Fuse 1 generation printers shall only be used with supplied accessories and additional tools recommended by Formlabs or a certified service provider. Third-party accessories and materials may cause damage.
The Fuse 1 generation printer is a Selective Laser Sintering (SLS) 3D printer that uses nylon powder as material. The use of personal protective equipment (PPE) is recommended when interacting with the Fuse 1 generation printers, and regular maintenance is required to ensure that the printer continues to run in proper working order.
Tools for cleaning and maintenance
The following tools and consumable supplies are necessary for cleaning and maintaining Fuse 1 generation printers. Non-abrasive microfiber cleaning cloths, polyester cloth swabs and a telescoping mirror are included with each Fuse 1 generation printer. Purchase additional cleaning cloths and swabs as needed to maintain your printer.
Note:
If ethanol is unavailable, 99.9% isopropyl alcohol is an acceptable alternative cleaning agent. Isopropyl alcohol does not evaporate as quickly as ethanol and is more difficult to clean with.
Personal protective equipment (PPE) for regular handling
Formlabs recommends always wearing PPE when interacting with Fuse 1 generation printers or handling parts printed on SLS printers.
Use the following equipment to ensure safe operation of the Fuse 1 generation printers.
