Required Supplies:
- Fuse Sift sifter rework kit (RP-SFT-SRK-01)
Third-party:
- 2.5 mm hex driver (flat-end)
- 6.0 mm hex driver
- 6.5 mm slotted screwdriver
- 3.5 mm (#28) drill bit
- Drill
- 1.3 Nm torque screwdriver with 2.0 mm hex bit
- 12.5 Nm torque screwdriver with 6.0 mm hex bit
- Flashlight
- Tape
- Compliant vacuum with static dissipative components, such as a Class II, Division 2 vacuum
- Vacuum brush tools
- Appropriate personal protective equipment for the powder in use, as defined in the safety data sheet (SDS)
- Nonreactive nitrile gloves
- Loctite 243 or equivalent threadlocker
