Warning:
Wear gloves when handling printed parts and surfaces that are contaminated with solvent or liquid resin to prevent skin contact.
Thoroughly clean the Build Platform 2 between prints. When performing consecutive prints using the same resin, you can clean the outside surfaces of the Build Platform 2 without separating the print surface from the build platform body. If you are changing resins between prints, disassemble the Build Platform 2 so you can clean between the print surface and the build platform body. Follow the instructions below to keep the build platform clean and well-maintained.
Warning:
Unless thoroughly cleaned of any uncured resin, always store the Build Platform 2 in a printer with the cover closed or away from any sources of light when not in use.
Cleaning the Build Platform 2 before printing with the same resin
If you are performing consecutive prints with the same resin, you do not generally need to remove the flexible surface from the build platform body for cleaning.
To prepare your Build Platform 2 for a new print using the same resin:
Cleaning the Build Platform 2 before printing with different resins
If you are changing resins between prints, remove the print surface from the build platform’s body to make sure all surfaces of the Build Platform 2 are thoroughly cleaned.
Caution:
To prepare your Build Platform 2 for a new print with a different resin:
Step 2: Clean the Build Platform 2
Step 3: Reinstall the print surface
