BL printer
    • Added Default setting for Surgical Guide Resin at 50 microns for the Form 4BL printer
    • Added Default setting for Color Base Resin at 100 microns for the Form 4L generation printers
  • Compatibility:
PreForm 3.45.1 — February 28, 2025
PreForm 3.45.1 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 4L, Form 4BL, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release includes new features for auto-layout (SLA), packing (SLS), print voting (SLS), and print time estimation (SLA). It also has bug fixes for file uploading issues, and new Default Settings for Form 4L, Form 4BL printers, Form 3L and Form 3BL printers.
Mac Download: Link
  • Bug fixes:
    • Fixing a potential software crash that could occur under certain conditions.
  • Compatibility:
PreForm 3.45.0 — February 25, 2025
PreForm 3.45.0 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 4L, Form 4BL, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release includes new features for auto-layout (SLA), packing (SLS), print voting (SLS), and print time estimation (SLA). It also has bug fixes for file uploading issues, and new Default Settings for Form 4L, Form 4BL printers, Form 3L and Form 3BL printers.
Mac Download: Link
Note:
Note: PreForm 3.45.0 no longer supports Windows 7 and 8, our new minimum version is Windows 10 October 2018 Update (version 1809)
  • New features:
    • Enhanced Layout feature (SLA): The automatic Layout tool has been optimized to utilize 25% more build platform space. This enhanced space utilization reduces the need for manual part arrangement while delivering more efficient print layouts.
    • Print time estimation (Form 4): When preparing Form 4 builds, you'll now see print time estimates that update in real-time as you modify your setup. This immediate feedback helps you better plan and schedule your print jobs, improving workflow efficiency.
    • Distance to Wall setting (SLS): PreForm’s powerful auto packing feature now allows you to configure a Distance to Wall setting. When a value is set, the algorithm will ensure an offset of that distance from the build chamber walls.
    • Print voting in PreForm (SLS): Vote on your earlier prints.
  • Improvements:
    • Statistics tracking update (SLS): We've refined our statistics tracking by excluding cages from model counts. This change provides more accurate metrics for actual part printing, giving you a clearer picture of your printing activity.
  • Bug fixes:
    • Fixed issue where FPS files were disappearing: When closing PreForm, some users’ FPS files would disappear. This has now been fixed.
    • Added Default setting for Rigid v1 Resin at 50 micron for Form 4L generation printers
    • Added Default setting for Black v4.1 Resin at 50 micron for Form 3L generation printers
    • Added Default setting for Clear v4.1 Resin at 50 micron for Form 3L generation printers
PreForm 3.44.2 — February 17, 2025
PreForm 3.44.2 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 4L, an Form 4BL printers. This release introduces new print settings and optimizations to enhance print quality and expand material capabilities across our printer lineup
Mac Download: Link
Note: PreForm 3.45.0 and above will no longer support Windows 7 and 8.
    • Added Default setting for Durable v2.1 Resin at 50 micron for Form 4L generation printers
    • Added Default Setting for Precision Model Resin at 100 microns for Form 4L and Form 4BL printers
    • Updated Speed Optimized V5.1 to Speed Optimized Beta V5.2 setting for Nylon 12 Powder for the Fuse 1+. This setting provides significantly improved accuracy and reduced z-axis warpage while maintaining the same print speed as v5.1
PreForm 3.44.1 — February 10, 2025
PreForm 3.44.1 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 4L, Form 4BL, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features bug fixes for job uploading issues with Fuse 1 generation printers, minor UI fixes for the Print Settings Editor, and new Default Settings for Form 4L and Form 4BL printers
Mac Download: Link
  • Bug fixes:
    • Fixed issue in PreForm 3.44.0 where some users encountered the error FL0 generation failed when uploading jobs to Fuse 1 generation printers
    • Fixed issue in PreForm 3.44.0 where Download History (CSV) feature did not work for Fuse printers
    • Minor UI fixes for Print Settings Editor
    • Added Default Setting for Grey V5 Resin at 150 microns for Form 4L and Form 4BL printers
    • Added Default Setting for Premium Teeth Resin at 50 microns for Form 4BL printers
    • Added Default Setting for Rigid 10K Resin at 50 microns for Form 4L and Form 4BL printers
PreForm 3.44.0 — January 29, 2025
PreForm 3.44.0 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 4L, Form 4BL, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features a new bundled supports feature for SLA printers, new language support in PreForm's UI, faster CAD imports, and bug fixes.
Mac Download: Link
Note: PreForm versions 3.45.0 and later will no longer support Windows 7 and Windows 8.
  • New features:
    • Bundled Supports: Groups support structures together for easier support removal, reducing post-processing time, and improving supported surface finish. Enable the option under the Supports flyout.
    • Language support: Switch PreForm’s UI to any of the supported languages: English, French, German, Italian, Japanese, Spanish, Simplified Chinese or Traditional Chinese. Select the language in the Settings window.
  • Improvements:
    • Streamlined job setup: Simplified visual feedback during print setup by turning the Undersupported model warning (indicated by red shading) off by default for some users. You can toggle this visualization in Print Validation settings if you prefer the previous behavior.
    • Faster CAD import: Improved performance when importing CAD files for faster print setup
  • Bug fixes:
    • Fixed issue where opening a FORM file would sometimes not select the correct printer type
    • Fixed issue preventing users from printing or saving FORM files with Castable Wax Resin on Form 4L/4BL
    • Tough 2000 v1.1 update: Released new Default V2 print setting at 100 microns with significant support structure improvements for better surface quality and easier support removal. The previous Default V1 print setting remains available as Legacy V1 for existing workflows.
  • Known issues:
    • The Form Wash and Form Cure updater is currently not working. For updating these units, Windows and MacOS users should use PreForm 3.39.0.
PreForm 3.43.2 — January 21, 2025
PreForm 3.43.2 is a recommended update for Fuse 1, Fuse 1+, Form 4B, Form 4, Form 4L, Form 4BL, Form 3BL, Form 3L, Form 3B/Form 3B+, Form 3/Form 3+, and Form 2 printers. This release features added support for IBT Flex Resin V1 and updated BioMed Flex Resin V1 on Form 4BL printers.
Mac Download: Link
    • Form 4BL: Added support for IBT Flex Resin V1 with 100 micron print settings
    • Form 4BL: Updated BioMed Flex Resin V1 at 100 microns to improve dimensional accuracy
Older versions
Looking for versions of PreForm from before the year 2025? Check the archive:
