Inspecting and cleaning resin tanks (Form 3L/Form 3BL)
Maintain and clean each resin tank using Formlabs instructions to maximize tank performance and to ensure consistent, high-quality prints over a tank’s lifetime. Only use approved materials and processes to clean the resin tank and film.
Tip:
Check that the resin tank is in good condition between prints and before storing the resin tank in the tank case. Remove debris and clean the tank after a failed print.
Inspecting the resin tank
For the best results, inspect resin tanks regularly and, if necessary, clean them. Dirty optical surfaces and damage to the flexible film may cause print failures.
Required supplies:
  • Non-reactive nitrile gloves
  • Tank tool
Inspecting the resin tank interior
To inspect the resin tank interior:
  1. Put on a clean pair of nitrile gloves.
  2. Use the tank tool to inspect the resin and the film for any print failures. Check for the following issues that may lead to print failures or any excessive wear that requires replacing the tank:
    • Cured resin on the film
    • Debris or failed prints in the resin
    • Punctures, cuts, or gouges in the film
    • Resin caught between film layers
  3. If necessary, follow cleaning instructions to remove cured resin, failed prints, debris, and settled pigment.
  4. Check that the mixer and float are properly installed in the tank.
Inspecting the resin tank exterior
To inspect the resin tank exterior:
  1. Put on a new, clean pair of nitrile gloves.
  2. Visually inspect the resin tank exterior for fingerprints, dust, contamination, and scratches, which cause the laser light to diffuse and lead to print failures or inaccuracies.
  3. If necessary, use the cleaning instructions to remove any fingerprints, dust, or contamination on the flexible film.
    • For moderate wear or scratches on the flexible film exterior, use the Layout tool in PreForm to move the model outside the worn or scratched area.
    • In the case of excessive wear or scratches on the flexible film exterior, switch to a new resin tank.
Inspecting the tank frame
To inspect the tank frame:
  2. Visually inspect the tank frame for contamination or resin. Resin on the tank frame may result in print failures and/or damage to the roller holder. If the roller holder is contaminated, refer to the support article Cleaning the roller holder (Form 3L/Form 3BL).
Cleaning the resin tank
Keep the resin tank—especially the top and underside surfaces of the flexible film—clean and free of cured resin and other debris to ensure print quality and extend the lifetime of the printer.
Warning:
Resin and solvent may cause skin irritation or an allergic skin reaction. Wear gloves when handling liquid resin, resin-coated surfaces, or solvent. Wash skin with plenty of soap and water.
Required resources
Resin tank exterior:
  • Isopropyl alcohol
  • PEC*PADs
Resin tank interior:
  • Tank tool
Tank frame:
  • Low-fiber paper towels
Cleaning the resin tank interior
To clean the resin tank interior:
  • Print failures:
  • Debris or contamination in the resin:
    • Refer to the support article Resin filtration.
    • Clean, debris-free resin helps avoid print failures, which may damage the resin tank.
  • Settled pigment in the resin:
    • Resin pigment can settle onto the flexible film interior. To supplement the mixer’s function, slide the tank tool against the flexible film to remove settled pigment.
Cleaning the resin tank exterior
To clean the resin tank exterior:
  2. Empty the liquid resin from the resin tank into an opaque container.
  3. Apply a small amount of clean isopropyl alcohol to a PEC*PAD.
  4. Wipe the flexible film exterior to remove contamination or resin.
Do not clean the inner surface of the flexible film (inside the resin tank) with isopropyl alcohol or any other solvent.
Do not allow liquid resin to become caught or to cure between the two layers of the flexible film. Resin trapped between the film layers renders the resin tank unusable.
Cleaning the tank frame
To clean the tank frame:
  2. Wipe the tank frame with a low-fiber paper towel to remove contamination or resin.
